Hello eveyone,
Does anybody knows how to join two tables based on a date-time atributs from each, but those attribut are not equal.
Here is the frst date-time attribut from the 1st dataset:
I need to join 2 excel files
the 1st one contine this column:
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">00</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">00</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">00</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">10</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">00</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">20</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">00</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">30</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">00</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">40</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">00</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">50</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">01</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">00</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">01</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">10</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">01</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">20</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">01</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">30</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">01</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">40</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">01</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">50</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">02</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">00</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">02</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">10</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">02</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">20</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">02</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">30</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">02</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">40</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">02</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">50</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">03</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">00</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">03</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">10</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">03</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">20</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">03</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">30</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">03</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">40</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">03</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">50</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">04</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">00</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">04</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">10</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">04</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">20</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">04</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">30</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">04</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">40</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">04</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">50</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">05</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">00</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">05</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">10</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">05</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">20</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">05</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">30</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">05</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">40</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">05</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">50</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">06</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">00</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">06</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">10</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">06</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">20</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">06</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">30</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">06</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">40</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">06</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">50</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">07</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">00</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">07</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">10</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">07</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">20</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">07</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">30</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">07</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">40</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">07</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">50</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">08</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">00</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">08</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">10</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">08</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">20</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">08</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">30</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">08</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">40</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">08</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">50</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">09</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">00</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">09</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">10</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">09</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">20</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">09</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">30</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">09</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">40</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">09</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">50</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">10</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">00</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">10</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">10</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">10</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">20</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">10</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">30</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">10</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">40</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">10</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">50</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">11</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">00</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">11</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">10</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">11</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">20</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">11</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">30</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">11</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">40</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">11</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">50</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">12</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">00</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">12</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">10</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">12</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">20</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">12</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">30</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">12</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">40</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">12</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">50</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">13</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">00</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">13</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">10</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">13</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">20</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">13</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">30</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">13</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">40</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">13</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">50</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">14</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">00</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">14</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">10</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">14</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">20</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">14</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">30</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">14</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">40</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">14</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">50</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">15</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">00</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">15</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">10</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">15</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">20</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">15</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">30</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">15</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">40</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">15</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">50</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">16</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">00</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">16</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">10</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">16</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">20</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">16</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">30</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">16</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">40</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">16</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">50</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">17</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">00</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">17</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">10</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">17</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">20</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">17</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">30</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">17</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">40</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">17</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">50</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">18</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">00</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">18</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">10</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">18</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">20</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">18</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">30</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">18</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">40</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">18</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">50</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">19</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">00</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">19</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">10</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">19</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">20</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">19</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">30</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">19</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">40</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">19</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">50</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">20</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">00</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">20</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">10</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">20</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">20</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">20</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">30</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">20</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">40</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">20</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">50</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">21</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">00</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">21</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">10</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">21</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">20</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">21</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">30</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">21</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">40</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">21</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">50</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">22</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">00</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">22</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">10</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">22</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">20</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">22</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">30</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">22</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">40</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">22</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">50</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">23</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">00</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">23</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">10</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">23</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">20</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">23</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">30</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">23</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">40</SPAN>
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">23</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">50</SPAN>
and the second one is like this:
<SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">01</SPAN><SPAN class="pun">/</SPAN><SPAN class="lit">2016</SPAN> <SPAN class="lit">08</SPAN><SPAN class="pun">:</SPAN><SPAN class="lit">00 and so one....</SPAN>
and i need to do the join based on the nearest value between these date attributs.
I really need your help.
Thank you so much.
