any solutions pls ?
Hi @342208173
Please share sample date and process XML to help us understand more about the issue going on here.
Thanks,
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.001"><context><input/><output/><macros/></context><operator activated="true" class="process" compatibility="8.1.001" expanded="true" name="Process"><process expanded="true"><operator activated="true" class="subprocess" compatibility="8.1.001" expanded="true" height="82" name="Subprocess" width="90" x="112" y="136"><process expanded="true"><operator activated="true" class="retrieve" compatibility="8.1.001" expanded="true" height="68" name="Retrieve" width="90" x="45" y="34"><parameter key="repository_entry" value="//Local Repository/data/Chicago_Crimes_2005_to_2007"/></operator><operator activated="true" class="trim" compatibility="8.1.001" expanded="true" height="82" name="Trim" width="90" x="179" y="34"/><operator activated="true" class="replace_missing_values" compatibility="8.1.001" expanded="true" height="103" name="Replace Missing Values" width="90" x="313" y="34"><list key="columns"/></operator><operator activated="true" class="remove_duplicates" compatibility="8.1.001" expanded="true" height="103" name="Remove Duplicates" width="90" x="447" y="34"/><operator activated="true" class="select_attributes" compatibility="8.1.001" expanded="true" height="82" name="Select Attributes" width="90" x="45" y="136"><parameter key="attribute_filter_type" value="subset"/><parameter key="attributes" value="Block|Community Area|Date|District|Location|Primary Type|Updated On|Year"/></operator><operator activated="true" class="set_role" compatibility="8.1.001" expanded="true" height="82" name="Set Role" width="90" x="380" y="187"><parameter key="attribute_name" value="Primary Type"/><parameter key="target_role" value="label"/><list key="set_additional_roles"/></operator><connect from_op="Retrieve" from_port="output" to_op="Trim" to_port="example set input"/><connect from_op="Trim" from_port="example set output" to_op="Replace Missing Values" to_port="example set input"/><connect from_op="Replace Missing Values" from_port="example set output" to_op="Remove Duplicates" to_port="example set input"/><connect from_op="Remove Duplicates" from_port="example set output" to_op="Select Attributes" to_port="example set input"/><connect from_op="Select Attributes" from_port="original" to_op="Set Role" to_port="example set input"/><connect from_op="Set Role" from_port="example set output" to_port="out 1"/><portSpacing port="source_in 1" spacing="0"/><portSpacing port="sink_out 1" spacing="0"/><portSpacing port="sink_out 2" spacing="0"/></process></operator><operator activated="true" class="split_validation" compatibility="8.1.001" expanded="true" height="124" name="Validation" width="90" x="380" y="136"><process expanded="true"><operator activated="true" class="h2o:deep_learning" compatibility="7.6.001" expanded="true" height="82" name="Deep Learning" width="90" x="112" y="85"><enumeration key="hidden_layer_sizes"><parameter key="hidden_layer_sizes" value="50"/><parameter key="hidden_layer_sizes" value="50"/></enumeration><enumeration key="hidden_dropout_ratios"/><list key="expert_parameters"/><list key="expert_parameters_"/></operator><connect from_port="training" to_op="Deep Learning" to_port="training set"/><connect from_op="Deep Learning" from_port="model" to_port="model"/><portSpacing port="source_training" spacing="0"/><portSpacing port="sink_model" spacing="0"/><portSpacing port="sink_through 1" spacing="0"/></process><process expanded="true"><operator activated="true" class="apply_model" compatibility="8.1.001" expanded="true" height="82" name="Apply Model" width="90" x="45" y="34"><list key="application_parameters"/></operator><operator activated="true" class="performance" compatibility="8.1.001" expanded="true" height="82" name="Performance" width="90" x="179" y="34"/><connect from_port="model" to_op="Apply Model" to_port="model"/><connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/><connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/><connect from_op="Performance" from_port="performance" to_port="averagable 1"/><portSpacing port="source_model" spacing="0"/><portSpacing port="source_test set" spacing="0"/><portSpacing port="source_through 1" spacing="0"/><portSpacing port="sink_averagable 1" spacing="0"/><portSpacing port="sink_averagable 2" spacing="0"/></process></operator><connect from_op="Subprocess" from_port="out 1" to_op="Validation" to_port="training"/><connect from_op="Validation" from_port="model" to_port="result 1"/><connect from_op="Validation" from_port="averagable 1" to_port="result 2"/><portSpacing port="source_input 1" spacing="0"/><portSpacing port="sink_result 1" spacing="0"/><portSpacing port="sink_result 2" spacing="0"/><portSpacing port="sink_result 3" spacing="0"/></process></operator></process>
you can find the data set here because i could not upload it.
https://www.kaggle.com/currie32/crimes-in-chicago/data
Thank you.
