Hi, Rapidminer community,
For a university project, I'm working on Transfer Learning. So, I build a model that learns from a source dataset (amazon text reviews with a star rating) and uses this knowledge to predict the stars on the target dataset but also combine information from the source and target to optimize the predictions and reduce the dimensionality with the SVD operator.
In the code that I added, there are 3 SVD's, one for the source, one for the target training and one for target testing. I'm not sure how to connect the pre(processing models) connections. In the code example I added a few apply model's. But this gives the error "Wrong number of attributes, operator expects a fixed number of attributes (100), the actual number was 100".
I also tried to add an extra 'group models' and combine the SVD preprocess models but didn't work either.
Who can help me?
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.003">
<operator activated="true" class="read_csv" compatibility="8.1.000" expanded="true" height="68" name="Read Health&PC" width="90" x="514" y="136">
<parameter key="csv_file" value="F:\CloudStation\Studie Mikael\VAF\DATA\amahpc-right-10k.csv"/>
<parameter key="column_separators" value=";"/>
<parameter key="trim_lines" value="false"/>
<parameter key="use_quotes" value="true"/>
<parameter key="quotes_character" value="""/>
<parameter key="escape_character" value="\"/>
<parameter key="skip_comments" value="false"/>
<parameter key="comment_characters" value="#"/>
<parameter key="parse_numbers" value="true"/>
<parameter key="decimal_character" value="."/>
<parameter key="grouped_digits" value="false"/>
<parameter key="grouping_character" value=","/>
<parameter key="date_format" value=""/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="locale" value="English (United States)"/>
<parameter key="encoding" value="windows-1252"/>
<parameter key="read_all_values_as_polynominal" value="false"/>
<parameter key="0" value="att1.true.real.attribute"/>
<parameter key="1" value="asin.true.polynominal.attribute"/>
<parameter key="2" value="reviewerName.true.polynominal.attribute"/>
<parameter key="3" value="helpful.true.real.attribute"/>
<parameter key="4" value="reviewText.true.polynominal.attribute"/>
<parameter key="5" value="overall.true.polynominal.attribute"/>
<parameter key="6" value="summary.true.polynominal.attribute"/>
<parameter key="7" value="unixReviewTime.true.real.attribute"/>
<parameter key="8" value="reviewTime.true.polynominal.attribute"/>
<parameter key="9" value="X1.true.real.attribute"/>
<parameter key="10" value="X2.true.real.attribute"/>
</list>
<parameter key="read_not_matching_values_as_missings" value="true"/>
<parameter key="datamanagement" value="double_array"/>
<parameter key="data_management" value="auto"/>
</process>
<operator activated="true" class="subprocess" compatibility="8.1.003" expanded="true" height="82" name="Pre-processing" width="90" x="648" y="136">
<process expanded="true">
<operator activated="true" class="replace" compatibility="8.1.003" expanded="true" height="82" name="Replace 1.0 > negative" width="90" x="179" y="34">
<parameter key="attribute" value="overall"/>
<parameter key="value_type" value="nominal"/>
<parameter key="except_value_type" value="file_path"/>
<parameter key="block_type" value="single_value"/>
<parameter key="except_block_type" value="single_value"/>
<parameter key="replace_what" value="1.0"/>
<parameter key="replace_by" value="negative"/>
<operator activated="true" class="replace" compatibility="8.1.003" expanded="true" height="82" name="Replace 2.0 > negative" width="90" x="313" y="34">
<parameter key="replace_what" value="2.0"/>
<operator activated="true" class="replace" compatibility="8.1.003" expanded="true" height="82" name="Replace 3.0 > neutral" width="90" x="447" y="34">
<parameter key="replace_what" value="3.0"/>
<parameter key="replace_by" value="neutral"/>
<operator activated="true" class="replace" compatibility="8.1.003" expanded="true" height="82" name="Replace 4.0 > positive" width="90" x="581" y="34">
<parameter key="replace_what" value="4.0"/>
<parameter key="replace_by" value="positive"/>
<operator activated="true" class="replace" compatibility="8.1.003" expanded="true" height="82" name="Replace 5.0 > positive" width="90" x="715" y="34">
<parameter key="replace_what" value="5.0"/>
<operator activated="true" class="select_attributes" compatibility="8.1.003" expanded="true" height="82" name="Select Attributes" width="90" x="380" y="136">
<parameter key="attribute" value=""/>
<parameter key="attributes" value="reviewText|overall"/>
<operator activated="true" class="declare_missing_value" compatibility="8.1.003" expanded="true" height="82" name="Declare Missing Value" width="90" x="514" y="136">
<parameter key="attribute_filter_type" value="all"/>
<parameter key="mode" value="nominal"/>
<parameter key="nominal_value" value="?"/>
<parameter key="expression_value" value=""/>
<operator activated="true" class="filter_examples" compatibility="8.1.003" expanded="true" height="103" name="Filter Examples" width="90" x="648" y="136">
<parameter key="parameter_expression" value=""/>
<parameter key="condition_class" value="custom_filters"/>
<parameter key="invert_filter" value="true"/>
<list key="filters_list">
<parameter key="filters_entry_key" value="overall.is_missing."/>
<parameter key="filters_entry_key" value="reviewText.is_missing."/>
</list>
<parameter key="filters_logic_and" value="true"/>
<parameter key="filters_check_metadata" value="true"/>
<operator activated="true" class="set_role" compatibility="8.1.003" expanded="true" height="82" name="Set Role" width="90" x="782" y="136">
<parameter key="attribute_name" value="overall"/>
<operator activated="true" class="nominal_to_text" compatibility="8.1.003" expanded="true" height="82" name="Nominal to Text" width="90" x="916" y="136">
<parameter key="attribute" value="reviewText"/>
<connect from_port="in 1" to_op="Replace 1.0 > negative" to_port="example set input"/>
<connect from_op="Replace 1.0 > negative" from_port="example set output" to_op="Replace 2.0 > negative" to_port="example set input"/>
<connect from_op="Replace 2.0 > negative" from_port="example set output" to_op="Replace 3.0 > neutral" to_port="example set input"/>
<connect from_op="Replace 3.0 > neutral" from_port="example set output" to_op="Replace 4.0 > positive" to_port="example set input"/>
<connect from_op="Replace 4.0 > positive" from_port="example set output" to_op="Replace 5.0 > positive" to_port="example set input"/>
<connect from_op="Replace 5.0 > positive" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Declare Missing Value" to_port="example set input"/>
<connect from_op="Declare Missing Value" from_port="example set output" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Filter Examples" from_port="example set output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Nominal to Text" to_port="example set input"/>
<connect from_op="Nominal to Text" from_port="example set output" to_port="out 1"/>
<portSpacing port="source_in 2" spacing="0"/>
</process>
</process>
<operator activated="true" class="operator_toolbox:smote" compatibility="1.0.000" expanded="true" height="82" name="Smote Upsampling" width="90" x="782" y="85">
<parameter key="number_of_neighbours" value="5"/>
<parameter key="normalize" value="true"/>
<parameter key="equalize_classes" value="true"/>
<parameter key="upsampling_size" value="1000"/>
<parameter key="auto_detect_minority_class" value="true"/>
<parameter key="round_integers" value="true"/>
<parameter key="nominal_change_rate" value="0.5"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
</process>
<operator activated="true" class="sample" compatibility="8.1.003" expanded="true" height="82" name="Sample" width="90" x="782" y="187">
<parameter key="sample" value="relative"/>
<parameter key="balance_data" value="true"/>
<parameter key="sample_size" value="100"/>
<parameter key="sample_ratio" value="0.1"/>
<parameter key="sample_probability" value="0.1"/>
<list key="sample_size_per_class">
<parameter key="positive" value="1000"/>
<parameter key="negative" value="1000"/>
<parameter key="neutral" value="1000"/>
</list>
<list key="sample_ratio_per_class">
<parameter key="negative" value="1.0"/>
<parameter key="positive" value="0.3"/>
<parameter key="neutral" value="1.0"/>
</list>
<list key="sample_probability_per_class"/>
</process>
<operator activated="true" class="text:process_document_from_data" compatibility="8.1.000" expanded="true" height="82" name="Process Documents from Data" width="90" x="916" y="187">
<parameter key="create_word_vector" value="true"/>
<parameter key="vector_creation" value="TF-IDF"/>
<parameter key="add_meta_information" value="true"/>
<parameter key="keep_text" value="false"/>
<parameter key="prune_method" value="percentual"/>
<parameter key="prune_below_percent" value="1.0"/>
<parameter key="prune_above_percent" value="30.0"/>
<parameter key="prune_below_rank" value="0.05"/>
<parameter key="prune_above_rank" value="0.95"/>
<parameter key="datamanagement" value="double_sparse_array"/>
<parameter key="select_attributes_and_weights" value="false"/>
<list key="specify_weights"/>
<operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize" width="90" x="179" y="34">
<parameter key="mode" value="non letters"/>
<parameter key="characters" value=".:"/>
<parameter key="language" value="English"/>
<parameter key="max_token_length" value="3"/>
<operator activated="true" class="text:stem_porter" compatibility="8.1.000" expanded="true" height="68" name="Stem (Porter)" width="90" x="313" y="34"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="8.1.000" expanded="true" height="68" name="Filter Stopwords (English)" width="90" x="447" y="34"/>
<operator activated="true" class="text:transform_cases" compatibility="8.1.000" expanded="true" height="68" name="Transform Cases" width="90" x="581" y="34">
<parameter key="transform_to" value="lower case"/>
<operator activated="true" class="text:filter_by_length" compatibility="8.1.000" expanded="true" height="68" name="Filter Tokens (by Length)" width="90" x="782" y="34">
<parameter key="min_chars" value="2"/>
<parameter key="max_chars" value="15"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Stem (Porter)" to_port="document"/>
<connect from_op="Stem (Porter)" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_port="document 1"/>
</process>
</process>
<operator activated="true" class="singular_value_decomposition" compatibility="8.1.003" expanded="true" height="103" name="SVD" width="90" x="1050" y="136">
<parameter key="dimensionality_reduction" value="fixed number"/>
<parameter key="percentage_threshold" value="0.95"/>
<parameter key="dimensions" value="100"/>
</process>
<operator activated="true" class="read_csv" compatibility="8.1.003" expanded="true" height="68" name="Read Beauty" width="90" x="514" y="289">
<parameter key="csv_file" value="F:\CloudStation\Studie Mikael\VAF\DATA\amabea-right-10k.csv"/>
</list>
<parameter key="1" value="reviewerID.true.polynominal.attribute"/>
<parameter key="2" value="summary.true.polynominal.attribute"/>
<parameter key="3" value="reviewerName.true.polynominal.attribute"/>
<parameter key="4" value="unixReviewTime.true.real.attribute"/>
<parameter key="5" value="reviewText.true.polynominal.attribute"/>
<parameter key="6" value="overall.true.polynominal.attribute"/>
<parameter key="7" value="helpful.true.real.attribute"/>
<parameter key="8" value="asin.true.polynominal.attribute"/>
</list>
</process>
<operator activated="true" class="subprocess" compatibility="8.1.003" expanded="true" height="82" name="Pre-processing (2)" width="90" x="648" y="289">
<operator activated="true" class="replace" compatibility="8.1.003" expanded="true" height="82" name="Replace 1.0 > negative (2)" width="90" x="45" y="34">
<operator activated="true" class="replace" compatibility="8.1.003" expanded="true" height="82" name="Replace 2.0 > negative (2)" width="90" x="179" y="34">
<operator activated="true" class="replace" compatibility="8.1.003" expanded="true" height="82" name="Replace 3.0 > neutral (2)" width="90" x="313" y="34">
<operator activated="true" class="replace" compatibility="8.1.003" expanded="true" height="82" name="Replace 4.0 > positive (2)" width="90" x="447" y="34">
<operator activated="true" class="replace" compatibility="8.1.003" expanded="true" height="82" name="Replace 5.0 > positive (2)" width="90" x="581" y="34">
<operator activated="true" class="declare_missing_value" compatibility="8.1.003" expanded="true" height="82" name="Declare Missing Value (2)" width="90" x="246" y="187">
<operator activated="true" class="filter_examples" compatibility="8.1.003" expanded="true" height="103" name="Filter Examples (2)" width="90" x="380" y="187">
</list>
<operator activated="true" class="select_attributes" compatibility="8.1.003" expanded="true" height="82" name="Select Attributes (2)" width="90" x="514" y="187">
<operator activated="true" class="set_role" compatibility="8.1.003" expanded="true" height="82" name="Set Role (2)" width="90" x="648" y="187">
<operator activated="true" class="nominal_to_text" compatibility="8.1.003" expanded="true" height="82" name="Nominal to Text (2)" width="90" x="782" y="187">
<connect from_port="in 1" to_op="Replace 1.0 > negative (2)" to_port="example set input"/>
<connect from_op="Replace 1.0 > negative (2)" from_port="example set output" to_op="Replace 2.0 > negative (2)" to_port="example set input"/>
<connect from_op="Replace 2.0 > negative (2)" from_port="example set output" to_op="Replace 3.0 > neutral (2)" to_port="example set input"/>
<connect from_op="Replace 3.0 > neutral (2)" from_port="example set output" to_op="Replace 4.0 > positive (2)" to_port="example set input"/>
<connect from_op="Replace 4.0 > positive (2)" from_port="example set output" to_op="Replace 5.0 > positive (2)" to_port="example set input"/>
<connect from_op="Replace 5.0 > positive (2)" from_port="example set output" to_op="Declare Missing Value (2)" to_port="example set input"/>
<connect from_op="Declare Missing Value (2)" from_port="example set output" to_op="Filter Examples (2)" to_port="example set input"/>
<connect from_op="Filter Examples (2)" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/>
<connect from_op="Select Attributes (2)" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/>
<connect from_op="Set Role (2)" from_port="example set output" to_op="Nominal to Text (2)" to_port="example set input"/>
<connect from_op="Nominal to Text (2)" from_port="example set output" to_port="out 1"/>
</process>
</process>
<operator activated="true" class="split_data" compatibility="8.1.003" expanded="true" height="103" name="Split Data" width="90" x="648" y="442">
<enumeration key="partitions">
<parameter key="ratio" value="0.7"/>
<parameter key="ratio" value="0.3"/>
</enumeration>
<parameter key="sampling_type" value="automatic"/>
</process>
<operator activated="true" class="operator_toolbox:smote" compatibility="1.0.000" expanded="true" height="82" name="Smote Upsampling (2)" width="90" x="782" y="289">
</process>
<operator activated="true" class="sample" compatibility="8.1.003" expanded="true" height="82" name="Sample (2)" width="90" x="782" y="391">
</list>
</list>
</process>
<operator activated="true" class="text:process_document_from_data" compatibility="8.1.000" expanded="true" height="82" name="Process Documents from Data (2)" width="90" x="916" y="340">
<operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize (2)" width="90" x="179" y="34">
<operator activated="true" class="text:stem_porter" compatibility="8.1.000" expanded="true" height="68" name="Stem (2)" width="90" x="380" y="34"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="8.1.000" expanded="true" height="68" name="Filter Stopwords (2)" width="90" x="581" y="34"/>
<operator activated="true" class="text:transform_cases" compatibility="8.1.000" expanded="true" height="68" name="Transform Cases (2)" width="90" x="715" y="34">
<operator activated="true" class="text:filter_by_length" compatibility="8.1.000" expanded="true" height="68" name="Filter Tokens (2)" width="90" x="849" y="34">
<connect from_port="document" to_op="Tokenize (2)" to_port="document"/>
<connect from_op="Tokenize (2)" from_port="document" to_op="Stem (2)" to_port="document"/>
<connect from_op="Stem (2)" from_port="document" to_op="Filter Stopwords (2)" to_port="document"/>
<connect from_op="Filter Stopwords (2)" from_port="document" to_op="Transform Cases (2)" to_port="document"/>
<connect from_op="Transform Cases (2)" from_port="document" to_op="Filter Tokens (2)" to_port="document"/>
<connect from_op="Filter Tokens (2)" from_port="document" to_port="document 1"/>
</process>
</process>
<operator activated="true" class="singular_value_decomposition" compatibility="8.1.003" expanded="true" height="103" name="SVD (2)" width="90" x="1050" y="289">
</process>
<operator activated="true" class="concurrency:cross_validation" compatibility="8.1.003" expanded="true" height="145" name="Cross Validation (2)" width="90" x="1184" y="289">
<parameter key="split_on_batch_attribute" value="false"/>
<parameter key="leave_one_out" value="false"/>
<parameter key="number_of_folds" value="2"/>
<parameter key="enable_parallel_execution" value="true"/>
<operator activated="true" class="k_nn" compatibility="8.1.003" expanded="true" height="82" name="k-NN (2)" width="90" x="179" y="34">
<parameter key="k" value="1"/>
<parameter key="weighted_vote" value="false"/>
<parameter key="measure_types" value="MixedMeasures"/>
<parameter key="mixed_measure" value="MixedEuclideanDistance"/>
<parameter key="nominal_measure" value="NominalDistance"/>
<parameter key="numerical_measure" value="EuclideanDistance"/>
<parameter key="divergence" value="GeneralizedIDivergence"/>
<parameter key="kernel_type" value="radial"/>
<parameter key="kernel_gamma" value="1.0"/>
<parameter key="kernel_sigma1" value="1.0"/>
<parameter key="kernel_sigma2" value="0.0"/>
<parameter key="kernel_sigma3" value="2.0"/>
<parameter key="kernel_degree" value="3.0"/>
<parameter key="kernel_shift" value="1.0"/>
<parameter key="kernel_a" value="1.0"/>
<parameter key="kernel_b" value="0.0"/>
<operator activated="false" class="naive_bayes" compatibility="8.1.003" expanded="true" height="82" name="Naive Bayes (2)" width="90" x="179" y="238">
<parameter key="laplace_correction" value="true"/>
<operator activated="false" class="h2o:generalized_linear_model" compatibility="7.6.001" expanded="true" height="124" name="Generalized Linear Model (2)" width="90" x="179" y="340">
<parameter key="family" value="AUTO"/>
<parameter key="link" value="family_default"/>
<parameter key="solver" value="AUTO"/>
<parameter key="reproducible" value="false"/>
<parameter key="maximum_number_of_threads" value="4"/>
<parameter key="use_regularization" value="true"/>
<parameter key="lambda_search" value="false"/>
<parameter key="number_of_lambdas" value="0"/>
<parameter key="lambda_min_ratio" value="0.0"/>
<parameter key="early_stopping" value="true"/>
<parameter key="stopping_rounds" value="3"/>
<parameter key="stopping_tolerance" value="0.001"/>
<parameter key="standardize" value="true"/>
<parameter key="non-negative_coefficients" value="false"/>
<parameter key="add_intercept" value="true"/>
<parameter key="compute_p-values" value="false"/>
<parameter key="remove_collinear_columns" value="false"/>
<parameter key="missing_values_handling" value="MeanImputation"/>
<parameter key="max_iterations" value="0"/>
<parameter key="specify_beta_constraints" value="false"/>
<list key="beta_constraints"/>
<parameter key="max_runtime_seconds" value="0"/>
<list key="expert_parameters"/>
<connect from_port="training set" to_op="k-NN (2)" to_port="training set"/>
<connect from_op="k-NN (2)" from_port="model" to_port="model"/>
<portSpacing port="source_training set" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="8.1.003" expanded="true" height="82" name="Apply Model (4)" width="90" x="112" y="34">
<parameter key="create_view" value="false"/>
<operator activated="true" class="performance_classification" compatibility="8.1.003" expanded="true" height="82" name="Performance training (2)" width="90" x="246" y="34">
<parameter key="main_criterion" value="accuracy"/>
<parameter key="accuracy" value="true"/>
<parameter key="classification_error" value="true"/>
<parameter key="kappa" value="false"/>
<parameter key="weighted_mean_recall" value="true"/>
<parameter key="weighted_mean_precision" value="true"/>
<parameter key="spearman_rho" value="false"/>
<parameter key="kendall_tau" value="false"/>
<parameter key="absolute_error" value="false"/>
<parameter key="relative_error" value="false"/>
<parameter key="relative_error_lenient" value="false"/>
<parameter key="relative_error_strict" value="false"/>
<parameter key="normalized_absolute_error" value="false"/>
<parameter key="root_mean_squared_error" value="false"/>
<parameter key="root_relative_squared_error" value="false"/>
<parameter key="squared_error" value="false"/>
<parameter key="correlation" value="false"/>
<parameter key="squared_correlation" value="false"/>
<parameter key="cross-entropy" value="false"/>
<parameter key="margin" value="false"/>
<parameter key="soft_margin_loss" value="false"/>
<parameter key="logistic_loss" value="true"/>
<parameter key="skip_undefined_labels" value="true"/>
<parameter key="use_example_weights" value="true"/>
<list key="class_weights"/>
<connect from_port="model" to_op="Apply Model (4)" to_port="model"/>
<connect from_port="test set" to_op="Apply Model (4)" to_port="unlabelled data"/>
<connect from_op="Apply Model (4)" from_port="labelled data" to_op="Performance training (2)" to_port="labelled data"/>
<connect from_op="Performance training (2)" from_port="performance" to_port="performance 1"/>
<portSpacing port="sink_test set results" spacing="0"/>
<portSpacing port="sink_performance 1" spacing="0"/>
<portSpacing port="sink_performance 2" spacing="0"/>
</process>
</process>
<operator activated="true" class="concurrency:cross_validation" compatibility="8.1.003" expanded="true" height="145" name="Cross Validation" width="90" x="1184" y="136">
<operator activated="true" class="k_nn" compatibility="8.1.003" expanded="true" height="82" name="k-NN" width="90" x="179" y="34">
<operator activated="false" class="naive_bayes" compatibility="8.1.003" expanded="true" height="82" name="Naive Bayes" width="90" x="179" y="238">
<operator activated="false" class="h2o:generalized_linear_model" compatibility="7.6.001" expanded="true" height="124" name="Generalized Linear Model" width="90" x="179" y="340">
<connect from_port="training set" to_op="k-NN" to_port="training set"/>
<connect from_op="k-NN" from_port="model" to_port="model"/>
</process>
<operator activated="true" class="apply_model" compatibility="8.1.003" expanded="true" height="82" name="Apply Model" width="90" x="112" y="34">
<operator activated="true" class="performance_classification" compatibility="8.1.003" expanded="true" height="82" name="Performance training" width="90" x="246" y="34">
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_op="Performance training" to_port="labelled data"/>
<connect from_op="Performance training" from_port="performance" to_port="performance 1"/>
</process>
</process>
<operator activated="true" class="group_models" compatibility="8.1.003" expanded="true" height="103" name="Group Models" width="90" x="1385" y="187"/>
</process>
<operator activated="true" class="text:process_document_from_data" compatibility="8.1.000" expanded="true" height="82" name="Process Documents from Data (3)" width="90" x="916" y="493">
<operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize (3)" width="90" x="179" y="34">
<operator activated="true" class="text:stem_porter" compatibility="8.1.000" expanded="true" height="68" name="Stem (3)" width="90" x="380" y="34"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="8.1.000" expanded="true" height="68" name="Filter Stopwords (3)" width="90" x="581" y="34"/>
<operator activated="true" class="text:transform_cases" compatibility="8.1.000" expanded="true" height="68" name="Transform Cases (3)" width="90" x="715" y="34">
<operator activated="true" class="text:filter_by_length" compatibility="8.1.000" expanded="true" height="68" name="Filter Tokens (3)" width="90" x="849" y="34">
<connect from_port="document" to_op="Tokenize (3)" to_port="document"/>
<connect from_op="Tokenize (3)" from_port="document" to_op="Stem (3)" to_port="document"/>
<connect from_op="Stem (3)" from_port="document" to_op="Filter Stopwords (3)" to_port="document"/>
<connect from_op="Filter Stopwords (3)" from_port="document" to_op="Transform Cases (3)" to_port="document"/>
<connect from_op="Transform Cases (3)" from_port="document" to_op="Filter Tokens (3)" to_port="document"/>
<connect from_op="Filter Tokens (3)" from_port="document" to_port="document 1"/>
</process>
</process>
<operator activated="true" class="singular_value_decomposition" compatibility="8.1.003" expanded="true" height="103" name="SVD (3)" width="90" x="1050" y="493">
</process>
<operator activated="true" class="apply_model" compatibility="8.1.003" expanded="true" height="82" name="Apply Model (6)" width="90" x="1184" y="493">
</process>
<operator activated="true" class="apply_model" compatibility="8.1.003" expanded="true" height="82" name="Apply Model (2)" width="90" x="1318" y="493">
</process>
<operator activated="true" class="apply_model" compatibility="8.1.003" expanded="true" height="82" name="Apply Model (5)" width="90" x="1452" y="493">
</process>
<operator activated="true" class="apply_model" compatibility="8.1.003" expanded="true" height="82" name="Apply Model (3)" width="90" x="1586" y="493">
</process>
<operator activated="true" class="performance_classification" compatibility="8.1.003" expanded="true" height="82" name="Test Performance" width="90" x="1586" y="340">
<parameter key="main_criterion" value="first"/>
</process>
