HelloWhat to do in the SEARCH TWITTER operator does not get reTWEET values. And just receive tweets?Thankful
Use the Search Twitter operator then a Select Attributes operator. Then select 'single' and the Text value.
Like so:
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="8.1.001" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="social_media:search_twitter" compatibility="8.1.000" expanded="true" height="68" name="Search Twitter" width="90" x="112" y="34"> <parameter key="connection" value="Twitter - Studio Connection"/> <parameter key="query" value="rapidminer"/> </operator> <operator activated="true" class="select_attributes" compatibility="8.1.001" expanded="true" height="82" name="Select Attributes" width="90" x="246" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Text"/> </operator> <connect from_op="Search Twitter" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
HelloThankfulBut I can not use the code givenI do not have the xml section
@ahootanha yes you do, your screen resolution is clipping off the XML view option.
