Does RM v.8.1.001 don't like notes... ;-)
Is there any way to move operator and note into subprocess?
Before "Move into new Subprocess"
After "Move into new Subprocess"
Thanks!
Thomas
If you "attach" the notes to the operators, they will move into the subprocess along with the operator. You can attach notes either by right clicking the operator and adding a note from the context menu, or by dragging an existing note on top of the operator until it sticks.
Yes this works fine..!
But If I drag the note over the operator, the note will lost his background color. Before he is yello, after "drag" he is without any background color.
That's just a default setting. You can manually change the note color once it is attached to the operator through "edit note" or double-clicking and then pick a different color from the drop down.
