I want to do cluster modelling in different hive tables but I dont know if this in possible, in case it is, could someone please tell me how?
thanks
Yes.... and No. :smileylol:
Currently Automodel cannot be used on Hive datasets directly (you can extract some data out though and use it with Read Hive operators).
However, the processes that you create with Automodel can be used on Hive datasets with RapidMiner Radoop.
And, as you get more experienced with RapidMiner Studio & Radoop you can build very advanced processes that automate all the things you would like to do.
With RapidMiner Server you can even build an webApp interface that will enable you to customize easily.
