Hi everyone,
i'm having trouble to apply the normalisation into the keras apply model. is that possible to connect them if using the keras apply model?thank very much.
Please post your XML process and sample data. It's kinda hard to diagnose without seeing the how the data flows through the process.
Hi, @Thomas_Ott
thank you for the reply.. i think i have just found the solution.. what i did is just connecting the usual apply model instead of using the keras apply model.. That has solved my problem.. Thanks again..
@dass sounds good. Good luck!
