hello @ahootanha some quick recommendations for you:• Post your XML process here in this thread (see https://youtu.be/KkgB5QXWXJ8 and "Read Before Posting" on right when you reply)• Attach your dataset if possible (use a fictionalized version if there are privacy concerns)• Make sure you have all necessary extensions installed (see https://youtu.be/pjBqG3xtXx4)Scott
Hello @ahootanha so perhaps you misunderstood. I am sure you searched and did not find an answer. But PLEASE post your process and your dataset. This is the part that makes it much easier for us to help.
Scott
HelloThank you for your attentionI get data with the search twitter operator. And I want to remove the symbols from tweets in the preprocessing stage.Please guide. How do I perform preprocessing for the analysis of emotions in RapidMiner? Thanks & Regards
hello @ahootanha I hear your question and I am able and willing to help. But if you don't (a) post your process, and (b) post your dataset, I cannot. I'm not sure how many different ways I can explain the same thing...
so there are good RegEx editors built into some operators, e.g. the Replace operator. There you can find some pre-made RegEx expressions such as the one you wish to use:
thanks for your kindnessOnlyHow do I remove links(URL) in tweets as well as emoticons?
and
how in the word, for exampleheeelllllooooRemove the prepositions of the hello word and also for other words.Please tell meVery necessaryThanks to your good forum
hello @ahootanha Some quick recommendations for you:• Post your XML process here in this thread (see https://youtu.be/KkgB5QXWXJ8 and "Read Before Posting" on right when you reply)• Attach your dataset if possible (use a fictionalized version if there are privacy concerns)• Make sure you have all necessary extensions installed (see https://youtu.be/pjBqG3xtXx4)Scott
Hi, thank you very much for being grateful. And guide meYes, I know this But I could not find the answer to my question ...I'd like to tell you how to remove links(URL) in tweetsplease..Thankful
