Loop model multiple times and record each individual outcome seperately
SHSguy
SHSguy New Altair Community Member
Would like to run a model n-amount of times and record the results of each individual loop separately.
However, when I try to do implement the model, please refer to the figure, it only saves one model run. Additionally, I would like to add an attribute that would identify which model run it is referring too?
Please, no scripts if it can be avoided :)
Thank you
Best Answer
  • MartinLiebig
    MartinLiebig
    Answer ✓
    Hi @SHSguy,
    the trick you need to know is macros. Just use as a filepath for Write Excel something like
    /Users/Martin/Results/MyFile %{a}.xlsx
    %{a} will be replaced with the iteration of the loop. You can also use the macros which are provided by the loop itself (e.g. %{iteration})
    Best,
    Martin
  • Thomas_Ott
    @SHSguy Wasn't this posted somewhere in the threads? Is this a duplicate?  Did you post your process and data set?
  • SHSguy
    Hi Thomas,
    The thread searches both manually and automated (on Rapidminer and Google) produced no indication of an existing one. Unless you have access to another search methodology besides reading each and every thread ever posted. There was also no mention of it on YouTube as could be identified via the YouTube search. Personally, and similarly to the Google and Rapidminer options I prefer to avoid manually reading/watching every thread or video ever produced.  If I did find a similar mention of it which resulted in a positive outcome in relation to my needs I would have avoided generating the graph affixed to my query and the compilation of the question and would have just implemented the provided solution.
  • SHSguy
    In addition, University guidelines prohibit me from sharing datasets publicly. The graph serves as the RM guide I have been utilizing.
  • Thomas_Ott
    @SHSguy the reason I say this is because the image you posted is eeirly similar to the image from here: https://community.rapidminer.com/t5/Getting-Started-Forum/Network-model/td-p/49561
    Ok, no data set. Then how about posting the process with some 'fake data' then?
  • MartinLiebig
    MartinLiebig
    Answer ✓
    Hi @SHSguy,
    Best,
    Martin
  • SHSguy
    Same process, the same person asking the question, different question.
  • SHSguy
    Hi Martin,
    Thank you for the advice, will definitely give it a try.
