Altair RISE
Nominate Yourself Now!
QuantX 'Eurostat Data Extractor' yields no data
User: "greg_lorincz79"
New Altair Community Member
Updated by Jocelyn
I've downloaded and installed the QuantX extension package and the Eurostat Data Extractor provides no data. I have selected codes in the parameter menu and yet all I get is an empty example set. What am I doing wrong?
<?xml version="1.0" encoding="UTF-8"?><process version="8.2.000">
<operator activated="true" class="quantx1:eurostat_data_extractor" compatibility="1.0.006" expanded="true" height="68" name="EuroStat Data Extractor" width="90" x="495" y="35">
<parameter key="Select Codes" value="med_ps32|proj_10c2150p|hsw_n2_05|road_eqs_busage"/>
<parameter key="Cache Data in Memory" value="false"/>
</process>
1 - 1 of 11
    User: "lionelderkrikor"
    Accepted Answer
    Hi @greg_lorincz79,
    Unfortunately, this extension is died. The developers do not maintain it anymore.
    Alternately, you can consider these extensions if you are looking for financial data :
     - Alpha Venture API
     - Quandl
    I hope it helps,
    Lionel
