Problem with Neural Net "use local random seed"
GonzaloAD
GonzaloAD New Altair Community Member
Hi guys, I have a small trouble.
How is it possible that when the "use local random seed" of Neural Net block is not enabled (unchecked) the same NN process does NOT provide the same results?
What is the purpose of "use local random seed"?
This is my XML process;
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.001">
<operator activated="true" class="read_csv" compatibility="8.1.001" expanded="true" height="68" name="Read CSV" width="90" x="112" y="187">
<parameter key="csv_file" value="C:\Users\Admin\Desktop\data Example.csv"/>
<parameter key="column_separators" value=";"/>
<parameter key="trim_lines" value="false"/>
<parameter key="use_quotes" value="true"/>
<parameter key="quotes_character" value="&quot;"/>
<parameter key="escape_character" value="\"/>
<parameter key="skip_comments" value="false"/>
<parameter key="comment_characters" value="#"/>
<parameter key="parse_numbers" value="true"/>
<parameter key="decimal_character" value="."/>
<parameter key="grouped_digits" value="false"/>
<parameter key="grouping_character" value=","/>
<parameter key="date_format" value=""/>
<parameter key="first_row_as_names" value="true"/>
<list key="annotations"/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="locale" value="English (United States)"/>
<parameter key="read_all_values_as_polynominal" value="false"/>
<list key="data_set_meta_data_information"/>
<parameter key="read_not_matching_values_as_missings" value="true"/>
<parameter key="datamanagement" value="double_array"/>
<parameter key="data_management" value="auto"/>
</process>
<operator activated="true" class="select_attributes" compatibility="8.1.001" expanded="true" height="82" name="Select Attributes T" width="90" x="246" y="187">
<parameter key="attribute" value=""/>
<parameter key="attributes" value="F|D|C|B|A"/>
</process>
<operator activated="true" class="set_role" compatibility="8.1.001" expanded="true" height="82" name="Set Role T" width="90" x="380" y="187">
<parameter key="attribute_name" value="F"/>
</process>
<operator activated="true" class="multiply" compatibility="8.1.001" expanded="true" height="145" name="Multiply Data T" width="90" x="514" y="187"/>
</process>
<operator activated="true" class="neural_net" compatibility="8.1.001" expanded="true" height="82" name="Neural Net" width="90" x="715" y="136">
<list key="hidden_layers">
<parameter key="Hidden" value="21"/>
</list>
<parameter key="training_cycles" value="32000"/>
<parameter key="learning_rate" value="0.1"/>
<parameter key="momentum" value="0.1"/>
<parameter key="decay" value="false"/>
<parameter key="shuffle" value="true"/>
<parameter key="normalize" value="true"/>
<parameter key="error_epsilon" value="1.0E-5"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
</process>
<operator activated="true" class="apply_model" compatibility="8.1.001" expanded="true" height="82" name="Apply Model NN" width="90" x="849" y="136">
<parameter key="create_view" value="false"/>
</process>
<operator activated="true" class="performance_regression" compatibility="8.1.001" expanded="true" height="82" name="Performance NN" width="90" x="983" y="136">
<parameter key="main_criterion" value="first"/>
<parameter key="root_mean_squared_error" value="true"/>
<parameter key="absolute_error" value="false"/>
<parameter key="relative_error" value="true"/>
<parameter key="relative_error_lenient" value="false"/>
<parameter key="relative_error_strict" value="false"/>
<parameter key="normalized_absolute_error" value="false"/>
<parameter key="root_relative_squared_error" value="false"/>
<parameter key="squared_error" value="false"/>
<parameter key="correlation" value="true"/>
<parameter key="squared_correlation" value="true"/>
<parameter key="prediction_average" value="false"/>
<parameter key="spearman_rho" value="false"/>
<parameter key="kendall_tau" value="false"/>
<parameter key="skip_undefined_labels" value="true"/>
<parameter key="use_example_weights" value="true"/>
</process>
<operator activated="true" class="neural_net" compatibility="8.1.001" expanded="true" height="82" name="Neural Net (2)" width="90" x="715" y="238">
</list>
</process>
<operator activated="true" class="apply_model" compatibility="8.1.001" expanded="true" height="82" name="Apply Model NN (2)" width="90" x="849" y="238">
</process>
<operator activated="true" class="performance_regression" compatibility="8.1.001" expanded="true" height="82" name="Performance NN (2)" width="90" x="983" y="238">
</process>
<operator activated="true" class="neural_net" compatibility="8.1.001" expanded="true" height="82" name="Neural Net (3)" width="90" x="715" y="340">
</list>
</process>
<operator activated="true" class="apply_model" compatibility="8.1.001" expanded="true" height="82" name="Apply Model NN (3)" width="90" x="849" y="340">
</process>
<operator activated="true" class="performance_regression" compatibility="8.1.001" expanded="true" height="82" name="Performance NN (3)" width="90" x="983" y="340">
</process>
<operator activated="true" class="neural_net" compatibility="8.1.001" expanded="true" height="82" name="Neural Net 21" width="90" x="715" y="442">
</list>
<parameter key="use_local_random_seed" value="true"/>
</process>
<operator activated="true" class="apply_model" compatibility="8.1.001" expanded="true" height="82" name="Apply Model NN (4)" width="90" x="849" y="442">
</process>
<operator activated="true" class="performance_regression" compatibility="8.1.001" expanded="true" height="82" name="Performance NN (4)" width="90" x="983" y="442">
</process>
 Can anyone help me?
Thanks!!!!
  • YYH
    YYH
    Hi @GonzaloAD,
    You xml code is somehow broken but I get your point.
    The NN operator in RapidMiner learns a model by means of a feed-forward neural network trained by a back propagation algorithm (multi-layer perceptron).
    The neural network corresponds to a function {\displaystyle y=f_{N}(w,x)} which, given a weight w,, maps an input x to an output y.produces a sequence of weights {\displaystyle w_{0},w_{1},\dots ,w_{p}}starting from some initial weight w0 , usually chosen at random
    Who is controlling the 'randomness' of the initial weight? The random seed. As you may know, we have no real random number generator in computer science. A seed is to be used in a pseudorandom number generator.
    HTH,
    YY
  • GonzaloAD
    I got it.
    The reason was that without a specific random seed the initialization value is random.
    Thank you very much!!!
Welcome!
Welcome!
