When using "predict" in automodel, the first task is to define a target/label. In the process "define target" = set role seems to be the first operator. And similarly the role of the defined target has been labelled as label (in example set output). But in the later process phases, for some reason the "label" -role was gone. However, the model seems to work ok, it can be simulated and accuracy measured.
Why the label -role in example set output was gone?
