I've heard that when I have only object assigned to a class in a leaf, it means that my tree is overtested.
Could you tell me if this is something wrong with my optimize operator?
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.003">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.1.003" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="8.1.003" expanded="true" height="68" name="Retrieve bookratingsTagsUserNEW" width="90" x="179" y="85">
<parameter key="repository_entry" value="bookratingsTagsUserNEW"/>
<operator activated="true" class="concurrency:optimize_parameters_grid" compatibility="8.1.003" expanded="true" height="124" name="Optimize Parameters (Grid)" width="90" x="447" y="85">
<list key="parameters">
<parameter key="Performance.accuracy" value="true,false"/>
<parameter key="Decision Tree.minimal_size_for_split" value="[0.0;0.0;0;linear]"/>
<parameter key="Decision Tree.confidence" value="[1.0E-7;0.5;10;linear]"/>
</list>
<operator activated="true" class="split_data" compatibility="8.1.003" expanded="true" height="103" name="Split Data" width="90" x="45" y="238">
<enumeration key="partitions">
<parameter key="ratio" value="0.7"/>
<parameter key="ratio" value="0.3"/>
</enumeration>
<operator activated="true" class="concurrency:parallel_decision_tree" compatibility="8.1.003" expanded="true" height="103" name="Decision Tree" width="90" x="179" y="85">
<parameter key="maximal_depth" value="100"/>
<parameter key="confidence" value="0.5"/>
<parameter key="minimal_leaf_size" value="1"/>
<parameter key="minimal_size_for_split" value="3"/>
<operator activated="true" class="apply_model" compatibility="8.1.003" expanded="true" height="82" name="Apply Model" width="90" x="246" y="238">
<operator activated="true" class="performance_classification" compatibility="8.1.003" expanded="true" height="82" name="Performance" width="90" x="380" y="187">
<parameter key="main_criterion" value="accuracy"/>
<list key="class_weights"/>
<connect from_port="input 1" to_op="Split Data" to_port="example set"/>
<connect from_op="Split Data" from_port="partition 1" to_op="Decision Tree" to_port="training set"/>
<connect from_op="Split Data" from_port="partition 2" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Decision Tree" from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_op="Apply Model" from_port="model" to_port="model"/>
<connect from_op="Performance" from_port="performance" to_port="performance"/>
<portSpacing port="sink_performance" spacing="0"/>
<portSpacing port="sink_output 1" spacing="0"/>
</process>
<connect from_op="Retrieve bookratingsTagsUserNEW" from_port="output" to_op="Optimize Parameters (Grid)" to_port="input 1"/>
<connect from_op="Optimize Parameters (Grid)" from_port="performance" to_port="result 2"/>
<connect from_op="Optimize Parameters (Grid)" from_port="model" to_port="result 1"/>
</process>
</process>
For example something like that, where to the classses I have one object assigned:
