Hi, I want to rename all columns in a short format but some of the columns are said to not come from an input when they are coming, and when I check in the rename old name they are not available there, why that happens?
Hi again @sebastian_gonza,
The problem seems solved :
it is a mistake of "inattention" (maximum(Consumo_minutos)_AAA renamed two times) :
I corrected this issue and here the new process :
<?xml version="1.0" encoding="UTF-8"?><process version="8.2.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="8.2.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="8.2.000" expanded="true" height="68" name="Retrieve anytime_partitioned_limpia" width="90" x="45" y="34"> <parameter key="repository_entry" value="//Rapidminer_Tests/data/anytime_partitioned_limpia"/> </operator> <operator activated="true" class="select_attributes" compatibility="8.2.000" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="34"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="bda_contract|dba_genre|dba_hr_start|dba_hr_end|fecha_hr_inicio|fecha_hr_fin|cambio_prog|dba_duration"/> </operator> <operator activated="true" class="generate_attributes" compatibility="8.2.000" expanded="true" height="82" name="Generate Attributes" width="90" x="313" y="34"> <list key="function_descriptions"> <parameter key="Dur_minutos" value="dba_duration/60"/> <parameter key="hora_inicio_ok" value="cut(dba_hr_start,0,2)"/> <parameter key="ID" value="replace(bda_contract,".","")"/> </list> </operator> <operator activated="true" class="generate_attributes" compatibility="8.2.000" expanded="true" height="82" name="Generate Attributes (14)" width="90" x="447" y="34"> <list key="function_descriptions"> <parameter key="ID_ok" value="if(length(ID)==9,concat("0",ID),ID)"/> </list> </operator> <operator activated="true" class="nominal_to_numerical" compatibility="8.2.000" expanded="true" height="103" name="Nominal to Numerical" width="90" x="581" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="hora_inicio_ok"/> <parameter key="coding_type" value="unique integers"/> <list key="comparison_groups"/> </operator> <operator activated="true" class="generate_attributes" compatibility="8.2.000" expanded="true" height="82" name="Generate Attributes (2)" width="90" x="715" y="34"> <list key="function_descriptions"> <parameter key="Franjas" value="if(hora_inicio_ok>=6 && hora_inicio_ok<12,"A",if(hora_inicio_ok>=12 && hora_inicio_ok<18,"AA",if(hora_inicio_ok>=18 && hora_inicio_ok<24,"AAA","ON")))"/> </list> </operator> <operator activated="true" class="nominal_to_date" compatibility="8.2.000" expanded="true" height="82" name="Nominal to Date" width="90" x="849" y="34"> <parameter key="attribute_name" value="fecha_hr_inicio"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> </operator> <operator activated="true" class="date_to_numerical" compatibility="8.2.000" expanded="true" height="82" name="Date to Numerical" width="90" x="983" y="34"> <parameter key="attribute_name" value="fecha_hr_inicio"/> <parameter key="time_unit" value="day"/> <parameter key="day_relative_to" value="week"/> </operator> <operator activated="true" class="numerical_to_polynominal" compatibility="8.2.000" expanded="true" height="82" name="Numerical to Polynominal (4)" width="90" x="1117" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="fecha_hr_inicio"/> </operator> <operator activated="true" class="map" compatibility="8.2.000" expanded="true" height="82" name="Map (5)" width="90" x="1251" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="fecha_hr_inicio"/> <list key="value_mappings"> <parameter key="1" value="Entre semana"/> <parameter key="2" value="Entre semana"/> <parameter key="3" value="Entre semana"/> <parameter key="4" value="Entre semana"/> <parameter key="5" value="Entre semana"/> <parameter key="6" value="Fin de semana"/> <parameter key="7" value="Fin de semana"/> </list> </operator> <operator activated="true" class="select_attributes" compatibility="8.2.000" expanded="true" height="82" name="Select Attributes (2)" width="90" x="1385" y="34"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="Dur_minutos|Franjas|ID|bda_contract|cambio_prog|dba_genre|fecha_hr_inicio|ID_ok"/> </operator> <operator activated="true" class="rename" compatibility="8.2.000" expanded="true" height="82" name="Rename" width="90" x="1117" y="187"> <parameter key="old_name" value="Dur_minutos"/> <parameter key="new_name" value="Consumo_minutos"/> <list key="rename_additional_attributes"> <parameter key="bda_contract" value="ID_final"/> <parameter key="cambio_prog" value="Cambio_programa"/> <parameter key="dba_genre" value="Genero"/> <parameter key="fecha_hr_inicio" value="Dia semana"/> </list> </operator> <operator activated="true" class="multiply" compatibility="8.2.000" expanded="true" height="124" name="Multiply" width="90" x="45" y="238"/> <operator activated="true" class="aggregate" compatibility="8.2.000" expanded="true" height="82" name="Aggregate (3)" width="90" x="179" y="442"> <list key="aggregation_attributes"> <parameter key="Consumo_minutos" value="maximum"/> </list> <parameter key="group_by_attributes" value="Genero|ID_final"/> </operator> <operator activated="true" class="map" compatibility="8.2.000" expanded="true" height="82" name="Map" width="90" x="313" y="442"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Genero"/> <list key="value_mappings"> <parameter key="Animación" value="Animacion"/> <parameter key="Animacion" value="Animacion"/> <parameter key="Infinity" value="Infinity"/> <parameter key="-Infinity" value="Infinity"/> <parameter key="Deporte" value="Deportes"/> <parameter key="Deportes" value="Deportes"/> <parameter key="Mundo Animal" value="Mundo Animal"/> <parameter key="Reino Animal" value="Mundo Animal"/> </list> </operator> <operator activated="true" class="pivot" compatibility="8.2.000" expanded="true" height="82" name="Genero (2)" width="90" x="447" y="442"> <parameter key="group_attribute" value="ID_final"/> <parameter key="index_attribute" value="Genero"/> <parameter key="skip_constant_attributes" value="false"/> </operator> <operator activated="true" class="aggregate" compatibility="8.2.000" expanded="true" height="82" name="Aggregate" width="90" x="179" y="238"> <list key="aggregation_attributes"> <parameter key="Consumo_minutos" value="maximum"/> </list> <parameter key="group_by_attributes" value="Dia semana|ID_final"/> </operator> <operator activated="true" class="pivot" compatibility="8.2.000" expanded="true" height="82" name="Dayweek (2)" width="90" x="313" y="238"> <parameter key="group_attribute" value="ID_final"/> <parameter key="index_attribute" value="Dia semana"/> <parameter key="skip_constant_attributes" value="false"/> </operator> <operator activated="true" class="aggregate" compatibility="8.2.000" expanded="true" height="82" name="Aggregate (2)" width="90" x="179" y="340"> <list key="aggregation_attributes"> <parameter key="Consumo_minutos" value="maximum"/> </list> <parameter key="group_by_attributes" value="Franjas|ID_final"/> </operator> <operator activated="true" class="pivot" compatibility="8.2.000" expanded="true" height="82" name="Franjas (3)" width="90" x="313" y="340"> <parameter key="group_attribute" value="ID_final"/> <parameter key="index_attribute" value="Franjas"/> <parameter key="skip_constant_attributes" value="false"/> </operator> <operator activated="true" class="concurrency:join" compatibility="8.2.000" expanded="true" height="82" name="Join" width="90" x="581" y="289"> <parameter key="remove_double_attributes" value="false"/> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="ID_final" value="ID_final"/> </list> <parameter key="keep_both_join_attributes" value="true"/> </operator> <operator activated="true" class="concurrency:join" compatibility="8.2.000" expanded="true" height="82" name="Join (2)" width="90" x="648" y="391"> <parameter key="remove_double_attributes" value="false"/> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="ID_final_from_ES2" value="ID_final"/> </list> <parameter key="keep_both_join_attributes" value="true"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="8.2.000" expanded="true" height="103" name="Replace Missing Values" width="90" x="782" y="391"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="regular_expression" value="maximum.+"/> <parameter key="default" value="zero"/> <list key="columns"/> </operator> <operator activated="true" class="rename" compatibility="8.2.000" expanded="true" height="82" name="Rename (2)" width="90" x="916" y="391"> <parameter key="old_name" value="maximum(Consumo_minutos)_Automóviles"/> <parameter key="new_name" value="ANY_Autos"/> <list key="rename_additional_attributes"> <parameter key="maximum(Consumo_minutos)_Accion" value="ANY_Accion"/> <parameter key="maximum(Consumo_minutos)_Adultos" value="ANY_Adultos"/> <parameter key="maximum(Consumo_minutos)_Animacion" value="ANY_Animacion"/> <parameter key="maximum(Consumo_minutos)_Aventura" value="ANY_Aventura"/> <parameter key="maximum(Consumo_minutos)_Baile" value="ANY_Baile"/> <parameter key="maximum(Consumo_minutos)_Belleza" value="ANY_Belleza"/> <parameter key="maximum(Consumo_minutos)_Box" value="ANY_Box"/> <parameter key="maximum(Consumo_minutos)_Caricaturas" value="ANY_Caricaturas"/> <parameter key="maximum(Consumo_minutos)_Ciclismo" value="ANY_Ciclismo"/> <parameter key="maximum(Consumo_minutos)_Ciencia ficcion" value="ANY_Ciencia ficcion"/> <parameter key="maximum(Consumo_minutos)_Cocina" value="ANY_Cocina"/> <parameter key="maximum(Consumo_minutos)_Comedia" value="ANY_Comedia"/> <parameter key="maximum(Consumo_minutos)_Concurso" value="ANY_Concurso"/> <parameter key="maximum(Consumo_minutos)_Crimen" value="ANY_Crimen"/> <parameter key="maximum(Consumo_minutos)_Deportes" value="ANY_Deportes"/> <parameter key="maximum(Consumo_minutos)_Documental" value="ANY_Documental"/> <parameter key="maximum(Consumo_minutos)_Drama" value="ANY_Drama"/> <parameter key="maximum(Consumo_minutos)_Educativo" value="ANY_Educativo"/> <parameter key="maximum(Consumo_minutos)_Entretenimiento" value="ANY_Entretenimiento"/> <parameter key="maximum(Consumo_minutos)_Espectáculos" value="ANY_Espectaculos"/> <parameter key="maximum(Consumo_minutos)_Familiar" value="ANY_Familiar"/> <parameter key="maximum(Consumo_minutos)_Fantasía" value="ANY_Fantasia"/> <parameter key="maximum(Consumo_minutos)_Futbol Soccer" value="ANY_Futbol"/> <parameter key="maximum(Consumo_minutos)_Horror" value="ANY_Horror"/> <parameter key="maximum(Consumo_minutos)_Infantil" value="ANY_Infantil"/> <parameter key="maximum(Consumo_minutos)_Informativo" value="ANY_Informativo"/> <parameter key="maximum(Consumo_minutos)_Investigación" value="ANY_Investigacion"/> <parameter key="maximum(Consumo_minutos)_Lucha Libre" value="ANY_Lucha libre"/> <parameter key="maximum(Consumo_minutos)_Melodrama" value="ANY_Melodrama"/> <parameter key="maximum(Consumo_minutos)_Mundo animal" value="ANY_Mundo animal"/> <parameter key="maximum(Consumo_minutos)_Musical" value="ANY_Musical"/> <parameter key="maximum(Consumo_minutos)_Noticias" value="ANY_Noticias"/> <parameter key="maximum(Consumo_minutos)_Publicidad" value="ANY_Publicidad"/> <parameter key="maximum(Consumo_minutos)_Reality TV" value="ANY_Reality"/> <parameter key="maximum(Consumo_minutos)_Religión" value="ANY_Religion"/> <parameter key="maximum(Consumo_minutos)_Romance" value="ANY_Romance"/> <parameter key="maximum(Consumo_minutos)_Serie Animada" value="ANY_Serie animada"/> <parameter key="maximum(Consumo_minutos)_Serie Infantil" value="ANY_Serie infantil"/> <parameter key="maximum(Consumo_minutos)_Series" value="ANY_Series"/> <parameter key="maximum(Consumo_minutos)_Suspenso" value="ANY_Suspenso"/> <parameter key="maximum(Consumo_minutos)_Terror" value="ANY_Terror"/> <parameter key="maximum(Consumo_minutos)_Tv-show" value="ANY_Show"/> <parameter key="maximum(Consumo_minutos)_Fin de semana" value="ANY_FS"/> <parameter key="maximum(Consumo_minutos)_Entre semana" value="ANY_ES"/> <parameter key="maximum(Consumo_minutos)_AAA" value="ANY_AAA"/> <parameter key="maximum(Consumo_minutos)_AA" value="ANY_AA"/> <parameter key="maximum(Consumo_minutos)_A" value="ANY_A"/> <parameter key="maximum(Consumo_minutos)_ON" value="ANY_ON"/> </list> </operator> <operator activated="true" class="set_role" compatibility="8.2.000" expanded="true" height="82" name="Set Role (4)" width="90" x="1184" y="391"> <parameter key="attribute_name" value="ID_final"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"> <parameter key="ID_final_from_ES2" value="id"/> <parameter key="ID_final_from_ES2_from_ES2" value="id"/> </list> </operator> <operator activated="true" class="store" compatibility="8.2.000" expanded="true" height="68" name="Store (4)" width="90" x="1318" y="391"> <parameter key="repository_entry" value="Offline data ok para clusters/any_para_cluster"/> </operator> <connect from_op="Retrieve anytime_partitioned_limpia" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Generate Attributes (14)" to_port="example set input"/> <connect from_op="Generate Attributes (14)" from_port="example set output" to_op="Nominal to Numerical" to_port="example set input"/> <connect from_op="Nominal to Numerical" from_port="example set output" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Nominal to Date" to_port="example set input"/> <connect from_op="Nominal to Date" from_port="example set output" to_op="Date to Numerical" to_port="example set input"/> <connect from_op="Date to Numerical" from_port="example set output" to_op="Numerical to Polynominal (4)" to_port="example set input"/> <connect from_op="Numerical to Polynominal (4)" from_port="example set output" to_op="Map (5)" to_port="example set input"/> <connect from_op="Map (5)" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Aggregate (2)" to_port="example set input"/> <connect from_op="Multiply" from_port="output 2" to_op="Aggregate" to_port="example set input"/> <connect from_op="Multiply" from_port="output 3" to_op="Aggregate (3)" to_port="example set input"/> <connect from_op="Aggregate (3)" from_port="example set output" to_op="Map" to_port="example set input"/> <connect from_op="Map" from_port="example set output" to_op="Genero (2)" to_port="example set input"/> <connect from_op="Genero (2)" from_port="example set output" to_op="Join (2)" to_port="right"/> <connect from_op="Aggregate" from_port="example set output" to_op="Dayweek (2)" to_port="example set input"/> <connect from_op="Dayweek (2)" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Aggregate (2)" from_port="example set output" to_op="Franjas (3)" to_port="example set input"/> <connect from_op="Franjas (3)" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_op="Join (2)" to_port="left"/> <connect from_op="Join (2)" from_port="join" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Rename (2)" to_port="example set input"/> <connect from_op="Rename (2)" from_port="example set output" to_op="Set Role (4)" to_port="example set input"/> <connect from_op="Set Role (4)" from_port="example set output" to_op="Store (4)" to_port="input"/> <connect from_op="Store (4)" from_port="through" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <description align="center" color="yellow" colored="false" height="120" resized="false" width="180" x="1280" y="224">anytime</description> </process> </operator></process>
Lionel
Hi @sebastian_gonza,
Try to go in the menu :
Process --> Check Synchronize Meta Data with Real Data
If it is not working could you share your process and your dataset(s) ?
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="8.1.003" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="8.1.003" expanded="true" height="68" name="Retrieve anytime_partitioned_limpia" width="90" x="45" y="34"> <parameter key="repository_entry" value="//Local Repository/Offline data/anytime_partitioned_limpia"/> </operator> <operator activated="true" class="select_attributes" compatibility="8.1.003" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="34"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="bda_contract|dba_genre|dba_hr_start|dba_hr_end|fecha_hr_inicio|fecha_hr_fin|cambio_prog|dba_duration"/> </operator> <operator activated="true" class="generate_attributes" compatibility="8.1.003" expanded="true" height="82" name="Generate Attributes" width="90" x="313" y="34"> <list key="function_descriptions"> <parameter key="Dur_minutos" value="dba_duration/60"/> <parameter key="hora_inicio_ok" value="cut(dba_hr_start,0,2)"/> <parameter key="ID" value="replace(bda_contract,".","")"/> </list> </operator> <operator activated="true" class="generate_attributes" compatibility="8.1.003" expanded="true" height="82" name="Generate Attributes (14)" width="90" x="447" y="34"> <list key="function_descriptions"> <parameter key="ID_ok" value="if(length(ID)==9,concat("0",ID),ID)"/> </list> </operator> <operator activated="true" class="nominal_to_numerical" compatibility="8.1.003" expanded="true" height="103" name="Nominal to Numerical" width="90" x="581" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="hora_inicio_ok"/> <parameter key="coding_type" value="unique integers"/> <list key="comparison_groups"/> </operator> <operator activated="true" class="generate_attributes" compatibility="8.1.003" expanded="true" height="82" name="Generate Attributes (2)" width="90" x="715" y="34"> <list key="function_descriptions"> <parameter key="Franjas" value="if(hora_inicio_ok>=6 && hora_inicio_ok<12,"A",if(hora_inicio_ok>=12 && hora_inicio_ok<18,"AA",if(hora_inicio_ok>=18 && hora_inicio_ok<24,"AAA","ON")))"/> </list> </operator> <operator activated="true" class="nominal_to_date" compatibility="8.1.003" expanded="true" height="82" name="Nominal to Date" width="90" x="849" y="34"> <parameter key="attribute_name" value="fecha_hr_inicio"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> </operator> <operator activated="true" class="date_to_numerical" compatibility="8.1.003" expanded="true" height="82" name="Date to Numerical" width="90" x="983" y="34"> <parameter key="attribute_name" value="fecha_hr_inicio"/> <parameter key="time_unit" value="day"/> <parameter key="day_relative_to" value="week"/> </operator> <operator activated="true" class="numerical_to_polynominal" compatibility="8.1.003" expanded="true" height="82" name="Numerical to Polynominal (4)" width="90" x="1117" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="fecha_hr_inicio"/> </operator> <operator activated="false" class="retrieve" compatibility="8.1.003" expanded="true" height="68" name="Retrieve items_granular" width="90" x="45" y="697"> <parameter key="repository_entry" value="items_granular"/> </operator> <operator activated="false" class="generate_attributes" compatibility="8.1.003" expanded="true" height="82" name="Generate Attributes (3)" width="90" x="179" y="697"> <list key="function_descriptions"> <parameter key="ano" value="cut(fecha,0,4)"/> <parameter key="mes" value="cut(fecha,4,2)"/> <parameter key="dia" value="cut(fecha,6,2)"/> </list> </operator> <operator activated="false" class="generate_attributes" compatibility="8.1.003" expanded="true" height="82" name="Generate Attributes (4)" width="90" x="313" y="697"> <list key="function_descriptions"> <parameter key="fecha_ok" value="concat(mes,"/",dia,"/",ano)"/> </list> </operator> <operator activated="false" class="nominal_to_date" compatibility="8.1.003" expanded="true" height="82" name="Nominal to Date (2)" width="90" x="447" y="697"> <parameter key="attribute_name" value="fecha_ok"/> <parameter key="date_format" value="MM/dd/yyyy"/> </operator> <operator activated="false" class="date_to_numerical" compatibility="8.1.003" expanded="true" height="82" name="Date to Numerical (2)" width="90" x="581" y="697"> <parameter key="attribute_name" value="fecha_ok"/> <parameter key="time_unit" value="day"/> <parameter key="day_relative_to" value="week"/> </operator> <operator activated="false" class="map" compatibility="8.1.003" expanded="true" height="82" name="Map (4)" width="90" x="715" y="697"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="dia"/> <list key="value_mappings"> <parameter key="1" value="Entre semana"/> <parameter key="2" value="Entre semana"/> <parameter key="3" value="Entre semana"/> <parameter key="4" value="Entre semana"/> <parameter key="5" value="Entre semana"/> <parameter key="6" value="Fin de semana"/> <parameter key="7" value="Fin de semana"/> </list> </operator> <operator activated="false" class="numerical_to_polynominal" compatibility="8.1.003" expanded="true" height="82" name="Numerical to Polynominal" width="90" x="849" y="697"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="fecha_ok"/> </operator> <operator activated="false" class="map" compatibility="8.1.003" expanded="true" height="82" name="Map (2)" width="90" x="983" y="697"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="fecha_ok"/> <list key="value_mappings"> <parameter key="1" value="Entre semana"/> <parameter key="2" value="Entre semana"/> <parameter key="3" value="Entre semana"/> <parameter key="4" value="Entre semana"/> <parameter key="5" value="Entre semana"/> <parameter key="6" value="Fin de semana"/> <parameter key="7" value="Fin de semana"/> </list> </operator> <operator activated="false" class="map" compatibility="8.1.003" expanded="true" height="82" name="Map (6)" width="90" x="1117" y="697"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="data_"/> <list key="value_mappings"> <parameter key="Coco" value="Coco"/> <parameter key="Coco " value="Coco"/> <parameter key="Gamefly" value="Gamefly"/> <parameter key="Game fly" value="Gamefly"/> <parameter key="Game FLY" value="Gamefly"/> <parameter key="GameFLY" value="Gamefly"/> <parameter key="Geo-tormenta" value="Geo tormenta"/> <parameter key="VOD infantiles" value="Infantiles"/> <parameter key="VOD infantil" value="Infantiles"/> <parameter key="Game Fly" value="Gamefly"/> <parameter key="Gamefly " value="Gamefly"/> <parameter key="Geo-Tormenta" value="Geo tormenta"/> <parameter key="Fox_play" value="Fox play"/> <parameter key="Foxplay" value="Fox play"/> <parameter key="Gamefly " value="Game fly"/> <parameter key="GameFLY " value="Game fly"/> <parameter key="Infantiles" value="Infantiles"/> <parameter key="Geo tormenta" value="Geo tormenta"/> </list> </operator> <operator activated="false" class="generate_attributes" compatibility="8.1.003" expanded="true" height="82" name="Generate Attributes (5)" width="90" x="1318" y="697"> <list key="function_descriptions"> <parameter key="Franjas" value="if(hora>=6 && hora<12,"A",if(hora>=12 && hora<18,"AA",if(hora>=18 && hora<24,"AAA","ON")))"/> </list> </operator> <operator activated="false" class="select_attributes" compatibility="8.1.003" expanded="true" height="82" name="Select Attributes (3)" width="90" x="1452" y="697"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="Franjas|cluster_|data_|dia|numero_veces_ocupado|plan|fecha_ok"/> </operator> <operator activated="false" class="multiply" compatibility="8.1.003" expanded="true" height="145" name="Multiply (2)" width="90" x="45" y="952"/> <operator activated="false" class="aggregate" compatibility="8.1.003" expanded="true" height="82" name="Aggregate (7)" width="90" x="179" y="1309"> <list key="aggregation_attributes"> <parameter key="numero_veces_ocupado" value="average"/> </list> <parameter key="group_by_attributes" value="cluster_|data_"/> </operator> <operator activated="false" class="pivot" compatibility="8.1.003" expanded="true" height="82" name="Canal (2)" width="90" x="380" y="1309"> <parameter key="group_attribute" value="cluster_"/> <parameter key="index_attribute" value="data_"/> </operator> <operator activated="false" class="aggregate" compatibility="8.1.003" expanded="true" height="82" name="Aggregate (6)" width="90" x="179" y="1156"> <list key="aggregation_attributes"> <parameter key="numero_veces_ocupado" value="average"/> </list> <parameter key="group_by_attributes" value="cluster_|plan"/> </operator> <operator activated="false" class="pivot" compatibility="8.1.003" expanded="true" height="82" name="Plan" width="90" x="380" y="1156"> <parameter key="group_attribute" value="cluster_"/> <parameter key="index_attribute" value="plan"/> </operator> <operator activated="false" class="aggregate" compatibility="8.1.003" expanded="true" height="82" name="Aggregate (4)" width="90" x="179" y="850"> <list key="aggregation_attributes"> <parameter key="numero_veces_ocupado" value="average"/> </list> <parameter key="group_by_attributes" value="cluster_|Franjas"/> </operator> <operator activated="false" class="aggregate" compatibility="8.1.003" expanded="true" height="82" name="Aggregate (5)" width="90" x="179" y="1003"> <list key="aggregation_attributes"> <parameter key="numero_veces_ocupado" value="average"/> </list> <parameter key="group_by_attributes" value="cluster_|fecha_ok"/> </operator> <operator activated="false" class="pivot" compatibility="8.1.003" expanded="true" height="82" name="Dayweek" width="90" x="380" y="1003"> <parameter key="group_attribute" value="cluster_"/> <parameter key="index_attribute" value="fecha_ok"/> </operator> <operator activated="false" class="pivot" compatibility="8.1.003" expanded="true" height="82" name="Franjas (2)" width="90" x="380" y="850"> <parameter key="group_attribute" value="cluster_"/> <parameter key="index_attribute" value="Franjas"/> </operator> <operator activated="false" class="concurrency:join" compatibility="8.1.003" expanded="true" height="82" name="Join (3)" width="90" x="648" y="901"> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="cluster_" value="cluster_"/> </list> </operator> <operator activated="false" class="concurrency:join" compatibility="8.1.003" expanded="true" height="82" name="Join (4)" width="90" x="782" y="1054"> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="cluster_" value="cluster_"/> </list> </operator> <operator activated="false" class="concurrency:join" compatibility="8.1.003" expanded="true" height="82" name="Join (5)" width="90" x="916" y="1207"> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="cluster_" value="cluster_"/> </list> </operator> <operator activated="false" class="replace_missing_values" compatibility="8.1.003" expanded="true" height="103" name="Replace Missing Values (2)" width="90" x="1117" y="1207"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="average(numero_veces_ocupado)_¡Madre!|average(numero_veces_ocupado)_scooby y batman|average(numero_veces_ocupado)_el tamaño si importa|average(numero_veces_ocupado)_YouTube|average(numero_veces_ocupado)_Warriors vs Kings|average(numero_veces_ocupado)_VOD infantil|average(numero_veces_ocupado)_VOD Infantiles|average(numero_veces_ocupado)_Tunein|average(numero_veces_ocupado)_Tiësto - Clublife 500|average(numero_veces_ocupado)_Tijuana vs. UNAM|average(numero_veces_ocupado)_The history of us|average(numero_veces_ocupado)_The Handmaid´s Tale|average(numero_veces_ocupado)_TRIPLE PLAY|average(numero_veces_ocupado)_Soccer Total|average(numero_veces_ocupado)_Rockets vs Cavaliers|average(numero_veces_ocupado)_PRM Nick Play|average(numero_veces_ocupado)_PRM APP MTV|average(numero_veces_ocupado)_PRM AMERICAN CRIME VERSACE TRIVIA|average(numero_veces_ocupado)_Nickelodeon|average(numero_veces_ocupado)_Netflix|average(numero_veces_ocupado)_NCIS|average(numero_veces_ocupado)_Media Center|average(numero_veces_ocupado)_Mas alla de la montaña|average(numero_veces_ocupado)_MTV|average(numero_veces_ocupado)_Liga de la justicia|average(numero_veces_ocupado)_La estrella de Belén|average(numero_veces_ocupado)_La cordillera|average(numero_veces_ocupado)_Juventus vs. Tottenham|average(numero_veces_ocupado)_Jumanji|average(numero_veces_ocupado)_Jigsaw: El Juego Continúa|average(numero_veces_ocupado)_Internet Total|average(numero_veces_ocupado)_IT (ESO)|average(numero_veces_ocupado)_Horoscopos|average(numero_veces_ocupado)_Geo-Tormenta|average(numero_veces_ocupado)_Gamefly|average(numero_veces_ocupado)_GameFly|average(numero_veces_ocupado)_Game fly|average(numero_veces_ocupado)_Game Fly|average(numero_veces_ocupado)_GEO TORMENTA|average(numero_veces_ocupado)_FoxPlay|average(numero_veces_ocupado)_Fox Play|average(numero_veces_ocupado)_FOX V3 Prueba|average(numero_veces_ocupado)_FOX App|average(numero_veces_ocupado)_El rebelde oculto|average(numero_veces_ocupado)_El castillo de cristal|average(numero_veces_ocupado)_Edo de cuenta|average(numero_veces_ocupado)_EMPRESARIAL TRIPLE PLAY|average(numero_veces_ocupado)_Discovery Kids App|average(numero_veces_ocupado)_Discovery Kids|average(numero_veces_ocupado)_Deezer|average(numero_veces_ocupado)_DOBLE PLAY TELEVISION|average(numero_veces_ocupado)_DOBLE PLAY TELEFONIA|average(numero_veces_ocupado)_Crackle|average(numero_veces_ocupado)_Como Cortar a tu patán|average(numero_veces_ocupado)_Comedy Central|average(numero_veces_ocupado)_Coco |average(numero_veces_ocupado)_Coco|average(numero_veces_ocupado)_Clima Mundial|average(numero_veces_ocupado)_Cbeebies|average(numero_veces_ocupado)_CBeebies App|average(numero_veces_ocupado)_Asesinato en el expreso oriente|average(numero_veces_ocupado)"/> <parameter key="default" value="zero"/> <list key="columns"/> </operator> <operator activated="false" class="rename" compatibility="8.1.003" expanded="true" height="82" name="Rename (4)" width="90" x="1251" y="1207"> <parameter key="old_name" value="average(numero_veces_ocupado)_Asesinato en el expreso oriente"/> <parameter key="new_name" value="asesinato en el expreso oriente"/> <list key="rename_additional_attributes"> <parameter key="average(numero_veces_ocupado)_CBeebies App" value="cbeebies app"/> <parameter key="average(numero_veces_ocupado)_Cbeebies" value="cbeebies"/> <parameter key="average(numero_veces_ocupado)_Clima Mundial" value="clima mundial"/> <parameter key="average(numero_veces_ocupado)_Coco" value="coco"/> <parameter key="average(numero_veces_ocupado)_Comedy Central" value="comedy central"/> <parameter key="average(numero_veces_ocupado)_Como Cortar a tu patán" value="como cortar a tu patan"/> <parameter key="average(numero_veces_ocupado)_Crackle" value="crackle"/> <parameter key="average(numero_veces_ocupado)_DOBLE PLAY TELEFONIA" value="doble play telefonia"/> <parameter key="average(numero_veces_ocupado)_DOBLE PLAY TELEVISION" value="doble play television"/> <parameter key="average(numero_veces_ocupado)_Deezer" value="deezer"/> <parameter key="average(numero_veces_ocupado)_Discovery Kids" value="discovery kids"/> <parameter key="average(numero_veces_ocupado)_Discovery Kids App" value="discovery kids app"/> <parameter key="average(numero_veces_ocupado)_EMPRESARIAL TRIPLE PLAY" value="empresarial triple play"/> <parameter key="average(numero_veces_ocupado)_Edo de cuenta" value="estado de cuenta"/> <parameter key="average(numero_veces_ocupado)_El castillo de cristal" value="el castillo de cristal"/> <parameter key="average(numero_veces_ocupado)_El rebelde oculto" value="el rebelde oculto"/> <parameter key="average(numero_veces_ocupado)_FOX App" value="fox app"/> <parameter key="average(numero_veces_ocupado)_FOX V3 Prueba" value="fox v3 prueba"/> <parameter key="average(numero_veces_ocupado)_Fox Play" value="fox play"/> <parameter key="average(numero_veces_ocupado)_GEO TORMENTA" value="geo tormenta"/> <parameter key="average(numero_veces_ocupado)_Horoscopos" value="Horoscopos"/> <parameter key="average(numero_veces_ocupado)_IT (ESO)" value="eso"/> <parameter key="average(numero_veces_ocupado)_Internet Total" value="Internet total"/> <parameter key="average(numero_veces_ocupado)_Jigsaw: El Juego Continúa" value="Jigsaw"/> <parameter key="average(numero_veces_ocupado)_Jumanji" value="Jumanji"/> <parameter key="average(numero_veces_ocupado)_Juventus vs. Tottenham" value="Juventus vs tottenham"/> <parameter key="average(numero_veces_ocupado)_La cordillera" value="la cordillera"/> <parameter key="average(numero_veces_ocupado)_La estrella de Belén" value="la estrella de belen"/> <parameter key="average(numero_veces_ocupado)_Liga de la justicia" value="liga de la justicia"/> <parameter key="average(numero_veces_ocupado)_MTV" value="mtv"/> <parameter key="average(numero_veces_ocupado)_Mas alla de la montaña" value="mas alla de la montaña"/> <parameter key="average(numero_veces_ocupado)_Media Center" value="Media center"/> <parameter key="average(numero_veces_ocupado)_NCIS" value="ncis"/> <parameter key="average(numero_veces_ocupado)_Netflix" value="netflix"/> <parameter key="average(numero_veces_ocupado)_Nickelodeon" value="nick"/> <parameter key="average(numero_veces_ocupado)_PRM AMERICAN CRIME VERSACE TRIVIA" value="prm american crime"/> <parameter key="average(numero_veces_ocupado)_PRM APP MTV" value="prm app mtv"/> <parameter key="average(numero_veces_ocupado)_PRM Nick Play" value="prm nickplay"/> <parameter key="average(numero_veces_ocupado)_Rockets vs Cavaliers" value="rockets vs cavaliers"/> <parameter key="average(numero_veces_ocupado)_Soccer Total" value="soccer total"/> <parameter key="average(numero_veces_ocupado)_TRIPLE PLAY" value="triple play"/> <parameter key="average(numero_veces_ocupado)_The Handmaid´s Tale" value="the handmaids tale"/> <parameter key="average(numero_veces_ocupado)_The history of us" value="the history of us"/> <parameter key="average(numero_veces_ocupado)_Tijuana vs. UNAM" value="tijuana vs unam"/> <parameter key="average(numero_veces_ocupado)_Tiësto - Clublife 500" value="tiesto clublife"/> <parameter key="average(numero_veces_ocupado)_Tunein" value="tunein"/> <parameter key="average(numero_veces_ocupado)_VOD Infantiles" value="vod infantiles"/> <parameter key="average(numero_veces_ocupado)_Warriors vs Kings" value="warriors vs kings"/> <parameter key="average(numero_veces_ocupado)_YouTube" value="youtube"/> <parameter key="average(numero_veces_ocupado)_el tamaño si importa" value="el tamaño si importa"/> <parameter key="average(numero_veces_ocupado)_scooby y batman" value="scooby y batman"/> <parameter key="average(numero_veces_ocupado)_¡Madre!" value="madre"/> <parameter key="average(numero_veces_ocupado)_GameFly" value="Game fly1"/> <parameter key="average(numero_veces_ocupado)_FoxPlay" value="Fox Play"/> <parameter key="average(numero_veces_ocupado)_A" value="A"/> <parameter key="average(numero_veces_ocupado)_AA" value="AA"/> <parameter key="average(numero_veces_ocupado)_AAA" value="AAA"/> <parameter key="average(numero_veces_ocupado)_ON" value="ON"/> <parameter key="average(numero_veces_ocupado)_Entre semana" value="Entre semana"/> <parameter key="average(numero_veces_ocupado)_Fin de semana" value="Fin de semana"/> <parameter key="average(numero_veces_ocupado)_?" value="TBD"/> </list> </operator> <operator activated="false" class="select_attributes" compatibility="8.1.003" expanded="true" height="82" name="Select Attributes (8)" width="90" x="1385" y="1207"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="asesinato en el expreso oriente|Media center|Juventus vs tottenham|Jumanji|Jigsaw|Internet total|Horoscopos|Game fly1|Fox Play|youtube|warriors vs kings|vod infantiles|tunein|triple play|tijuana vs unam|tiesto clublife|the history of us|the handmaids tale|soccer total|scooby y batman|rockets vs cavaliers|prm nickplay|prm app mtv|prm american crime|nick|netflix|ncis|mtv|mas alla de la montaña|madre|liga de la justicia|la estrella de belen|la cordillera|geo tormenta|fox v3 prueba|fox play|fox app|estado de cuenta|eso|empresarial triple play|el tamaño si importa|el rebelde oculto|el castillo de cristal|doble play television|doble play telefonia|discovery kids app|discovery kids|deezer|crackle|como cortar a tu patan|comedy central|coco|cluster_|clima mundial|cbeebies app|cbeebies"/> </operator> <operator activated="false" class="store" compatibility="8.1.003" expanded="true" height="68" name="Store (3)" width="90" x="1586" y="1207"> <parameter key="repository_entry" value="Offline data ok para clusters/VOD_para_cluster"/> </operator> <operator activated="false" class="retrieve" compatibility="8.1.003" expanded="true" height="68" name="Retrieve live-depuracion_snse_pl2" width="90" x="45" y="1564"> <parameter key="repository_entry" value="live-depuracion_snse_pl2"/> </operator> <operator activated="false" class="generate_attributes" compatibility="8.1.003" expanded="true" height="82" name="Generate Attributes (6)" width="90" x="179" y="1564"> <list key="function_descriptions"> <parameter key="ano" value="cut(fecha,0,4)"/> <parameter key="mes" value="cut(fecha,4,2)"/> <parameter key="dia" value="cut(fecha,6,2)"/> <parameter key="ID" value="replace(cuenta,".","")"/> </list> </operator> <operator activated="true" class="map" compatibility="8.1.003" expanded="true" height="82" name="Map (5)" width="90" x="1251" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="fecha_hr_inicio"/> <list key="value_mappings"> <parameter key="1" value="Entre semana"/> <parameter key="2" value="Entre semana"/> <parameter key="3" value="Entre semana"/> <parameter key="4" value="Entre semana"/> <parameter key="5" value="Entre semana"/> <parameter key="6" value="Fin de semana"/> <parameter key="7" value="Fin de semana"/> </list> </operator> <operator activated="true" class="select_attributes" compatibility="8.1.003" expanded="true" height="82" name="Select Attributes (2)" width="90" x="1385" y="34"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="Dur_minutos|Franjas|ID|bda_contract|cambio_prog|dba_genre|fecha_hr_inicio|ID_ok"/> </operator> <operator activated="true" class="rename" compatibility="8.1.003" expanded="true" height="82" name="Rename" width="90" x="1117" y="187"> <parameter key="old_name" value="Dur_minutos"/> <parameter key="new_name" value="Consumo_minutos"/> <list key="rename_additional_attributes"> <parameter key="bda_contract" value="ID_final"/> <parameter key="cambio_prog" value="Cambio_programa"/> <parameter key="dba_genre" value="Genero"/> <parameter key="fecha_hr_inicio" value="Dia semana"/> </list> </operator> <operator activated="true" class="multiply" compatibility="8.1.003" expanded="true" height="124" name="Multiply" width="90" x="45" y="238"/> <operator activated="true" class="aggregate" compatibility="8.1.003" expanded="true" height="82" name="Aggregate (3)" width="90" x="179" y="442"> <list key="aggregation_attributes"> <parameter key="Consumo_minutos" value="maximum"/> </list> <parameter key="group_by_attributes" value="Genero|ID_final"/> </operator> <operator activated="true" class="map" compatibility="8.1.003" expanded="true" height="82" name="Map" width="90" x="313" y="442"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Genero"/> <list key="value_mappings"> <parameter key="Animación" value="Animacion"/> <parameter key="Animacion" value="Animacion"/> <parameter key="Infinity" value="Infinity"/> <parameter key="-Infinity" value="Infinity"/> <parameter key="Deporte" value="Deportes"/> <parameter key="Deportes" value="Deportes"/> <parameter key="Mundo Animal" value="Mundo Animal"/> <parameter key="Reino Animal" value="Mundo Animal"/> </list> </operator> <operator activated="true" class="pivot" compatibility="8.1.003" expanded="true" height="82" name="Genero (2)" width="90" x="447" y="442"> <parameter key="group_attribute" value="ID_final"/> <parameter key="index_attribute" value="Genero"/> <parameter key="skip_constant_attributes" value="false"/> </operator> <operator activated="true" class="aggregate" compatibility="8.1.003" expanded="true" height="82" name="Aggregate" width="90" x="179" y="238"> <list key="aggregation_attributes"> <parameter key="Consumo_minutos" value="maximum"/> </list> <parameter key="group_by_attributes" value="Dia semana|ID_final"/> </operator> <operator activated="true" class="pivot" compatibility="8.1.003" expanded="true" height="82" name="Dayweek (2)" width="90" x="313" y="238"> <parameter key="group_attribute" value="ID_final"/> <parameter key="index_attribute" value="Dia semana"/> <parameter key="skip_constant_attributes" value="false"/> </operator> <operator activated="true" class="aggregate" compatibility="8.1.003" expanded="true" height="82" name="Aggregate (2)" width="90" x="179" y="340"> <list key="aggregation_attributes"> <parameter key="Consumo_minutos" value="maximum"/> </list> <parameter key="group_by_attributes" value="Franjas|ID_final"/> </operator> <operator activated="true" class="pivot" compatibility="8.1.003" expanded="true" height="82" name="Franjas (3)" width="90" x="313" y="340"> <parameter key="group_attribute" value="ID_final"/> <parameter key="index_attribute" value="Franjas"/> <parameter key="skip_constant_attributes" value="false"/> </operator> <operator activated="true" class="concurrency:join" compatibility="8.1.003" expanded="true" height="82" name="Join" width="90" x="581" y="289"> <parameter key="remove_double_attributes" value="false"/> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="ID_final" value="ID_final"/> </list> <parameter key="keep_both_join_attributes" value="true"/> </operator> <operator activated="true" class="concurrency:join" compatibility="8.1.003" expanded="true" height="82" name="Join (2)" width="90" x="648" y="391"> <parameter key="remove_double_attributes" value="false"/> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="ID_final_from_ES2" value="ID_final"/> </list> <parameter key="keep_both_join_attributes" value="true"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="8.1.003" expanded="true" height="103" name="Replace Missing Values" width="90" x="782" y="391"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="regular_expression" value="maximum.+"/> <parameter key="default" value="zero"/> <list key="columns"/> </operator> <operator activated="true" class="rename" compatibility="8.1.003" expanded="true" height="82" name="Rename (2)" width="90" x="916" y="391"> <parameter key="old_name" value="maximum(Consumo_minutos)_Automóviles"/> <parameter key="new_name" value="ANY_Autos"/> <list key="rename_additional_attributes"> <parameter key="maximum(Consumo_minutos)_Accion" value="ANY_Accion"/> <parameter key="maximum(Consumo_minutos)_Adultos" value="ANY_Adultos"/> <parameter key="maximum(Consumo_minutos)_Animacion" value="ANY_Animacion"/> <parameter key="maximum(Consumo_minutos)_Aventura" value="ANY_Aventura"/> <parameter key="maximum(Consumo_minutos)_Baile" value="ANY_Baile"/> <parameter key="maximum(Consumo_minutos)_Belleza" value="ANY_Belleza"/> <parameter key="maximum(Consumo_minutos)_Box" value="ANY_Box"/> <parameter key="maximum(Consumo_minutos)_Caricaturas" value="ANY_Caricaturas"/> <parameter key="maximum(Consumo_minutos)_Ciclismo" value="ANY_Ciclismo"/> <parameter key="maximum(Consumo_minutos)_Ciencia ficcion" value="ANY_Ciencia ficcion"/> <parameter key="maximum(Consumo_minutos)_Cocina" value="ANY_Cocina"/> <parameter key="maximum(Consumo_minutos)_Comedia" value="ANY_Comedia"/> <parameter key="maximum(Consumo_minutos)_Concurso" value="ANY_Concurso"/> <parameter key="maximum(Consumo_minutos)_Crimen" value="ANY_Crimen"/> <parameter key="maximum(Consumo_minutos)_Deportes" value="ANY_Deportes"/> <parameter key="maximum(Consumo_minutos)_Documental" value="ANY_Documental"/> <parameter key="maximum(Consumo_minutos)_Drama" value="ANY_Drama"/> <parameter key="maximum(Consumo_minutos)_Educativo" value="ANY_Educativo"/> <parameter key="maximum(Consumo_minutos)_Entretenimiento" value="ANY_Entretenimiento"/> <parameter key="maximum(Consumo_minutos)_Espectáculos" value="ANY_Espectaculos"/> <parameter key="maximum(Consumo_minutos)_Familiar" value="ANY_Familiar"/> <parameter key="maximum(Consumo_minutos)_Fantasía" value="ANY_Fantasia"/> <parameter key="maximum(Consumo_minutos)_Futbol Soccer" value="ANY_Futbol"/> <parameter key="maximum(Consumo_minutos)_Horror" value="ANY_Horror"/> <parameter key="maximum(Consumo_minutos)_Infantil" value="ANY_Infantil"/> <parameter key="maximum(Consumo_minutos)_Informativo" value="ANY_Informativo"/> <parameter key="maximum(Consumo_minutos)_Investigación" value="ANY_Investigacion"/> <parameter key="maximum(Consumo_minutos)_Lucha Libre" value="ANY_Lucha libre"/> <parameter key="maximum(Consumo_minutos)_Melodrama" value="ANY_Melodrama"/> <parameter key="maximum(Consumo_minutos)_Mundo animal" value="ANY_Mundo animal"/> <parameter key="maximum(Consumo_minutos)_Musical" value="ANY_Musical"/> <parameter key="maximum(Consumo_minutos)_Noticias" value="ANY_Noticias"/> <parameter key="maximum(Consumo_minutos)_Publicidad" value="ANY_Publicidad"/> <parameter key="maximum(Consumo_minutos)_Reality TV" value="ANY_Reality"/> <parameter key="maximum(Consumo_minutos)_Religión" value="ANY_Religion"/> <parameter key="maximum(Consumo_minutos)_Romance" value="ANY_Romance"/> <parameter key="maximum(Consumo_minutos)_Serie Animada" value="ANY_Serie animada"/> <parameter key="maximum(Consumo_minutos)_Serie Infantil" value="ANY_Serie infantil"/> <parameter key="maximum(Consumo_minutos)_Series" value="ANY_Series"/> <parameter key="maximum(Consumo_minutos)_Suspenso" value="ANY_Suspenso"/> <parameter key="maximum(Consumo_minutos)_Terror" value="ANY_Terror"/> <parameter key="maximum(Consumo_minutos)_Tv-show" value="ANY_Show"/> <parameter key="maximum(Consumo_minutos)_Fin de semana" value="ANY_FS"/> <parameter key="maximum(Consumo_minutos)_Entre semana" value="ANY_ES"/> <parameter key="maximum(Consumo_minutos)_AAA" value="ANY_AAA"/> <parameter key="maximum(Consumo_minutos)_AA" value="ANY_AA"/> <parameter key="maximum(Consumo_minutos)_AAA" value="ANY_A"/> <parameter key="maximum(Consumo_minutos)_ON" value="ANY_ON"/> </list> </operator> <operator activated="true" class="set_role" compatibility="8.1.003" expanded="true" height="82" name="Set Role (4)" width="90" x="1050" y="391"> <parameter key="attribute_name" value="ID_final"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"> <parameter key="ID_final_from_ES2" value="id"/> <parameter key="ID_final_from_ES2_from_ES2" value="id"/> </list> </operator> <operator activated="true" class="store" compatibility="8.1.003" expanded="true" height="68" name="Store (4)" width="90" x="1184" y="391"> <parameter key="repository_entry" value="Offline data ok para clusters/any_para_cluster"/> </operator> <operator activated="false" class="retrieve" compatibility="8.1.003" expanded="true" height="68" name="Retrieve TP_Cartera_Clientes_20180503" width="90" x="45" y="2380"> <parameter key="repository_entry" value="TP_cartera_sample"/> </operator> <operator activated="false" class="select_attributes" compatibility="8.1.003" expanded="true" height="82" name="Select Attributes (5)" width="90" x="179" y="2380"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="CUENTA|RENTA|RENTA_ADICIONAL|SALDO_SERV|SCORE|SEGMENTO|SEGMENTO_ATRASO|SEMANAS_ATRASO|SERVICIOS_ACTIVOS|SERVICIOS_DESACTIVOS|TOTAL_CARTERA"/> </operator> <operator activated="false" class="numerical_to_polynominal" compatibility="8.1.003" expanded="true" height="82" name="Numerical to Polynominal (3)" width="90" x="313" y="2380"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="CUENTA"/> </operator> <operator activated="false" class="generate_attributes" compatibility="8.1.003" expanded="true" height="82" name="Generate Attributes (16)" width="90" x="447" y="2380"> <list key="function_descriptions"> <parameter key="ID" value="replace(CUENTA,".","")"/> <parameter key="ID_ok" value="if(length(ID)==9,concat("0",ID),ID)"/> </list> </operator> <operator activated="false" class="multiply" compatibility="8.1.003" expanded="true" height="208" name="Multiply (4)" width="90" x="715" y="2380"/> <operator activated="false" class="aggregate" compatibility="8.1.003" expanded="true" height="82" name="Servicios desactivados (2)" width="90" x="916" y="2992"> <list key="aggregation_attributes"> <parameter key="TOTAL_CARTERA" value="maximum"/> </list> <parameter key="group_by_attributes" value="ID_ok"/> </operator> <operator activated="false" class="aggregate" compatibility="8.1.003" expanded="true" height="82" name="Servicios desactivados" width="90" x="916" y="2890"> <list key="aggregation_attributes"> <parameter key="SERVICIOS_DESACTIVOS" value="maximum"/> </list> <parameter key="group_by_attributes" value="SERVICIOS_DESACTIVOS|ID_ok"/> </operator> <operator activated="false" class="pivot" compatibility="8.1.003" expanded="true" height="82" name="Pivot (3)" width="90" x="1050" y="2890"> <parameter key="group_attribute" value="ID_ok"/> <parameter key="index_attribute" value="SERVICIOS_DESACTIVOS"/> </operator> <operator activated="false" class="aggregate" compatibility="8.1.003" expanded="true" height="82" name="Servicios activos" width="90" x="916" y="2788"> <list key="aggregation_attributes"> <parameter key="SERVICIOS_ACTIVOS" value="maximum"/> </list> <parameter key="group_by_attributes" value="SERVICIOS_ACTIVOS|ID_ok"/> </operator> <operator activated="false" class="pivot" compatibility="8.1.003" expanded="true" height="82" name="Pivot (2)" width="90" x="1050" y="2788"> <parameter key="group_attribute" value="ID_ok"/> <parameter key="index_attribute" value="SERVICIOS_ACTIVOS"/> </operator> <operator activated="false" class="aggregate" compatibility="8.1.003" expanded="true" height="82" name="Segmento atraso" width="90" x="916" y="2686"> <list key="aggregation_attributes"> <parameter key="SEGMENTO_ATRASO" value="count"/> </list> <parameter key="group_by_attributes" value="SEGMENTO_ATRASO|ID_ok"/> </operator> <operator activated="false" class="pivot" compatibility="8.1.003" expanded="true" height="82" name="Pivot" width="90" x="1050" y="2686"> <parameter key="group_attribute" value="ID_ok"/> <parameter key="index_attribute" value="SEGMENTO_ATRASO"/> </operator> <operator activated="false" class="aggregate" compatibility="8.1.003" expanded="true" height="82" name="Score" width="90" x="916" y="2584"> <list key="aggregation_attributes"> <parameter key="SCORE" value="maximum"/> </list> <parameter key="group_by_attributes" value="RENTA|ID_ok"/> </operator> <operator activated="false" class="aggregate" compatibility="8.1.003" expanded="true" height="82" name="Saldo servicio" width="90" x="916" y="2482"> <list key="aggregation_attributes"> <parameter key="SALDO_SERV" value="maximum"/> </list> <parameter key="group_by_attributes" value="RENTA|ID_ok"/> </operator> <operator activated="false" class="aggregate" compatibility="8.1.003" expanded="true" height="82" name="Renta Adicional" width="90" x="916" y="2380"> <list key="aggregation_attributes"> <parameter key="RENTA_ADICIONAL" value="maximum"/> </list> <parameter key="group_by_attributes" value="RENTA|ID_ok"/> </operator> <operator activated="false" class="concurrency:join" compatibility="8.1.003" expanded="true" height="82" name="Join (9)" width="90" x="1117" y="2380"> <parameter key="remove_double_attributes" value="false"/> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="ID_ok" value="ID_ok"/> </list> <parameter key="keep_both_join_attributes" value="true"/> </operator> <operator activated="false" class="concurrency:join" compatibility="8.1.003" expanded="true" height="82" name="Join (10)" width="90" x="1251" y="2533"> <parameter key="remove_double_attributes" value="false"/> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="ID_ok_from_ES2" value="ID_ok"/> </list> <parameter key="keep_both_join_attributes" value="true"/> </operator> <operator activated="false" class="concurrency:join" compatibility="8.1.003" expanded="true" height="82" name="Join (11)" width="90" x="1318" y="2686"> <parameter key="remove_double_attributes" value="false"/> <parameter key="join_type" value="left"/> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="ID_ok_from_ES2_from_ES2" value="ID_ok"/> </list> <parameter key="keep_both_join_attributes" value="true"/> </operator> <operator activated="false" class="concurrency:join" compatibility="8.1.003" expanded="true" height="82" name="Join (12)" width="90" x="1452" y="2788"> <parameter key="remove_double_attributes" value="false"/> <parameter key="join_type" value="left"/> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="ID_ok_from_ES2_from_ES2_from_ES2" value="ID_ok"/> </list> <parameter key="keep_both_join_attributes" value="true"/> </operator> <operator activated="false" class="concurrency:join" compatibility="8.1.003" expanded="true" height="82" name="Join (13)" width="90" x="1519" y="2890"> <parameter key="remove_double_attributes" value="false"/> <parameter key="join_type" value="left"/> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="ID_ok_from_ES2_from_ES2_from_ES2_from_ES2" value="ID_ok"/> </list> <parameter key="keep_both_join_attributes" value="true"/> </operator> <operator activated="false" class="concurrency:join" compatibility="8.1.003" expanded="true" height="82" name="Join (14)" width="90" x="1653" y="2992"> <parameter key="remove_double_attributes" value="false"/> <parameter key="join_type" value="left"/> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="ID_ok_from_ES2_from_ES2_from_ES2_from_ES2_from_ES2" value="ID_ok"/> </list> <parameter key="keep_both_join_attributes" value="true"/> </operator> <operator activated="false" class="retrieve" compatibility="8.1.003" expanded="true" height="68" name="Retrieve base_usuarios_201817" width="90" x="45" y="3247"> <parameter key="repository_entry" value="base_usuarios_201817"/> </operator> <operator activated="false" class="rename" compatibility="8.1.003" expanded="true" height="82" name="Rename (5)" width="90" x="179" y="3247"> <parameter key="old_name" value="col0"/> <parameter key="new_name" value="Origen"/> <list key="rename_additional_attributes"> <parameter key="col3" value="Cuenta"/> <parameter key="col4" value="Cliente desde"/> <parameter key="col5" value="Cuenta cerrada"/> <parameter key="col6" value="TBD"/> <parameter key="col7" value="Estado cuenta"/> <parameter key="col8" value="Detalle estado"/> <parameter key="col10" value="Plan"/> <parameter key="col12" value="Estado Mexico"/> <parameter key="col15" value="Credito a favor"/> </list> </operator> <operator activated="false" class="select_attributes" compatibility="8.1.003" expanded="true" height="82" name="Select Attributes (6)" width="90" x="313" y="3247"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="Cliente desde|Credito a favor|Cuenta|Cuenta cerrada|Detalle estado|Estado Mexico|Estado cuenta|Origen|Plan|TBD"/> </operator> <operator activated="false" class="nominal_to_date" compatibility="8.1.003" expanded="true" height="82" name="Nominal to Date (4)" width="90" x="447" y="3247"> <parameter key="attribute_name" value="Cliente desde"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> </operator> <operator activated="false" class="replace" compatibility="8.1.003" expanded="true" height="82" name="Replace" width="90" x="581" y="3247"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Cuenta cerrada"/> <parameter key="replace_what" value="NULL"/> <parameter key="replace_by" value="2018-05-29 00:00:00.000"/> </operator> <operator activated="false" class="nominal_to_date" compatibility="8.1.003" expanded="true" height="82" name="Nominal to Date (5)" width="90" x="715" y="3247"> <parameter key="attribute_name" value="Cuenta cerrada"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> </operator> <operator activated="false" class="aggregate" compatibility="8.1.003" expanded="true" height="82" name="Estados de mexico" width="90" x="313" y="3910"> <list key="aggregation_attributes"> <parameter key="Rangos_duracion_cuenta_ok" value="count"/> </list> <parameter key="group_by_attributes" value="Cuenta|Estado Mexico"/> </operator> <operator activated="false" class="pivot" compatibility="8.1.003" expanded="true" height="82" name="Pivot (9)" width="90" x="447" y="3910"> <parameter key="group_attribute" value="Cuenta"/> <parameter key="index_attribute" value="Estado Mexico"/> </operator> <operator activated="false" class="generate_attributes" compatibility="8.1.003" expanded="true" height="82" name="Generate Attributes (15)" width="90" x="313" y="1564"> <list key="function_descriptions"> <parameter key="ID_ok" value="if(length(ID)==9,concat("0",ID),ID)"/> </list> </operator> <operator activated="false" class="generate_attributes" compatibility="8.1.003" expanded="true" height="82" name="Generate Attributes (7)" width="90" x="447" y="1564"> <list key="function_descriptions"> <parameter key="fecha_ok" value="concat(mes,"/",dia,"/",ano)"/> </list> </operator> <operator activated="false" class="nominal_to_date" compatibility="8.1.003" expanded="true" height="82" name="Nominal to Date (3)" width="90" x="581" y="1564"> <parameter key="attribute_name" value="fecha_ok"/> <parameter key="date_format" value="MM/dd/yyyy"/> </operator> <operator activated="false" class="date_to_numerical" compatibility="8.1.003" expanded="true" height="82" name="Date to Numerical (3)" width="90" x="715" y="1564"> <parameter key="attribute_name" value="fecha_ok"/> <parameter key="time_unit" value="day"/> <parameter key="day_relative_to" value="week"/> </operator> <operator activated="false" class="numerical_to_polynominal" compatibility="8.1.003" expanded="true" height="82" name="Numerical to Polynominal (2)" width="90" x="849" y="1564"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="fecha_ok"/> </operator> <operator activated="false" class="map" compatibility="8.1.003" expanded="true" height="82" name="Map (3)" width="90" x="983" y="1564"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="fecha_ok"/> <list key="value_mappings"> <parameter key="1" value="Entre semana"/> <parameter key="2" value="Entre semana"/> <parameter key="3" value="Entre semana"/> <parameter key="4" value="Entre semana"/> <parameter key="5" value="Entre semana"/> <parameter key="6" value="Fin de semana"/> <parameter key="7" value="Fin de semana"/> </list> </operator> <operator activated="false" class="generate_attributes" compatibility="8.1.003" expanded="true" height="82" name="Generate Attributes (8)" width="90" x="1117" y="1564"> <list key="function_descriptions"> <parameter key="Franjas" value="if(hora_inicio_1>=6 && hora_inicio_1<12,"A",if(hora_inicio_1>=12 && hora_inicio_1<18,"AA",if(hora_inicio_1>=18 && hora_inicio_1<24,"AAA","ON")))"/> <parameter key="Duracion_ok" value="duracion/60"/> </list> </operator> <operator activated="false" class="select_attributes" compatibility="8.1.003" expanded="true" height="82" name="Select Attributes (4)" width="90" x="1251" y="1564"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="Duracion_ok|Franjas|canal|fecha_ok|genero|programa|ID_ok"/> </operator> <operator activated="false" class="set_role" compatibility="8.1.003" expanded="true" height="82" name="Set Role" width="90" x="1385" y="1564"> <parameter key="attribute_name" value="ID_ok"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="false" class="multiply" compatibility="8.1.003" expanded="true" height="124" name="Multiply (3)" width="90" x="45" y="1768"/> <operator activated="false" class="aggregate" compatibility="8.1.003" expanded="true" height="82" name="Aggregate (11)" width="90" x="179" y="2176"> <list key="aggregation_attributes"> <parameter key="Duracion_ok" value="maximum"/> </list> <parameter key="group_by_attributes" value="genero|ID_ok"/> </operator> <operator activated="false" class="pivot" compatibility="8.1.003" expanded="true" height="82" name="Genero" width="90" x="380" y="2176"> <parameter key="group_attribute" value="ID_ok"/> <parameter key="index_attribute" value="genero"/> <parameter key="skip_constant_attributes" value="false"/> </operator> <operator activated="false" class="aggregate" compatibility="8.1.003" expanded="true" height="82" name="Aggregate (10)" width="90" x="179" y="2023"> <list key="aggregation_attributes"> <parameter key="Duracion_ok" value="maximum"/> </list> <parameter key="group_by_attributes" value="fecha_ok|ID_ok"/> </operator> <operator activated="false" class="pivot" compatibility="8.1.003" expanded="true" height="82" name="Dia semana" width="90" x="380" y="2023"> <parameter key="group_attribute" value="ID_ok"/> <parameter key="index_attribute" value="fecha_ok"/> <parameter key="skip_constant_attributes" value="false"/> </operator> <operator activated="false" class="aggregate" compatibility="8.1.003" expanded="true" height="82" name="Aggregate (8)" width="90" x="179" y="1717"> <list key="aggregation_attributes"> <parameter key="Duracion_ok" value="maximum"/> </list> <parameter key="group_by_attributes" value="Franjas|ID_ok"/> </operator> <operator activated="false" class="pivot" compatibility="8.1.003" expanded="true" height="82" name="Franjas" width="90" x="380" y="1717"> <parameter key="group_attribute" value="ID_ok"/> <parameter key="index_attribute" value="Franjas"/> <parameter key="skip_constant_attributes" value="false"/> </operator> <operator activated="false" class="concurrency:join" compatibility="8.1.003" expanded="true" height="82" name="Join (7)" width="90" x="849" y="1921"> <parameter key="remove_double_attributes" value="false"/> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="ID_ok" value="ID_ok"/> </list> <parameter key="keep_both_join_attributes" value="true"/> </operator> <operator activated="false" class="concurrency:join" compatibility="8.1.003" expanded="true" height="82" name="Join (8)" width="90" x="1050" y="2074"> <parameter key="remove_double_attributes" value="false"/> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="ID_ok_from_ES2" value="ID_ok"/> </list> <parameter key="keep_both_join_attributes" value="true"/> </operator> <operator activated="false" class="replace_missing_values" compatibility="8.1.003" expanded="true" height="103" name="Replace Missing Values (3)" width="90" x="1184" y="2074"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="regular_expression" value="maximum.+"/> <parameter key="default" value="zero"/> <list key="columns"/> </operator> <operator activated="false" class="store" compatibility="8.1.003" expanded="true" height="68" name="Store (2)" width="90" x="1452" y="2074"> <parameter key="repository_entry" value="Offline data ok para clusters/VOD_para_cluster"/> </operator> <operator activated="false" class="numerical_to_polynominal" compatibility="8.1.003" expanded="true" height="82" name="Numerical to Polynominal (5)" width="90" x="849" y="3247"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Cuenta"/> </operator> <operator activated="false" class="generate_attributes" compatibility="8.1.003" expanded="true" height="82" name="Generate Attributes (9)" width="90" x="983" y="3247"> <list key="function_descriptions"> <parameter key="ID" value="replace(Cuenta,".","")"/> <parameter key="ID_ok" value="if(length(ID)==9,concat("0",ID),ID)"/> </list> </operator> <operator activated="false" class="generate_attributes" compatibility="8.1.003" expanded="true" height="82" name="Duracion cuenta cerrada" width="90" x="1117" y="3247"> <list key="function_descriptions"> <parameter key="Duracion_cuenta_cerrada" value="if(missing([Cuenta cerrada]),date_diff([Cliente desde],date_now()),date_diff([Cliente desde],[Cuenta cerrada]))"/> </list> </operator> <operator activated="false" class="generate_attributes" compatibility="8.1.003" expanded="true" height="82" name="Generate Attributes (10)" width="90" x="1251" y="3247"> <list key="function_descriptions"> <parameter key="Duracion_cuenta_años" value="Duracion_cuenta_cerrada/31536000000"/> </list> </operator> <operator activated="false" class="generate_attributes" compatibility="8.1.003" expanded="true" height="82" name="Generate Attributes (11)" width="90" x="1385" y="3247"> <list key="function_descriptions"> <parameter key="Rangos_duracion_cuenta" value="if([Duracion_cuenta_años]>=0 && [Duracion_cuenta_años] <0.5,"0.5 años",if([Duracion_cuenta_años]>=0.5 && [Duracion_cuenta_años] <1,"0.5-1 años",if([Duracion_cuenta_años]>=1 && [Duracion_cuenta_años] <1.5,"1-1.5 años",if([Duracion_cuenta_años]>=1.5 && [Duracion_cuenta_años] <2,"1.5-2 años",if([Duracion_cuenta_años]>=2 && [Duracion_cuenta_años] <2.5,"2-2.5 años",if([Duracion_cuenta_años]>=2.5 && [Duracion_cuenta_años] <3,"2.5-3 años",if([Duracion_cuenta_años]>=3 && [Duracion_cuenta_años] <3.5,"3-3.5 años",if([Duracion_cuenta_años]>=3.5 && [Duracion_cuenta_años] <4,"3.5-4 años",if([Duracion_cuenta_años]>=4 && [Duracion_cuenta_años] <4.5,"4-4.5 años",if([Duracion_cuenta_años]>=4.5 && [Duracion_cuenta_años] <5,"4.5-5 años","+ 5 años"))))))))))"/> </list> </operator> <operator activated="false" class="date_to_nominal" compatibility="8.1.003" expanded="true" height="82" name="Date to Nominal" width="90" x="1519" y="3247"> <parameter key="attribute_name" value="Cuenta cerrada"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> </operator> <operator activated="false" class="replace" compatibility="8.1.003" expanded="true" height="82" name="Replace (2)" width="90" x="1653" y="3247"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Cuenta cerrada"/> <parameter key="replace_what" value="2018-05-29 00:00:00.000"/> <parameter key="replace_by" value="NULL"/> </operator> <operator activated="false" class="generate_attributes" compatibility="8.1.003" expanded="true" height="82" name="Generate Attributes (12)" width="90" x="1787" y="3247"> <list key="function_descriptions"> <parameter key="Rangos_duracion_cuenta_ok" value="if([Estado cuenta]=="ACTIVO","Activa",Rangos_duracion_cuenta)"/> </list> </operator> <operator activated="false" class="generate_attributes" compatibility="8.1.003" expanded="true" height="82" name="Generate Attributes (13)" width="90" x="1921" y="3247"> <list key="function_descriptions"> <parameter key="Mes_de_cierre" value="cut([Cuenta cerrada],5,2)"/> </list> </operator> <operator activated="false" class="select_attributes" compatibility="8.1.003" expanded="true" height="82" name="Select Attributes (7)" width="90" x="45" y="3400"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="Credito a favor|Detalle estado|Estado Mexico|Estado cuenta|Mes_de_cierre|Origen|Plan|Rangos_duracion_cuenta_ok|ID_ok"/> </operator> <operator activated="false" class="multiply" compatibility="8.1.003" expanded="true" height="166" name="Multiply (5)" width="90" x="179" y="3400"/> <operator activated="false" class="aggregate" compatibility="8.1.003" expanded="true" height="82" name="Rangos duracion" width="90" x="313" y="3808"> <list key="aggregation_attributes"> <parameter key="Rangos_duracion_cuenta_ok" value="count"/> </list> <parameter key="group_by_attributes" value="Rangos_duracion_cuenta_ok|ID_ok"/> </operator> <operator activated="false" class="pivot" compatibility="8.1.003" expanded="true" height="82" name="Pivot (8)" width="90" x="447" y="3808"> <parameter key="group_attribute" value="ID_ok"/> <parameter key="index_attribute" value="Rangos_duracion_cuenta_ok"/> </operator> <operator activated="false" c
Not really an answer to your problem, but you can also use the rename by replaceming operator. This way you can use a regex to replace all your new names with the short one. Just replace maximum(Consumo_minutos)_ with ANY, and all matching columns are replaced at the same time. Easier than keeping track of all your possible options...
to share your data file you can :
- create a zip archive and share here in the forum.
OR
- post your file on a cloud repository (Google Drive for example) and share the link.
Ok, here in zip
thks
Thank you Lionel
