Create chart for binominal attributes
User: "AliMajed"
New Altair Community Member
Updated by Jocelyn
Greetings
I have a grocery dataset that shows each transaction has wich items in a binary format (I have attached th eimage to clarify). I want to make the chart to see for example 10 top most bougth stuffs; a histogram or anything else. But I cant, for each chart, it shows how many false and trues are for each items, I don't know how to make it.
Thanks in Advanced
1 - 1 of 11
    User: "lionelderkrikor"
    Accepted Answer
    Hi @AliMajed,
    I think that it is not possible to build your chart directly.
    You have to pre-calculate the sum for each product in your process.
    Here a possible element of answer :
    <?xml version="1.0" encoding="UTF-8"?><process version="8.1.003">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="8.1.003" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="read_excel" compatibility="8.1.003" expanded="true" height="68" name="Read Excel" width="90" x="112" y="34">
    <parameter key="excel_file" value="C:\Users\Lionel\Documents\Formations_DataScience\Rapidminer\Tests_Rapidminer\Binominal_Charts\Binominal_Charts.xlsx"/>
    <parameter key="imported_cell_range" value="A1:I15"/>
    <parameter key="first_row_as_names" value="false"/>
    <list key="annotations">
    <parameter key="0" value="Name"/>
    </list>
    <parameter key="0" value="TID.true.integer.attribute"/>
    <parameter key="1" value="Milk.true.integer.attribute"/>
    <parameter key="2" value="yogurt.true.integer.attribute"/>
    <parameter key="3" value="Cream.true.integer.attribute"/>
    <parameter key="4" value="Ice cream.true.integer.attribute"/>
    <parameter key="5" value="Curd.true.integer.attribute"/>
    <parameter key="6" value="Cheese.true.integer.attribute"/>
    <parameter key="7" value="Butter.true.integer.attribute"/>
    <parameter key="8" value="Eggs.true.integer.attribute"/>
    </list>
    <operator activated="true" class="concurrency:loop_attributes" compatibility="8.1.003" expanded="true" height="82" name="Loop Attributes" width="90" x="313" y="34">
    <parameter key="attribute" value="TID"/>
    <operator activated="true" class="aggregate" compatibility="8.1.003" expanded="true" height="82" name="Aggregate" width="90" x="313" y="34">
    <parameter key="%{loop_attribute}" value="sum"/>
    </list>
    <operator activated="true" class="transpose" compatibility="8.1.003" expanded="true" height="82" name="Transpose" width="90" x="447" y="34"/>
    <connect from_port="input 1" to_op="Aggregate" to_port="example set input"/>
    <connect from_op="Aggregate" from_port="example set output" to_op="Transpose" to_port="example set input"/>
    <connect from_op="Transpose" from_port="example set output" to_port="output 1"/>
    <portSpacing port="sink_output 1" spacing="0"/>
    <portSpacing port="sink_output 2" spacing="0"/>
    </process>
    <operator activated="true" class="append" compatibility="8.1.003" expanded="true" height="82" name="Append" width="90" x="447" y="34"/>
    <operator activated="true" class="rename" compatibility="8.1.003" expanded="true" height="82" name="Rename" width="90" x="581" y="34">
    <parameter key="old_name" value="att_1"/>
    <parameter key="new_name" value="Sum (grocery products)"/>
    <list key="rename_additional_attributes"/>
    <connect from_op="Read Excel" from_port="output" to_op="Loop Attributes" to_port="input 1"/>
    <connect from_op="Loop Attributes" from_port="output 1" to_op="Append" to_port="example set 1"/>
    <connect from_op="Append" from_port="merged set" to_op="Rename" to_port="example set input"/>
    <connect from_op="Rename" from_port="example set output" to_port="result 1"/>
    </process>
    </process>
    After running this process, you obtain an example set with the sum for each product :
    Then you can represent these datas on a bars chart :
    Does this process answer to your need ?
    Lionel
    NB : The link to the Excel file used in this process (created from the screenshot you shared) :
    https://drive.google.com/open?id=1iIwBaWIiPt24McNXov_13dc8DmG5nzTC
