Hello, rapidminer team,
please I am trying to run this process but it doesn't run.I would appreciate your help
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.003">
<operator activated="true" class="read_csv" compatibility="8.1.003" expanded="true" height="68" name="Read CSV" width="90" x="45" y="34">
<parameter key="csv_file" value="C:\Users\Hanan Yakubu\Downloads\Trips-credible.csv"/>
<parameter key="column_separators" value=","/>
<parameter key="trim_lines" value="false"/>
<parameter key="use_quotes" value="true"/>
<parameter key="quotes_character" value="""/>
<parameter key="escape_character" value="\"/>
<parameter key="skip_comments" value="false"/>
<parameter key="comment_characters" value="#"/>
<parameter key="parse_numbers" value="true"/>
<parameter key="decimal_character" value="."/>
<parameter key="grouped_digits" value="false"/>
<parameter key="grouping_character" value=","/>
<parameter key="date_format" value=""/>
<parameter key="first_row_as_names" value="true"/>
<list key="annotations"/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="locale" value="English (United States)"/>
<parameter key="read_all_values_as_polynominal" value="false"/>
<list key="data_set_meta_data_information"/>
<parameter key="read_not_matching_values_as_missings" value="true"/>
<parameter key="datamanagement" value="double_array"/>
<parameter key="data_management" value="auto"/>
</process>
<operator activated="true" class="com.aylien.textapi.rapidminer:aylien_sentiment" compatibility="0.2.000" expanded="true" height="68" name="Analyze Sentiment" width="90" x="45" y="136">
<parameter key="connection" value="Aylien"/>
<parameter key="input_attribute" value="opine"/>
<parameter key="sentiment_mode" value="document"/>
<parameter key="Is input URL" value="false"/>
</process>
<operator activated="true" class="text:data_to_documents" compatibility="8.1.000" expanded="true" height="68" name="Data to Documents" width="90" x="45" y="238">
<parameter key="select_attributes_and_weights" value="false"/>
<list key="specify_weights"/>
</process>
<operator activated="true" class="com.aylien.textapi.rapidminer:aylien_document_classify_by_taxonomy" compatibility="0.2.000" expanded="true" height="82" name="Categorize (Document)" width="90" x="45" y="289">
<parameter key="Taxonomy" value="iab-qag"/>
</process>
<operator activated="true" class="text:documents_to_data" compatibility="8.1.000" expanded="true" height="82" name="Documents to Data" width="90" x="179" y="289">
<parameter key="text_attribute" value="opine"/>
<parameter key="add_meta_information" value="true"/>
<parameter key="datamanagement" value="double_sparse_array"/>
</process>
