Helo,
I have a problem with my decision tree. It generated only one node. Then I started to minimize the confidence even to 0.1 and min gain to 0.001. However, it didn't help. Could you please tell me what to do?
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.003">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.1.003" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="8.1.003" expanded="true" height="68" name="Retrieve Books_Ratings_Tags_forUser10" width="90" x="112" y="85">
<parameter key="repository_entry" value="Books_Ratings_Tags_forUser10"/>
<operator activated="true" class="split_data" compatibility="8.1.003" expanded="true" height="103" name="Split Data" width="90" x="246" y="85">
<enumeration key="partitions">
<parameter key="ratio" value="0.8"/>
<parameter key="ratio" value="0.2"/>
</enumeration>
<operator activated="true" class="concurrency:parallel_decision_tree" compatibility="8.1.003" expanded="true" height="103" name="Decision Tree" width="90" x="447" y="34">
<parameter key="confidence" value="0.1"/>
<parameter key="minimal_gain" value="0.001"/>
<operator activated="true" class="apply_model" compatibility="8.1.003" expanded="true" height="82" name="Apply Model" width="90" x="581" y="136">
<connect from_op="Retrieve Books_Ratings_Tags_forUser10" from_port="output" to_op="Split Data" to_port="example set"/>
<connect from_op="Split Data" from_port="partition 1" to_op="Decision Tree" to_port="training set"/>
<connect from_op="Split Data" from_port="partition 2" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Decision Tree" from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_op="Apply Model" from_port="model" to_port="result 1"/>
</process>
</process>
Best wishes
Olga
