Altair RISE
Nominate Yourself Now!
Non managed error which has stopped solving proces
User: "Junki Park"
Altair Community Member
Updated by Junki Park
I can't solve the problem 3d model
Model is synchronous generator.
Analysis is set to transient magnetic 3d
I check geometry, mesh , physics .. but there i no error
But, whenever I start to solve problem, Flux gives:
Message :
executeAlgo_c : Execution failed.
Failed execution
Non managed error which has stopped solving process
Advanced :
MXQSPETSC => PETSc solver call failed
MXQSPETSC => Linear Solving with PETSc failed
MXQSLI_1 => Solving process of linear system is aborted
PBC3VP_2 => Newton-Raphson process is aborted
PBC2VP   => Gauss-Seidel process is aborted
PBC1VP   => Solving process is aborted
PBCVP0   => failed
PB2RGS   => Failed
PB1RGS   => Failed
PBCIR2_1 => Failed
PBCDV1_1 => Failed
PBCDV0   => Failed
PBCPEI   => Failed
PBEAVR   => failed
PB_FNUM1_2 => Problem while evaluating. Unable to solve the project.
PBEPVD_4 => Failed
PBEETA_3 => failed
PBCEVL_4 => failed
PBCEVL_3 => Failed
PBERES_3 => failed
FL5RE4   => Command not executed correctly
FL5ERS   => failed
FL5ERS_1 => failed
executeAlgo_c => failed
stdcom.error.SoftwareFortranException: executeAlgo_c : Execution failed.
Failed execution
    at cad.core.common.error.ErrorManager.createFortranException(ErrorManager.java:174)
    at cad.flux.kernel.dbmanager.FGCProjectDbWrapper.executeAlgo(Na tive Method)
    at cad.flux.kernel.dbmanager.FGCProjectDbAdapter.executeAlgo(FGCProjectDbAdapter.java:932)
    at cad.flux.kernel.dbmanager.FGCDbManager.executeAlgo(FGCDbManager.java:151)
    at cad.flux.kernel.FGSupervisor.executeNativeCommand(FGSupervisor.java:2249)
    at cad.flux.kernel.actions.implementation.algo.project.KSolveScenarioAction.doAction(KSolveScenarioAction.java:83)
    at cad.core.common.dynamic.actions.UIActionManager.postAction(UIActionManager.java:147)
    at cad.core.kernel.KernelCommon.postAction(KernelCommon.java:347)
    at cad.core.kernel.Supervisor.executeJavaCommand(Supervisor.java:2933)
    at cad.core.kernel.Supervisor.executeCommand(Supervisor.java:2111)
    at cad.core.kernel.Supervisor.executeMethod(Supervisor.java:2230)
    at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
    at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    at java.base/java.lang.reflect.Method.invoke(Unknown Source)
    at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
    at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:208)
    at org.python.core.PyObject.__call__(PyObject.java:523)
    at org.python.core.PyObject.__call__(PyObject.java:528)
    at org.python.core.PyMethod.__call__(PyMethod.java:171)
    at pydb$py.executeMethod$212(pydb.py:1730)
    at pydb$py.call_function(pydb.py)
    at org.python.core.PyTableCode.call(PyTableCode.java:173)
    at org.python.core.PyBaseCode.call(PyBaseCode.java:168)
    at org.python.core.PyFunction.__call__(PyFunction.java:437)
    at org.python.core.PyMethod.__call__(PyMethod.java:156)
    at pydb$py.__call__$179(pydb.py:1501)
    at org.python.core.PyBaseCode.call(PyBaseCode.java:306)
    at org.python.core.PyBaseCode.call(PyBaseCode.java:197)
    at org.python.core.PyFunction.__call__(PyFunction.java:485)
    at org.python.core.PyMethod.instancemethod___call__(PyMethod.java:237)
    at org.python.core.PyMethod.__call__(PyMethod.java:228)
    at org.python.core.PyMethod.__call__(PyMethod.java:223)
    at org.python.core.PyObject.invoke(PyObject.java:3636)
    at org.python.core.PyInstance.instance___call__(PyInstance.java:377)
    at org.python.core.PyInstance.__call__(PyInstance.java:372)
    at org.python.core.PyObject.__call__(PyObject.java:411)
    at org.python.pycode._pyx7.f$0(<input>:1)
    at org.python.pycode._pyx7.call_function(<input>)
    at org.python.core.PyCode.call(PyCode.java:18)
    at org.python.core.Py.runCode(Py.java:1698)
    at org.python.core.Py.exec(Py.java:1742)
    at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:277)
    at cad.core.kernel.components.PythonWrapper.runCode(PythonWrapper.java:655)
    at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:650)
    at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:625)
    at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:620)
    at cad.core.kernel.components.PythonWrapper.execute(PythonWrapper.java:665)
    at cad.core.kernel.components.PythonWrapper.executeFunction(PythonWrapper.java:733)
    at cad.core.kernel.encoder.CommandServerRequestsInputPlug.executeCommand(CommandServerRequestsInputPlug.java:79)
    at stdcom.protocole.commandserverrequests.CommandServerRequestsRouter.executeCommand(CommandServerRequestsRouter.java:70)
    at stdcom.protocole.commandserverrequests.CommandServerRequestsOutputPlug.executeCommand(CommandServerRequestsOutputPlug.java:111)
    at cad.core.frontal.decoder.FrontalDecoder.executeCommand(FrontalDecoder.java:694)
    at cad.core.frontal.actions.implementation.GeneralAction.executeBox(GeneralAction.java:286)
    at cad.flux.frontal.actions.implementation.algo.project.FAbstractSaveAsAction.executeBox(FAbstractSaveAsAction.java:93)
    at cad.core.frontal.actions.implementation.GeneralAction.postAct(GeneralAction.java:254)
    at cad.core.frontal.actions.implementation.GeneralAction.interpret(GeneralAction.java:315)
    at cad.core.frontal.components.box.frontaldialog.FrontalDescriptorDialogBox.internalRun(FrontalDescriptorDialogBox.java:296)
    at cad.core.frontal.frontalthread.WorkerThread.executeImplementer(WorkerThread.java:226)
    at cad.core.frontal.frontalthread.WorkerThread.run(WorkerThread.java:274)
what should i do?
1 - 2 of 21
    User: "asoualmi"
    Updated by asoualmi
    The problem come the solver as mentioned in the error message. Did you parameterized the PETs solver in the supervisor? If it not the case, you should do it.
    To do it:
    Flux Supervisor >> options >> parallel computing >> new window will be opened (see attached picture) >> click on add (you put the name of your machine (laptop) and the number processes that you want to use.
    Thanks.
    User: "HaoZhouBremen"
    Hi, I am encountering this issue with PETs solver exactly with Flux 2025.1 There is no such setting option any more in this latest version. My simulation works with direct sover. But it is very slow and iterative solver fails. Any suggestion? Thanks
    User: "Junki Park"
    OP
    To do it:
    Thanks.
    It’s working. Thank you
