I am able to import hm. But import hm.entities is not callable.
Hi Shubham,
We are introducing Python API in HyperMesh client in version 2024.0 (due to be available soon), hence you are seeing an error when trying to import hm.entities in 2023.1.
In version 2023.1, we completed the first phase of Python API for HyperView and HyperGraph clients.
Best regards,Michal StefucaAutomation & Customization
Even I am facing this issue. When is it going to be resolved? version: 2024.1
Hi @Shanmukh_Kancherla
The hm modules can be imported only within the HyperMesh application. If you are writing your code in VS Code, you can take advantage of the HyperWorksPyAPI - Visual Studio Marketplace extension, but it will only provide syntax recognition, auto-completion, and docstrings for some classes/methods. The code itself will not run in a standalone Python interpreter, you will need to execute it inside HyperMesh.
Thanks,
Micha Stefuca Automation & Customization
