I am scoring data and get results in a column called "confidence". Easy enough, but this result data is hidden from use in downstream processes - cannot see the column in generate attributes, set role, select attributes, etc. The only place I see the output is in the yellow results column. Is there an operator to retrieve this confidence data and use it in downstream process steps? I can export to excel and reimport but this seems silly. thanks, Mike
