Multilogit in R - Model Application fails
New Altair Community Member
Updated by Jocelyn
Alright guys, I'm running into an error using R. I'm attaching a sample process, I can't post the actual data but it's similar to the data below.
I'm using the Mlogit package in R and I can build a model just fine. When I try to apply the model to new data, I get an application error (see screenshot below). There is a predict function in the package but I'm wondering if I need to fit the model first in the Apply stage? I was under impression that I don't need to.
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.1.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="generate_data" compatibility="8.1.001" expanded="true" height="68" name="Generate Data" width="90" x="45" y="34">
<parameter key="target_function" value="random classification"/>
<operator activated="true" class="generate_id" compatibility="8.1.001" expanded="true" height="82" name="Generate ID" width="90" x="179" y="34"/>
<operator activated="true" class="split_data" compatibility="8.1.001" expanded="true" height="103" name="Split Data" width="90" x="246" y="187">
<enumeration key="partitions">
<parameter key="ratio" value="0.7"/>
<parameter key="ratio" value="0.3"/>
</enumeration>
<operator activated="true" class="r_scripting:execute_r" compatibility="8.1.000" expanded="true" height="82" name="Execute Mlogit Model" width="90" x="447" y="34">
<parameter key="script" value="library(mlogit) rm_main = function(data) { 	# print the meta data 	print(metaData) 	# access the meta data for every entry 	for(i in seq(along=metaData$data)) { 	print(paste("type of", names(metaData$data)[i], "in the original example set:", metaData$data[[i]]$type)) 	print(paste("role of", names(metaData$data)[i], "in the original example set:", metaData$data[[i]]$role)) } 	data$id <- as.factor(data$id) 	data$label <- as.logical(data$label) 	 	mModel <- mlogit.data(formula = label, data = data, alt.var="id", shape= "long") 	 	return(mModel) } "/>
<operator activated="true" class="r_scripting:execute_r" compatibility="8.1.000" expanded="true" height="103" name="Apply Mlogit Model" width="90" x="648" y="187">
<parameter key="script" value="library(mlogit) rm_main = function(mModel, data) {		 	# print the meta data 	print(metaData) 	# access the meta data for every entry 	for(i in seq(along=metaData$data)) { 	print(paste("type of", names(metaData$data)[i], "in the original example set:", metaData$data[[i]]$type)) 	print(paste("role of", names(metaData$data)[i], "in the original example set:", metaData$data[[i]]$role)) } 	data$id <- as.factor(data$id) 	 	newM <- mlogit.data(data, alt.var="id", shape ="long") 	 	result <-predict(mModel,newdata=newM) 	#result <- predict(mModel, data) 	data$prediction <- result 	 	metaData$data$prediction <<- list(type="real", role="prediction") 	 	return(data) 	 }"/>
<connect from_op="Generate Data" from_port="output" to_op="Generate ID" to_port="example set input"/>
<connect from_op="Generate ID" from_port="example set output" to_op="Split Data" to_port="example set"/>
<connect from_op="Split Data" from_port="partition 1" to_op="Execute Mlogit Model" to_port="input 1"/>
<connect from_op="Split Data" from_port="partition 2" to_op="Apply Mlogit Model" to_port="input 2"/>
<connect from_op="Execute Mlogit Model" from_port="output 1" to_op="Apply Mlogit Model" to_port="input 1"/>
<connect from_op="Apply Mlogit Model" from_port="output 1" to_port="result 1"/>
</process>
</process>
Thoughts on this? Maybe R experts @yyhuang and @Telcontar120 have a clue?
1 - 2 of
21
@SGolbert ah, i see. So when I change mlogit.data to just mlogit I get an "object 'label'" not found. I might have to convert the binominal to an integer.
Hi Tom,
you picked my curiosity and I've read the vignette on the mlogit package:
Therefore mlogit.data returns a data frame, not a model.
Sebastian
