Charts and Color-Column: How to select Attributes in Color-Column?
User: "thomas_wiedmann"
New Altair Community Member
Updated by Jocelyn
Due to "Filter Examples" are within the graph are fewer points than in the "Color Column". All values are displayed in "Color Column". Only five values in the result set are to be output. How so select values in "Color Column" ?
The other way around. I just wanna see this five values in "Color Column" that apears in the chart.
Thanks!
Thomas
1 - 1 of 11
    User: "kypexin"
    Accepted Answer
    Hi @thomas_wiedmann
    If I get your issue correct that after filtering examples you only have this 5 'KLASS' values in the dataset left, then try putting 'Remove unused values' operator after 'Filter examples', this will remove all values that may have remained after filteringf but are not assigned to any example.
