Happy Friday RM team!
I have the following issue: I run LDA Topic Modeling process and able to get Topics Description using Top output (words for topics) of LDA process. I'm also able to save generated LDA model. However, once I apply this LDA model on set of new documents, I have no idea which topics mean what. I suspect that Topic IDs are not the same between my original topics description coming from LDA process to generate the model and topic ids that are generated after model application on new documents set. Can you please clarify? Is it possible to have same topic ids generated? I'm also using reproducible and random seed option when model is generated during original LDA process. Thanks!
