"Filter: Upper case and Lower case"
asn4293
asn4293 New Altair Community Member
I find it very awkward that we have filter operator and we can only do it by having exact upper and lower case. I don't know but @IngoRM it should have been in the some options of filtering please. Also, if it is not in the software you should have it in, in the next update
Best Answer
  • MartinLiebig
    MartinLiebig
    Answer ✓
    Hi @asn4293,
    like this?
    Best,
    Martin
    <?xml version="1.0" encoding="UTF-8"?><process version="8.1.001">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="8.1.001" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="generate_data_user_specification" compatibility="8.1.001" expanded="true" height="68" name="Generate Data by User Specification" width="90" x="179" y="34">
    <list key="attribute_values">
    <parameter key="word" value="&quot;english&quot;"/>
    </list>
    <operator activated="true" class="generate_data_user_specification" compatibility="8.1.001" expanded="true" height="68" name="Generate Data by User Specification (2)" width="90" x="179" y="136">
    <parameter key="word" value="&quot;English&quot;"/>
    </list>
    <operator activated="true" class="generate_data_user_specification" compatibility="8.1.001" expanded="true" height="68" name="Generate Data by User Specification (3)" width="90" x="179" y="238">
    <parameter key="word" value="&quot;French&quot;"/>
    </list>
    <operator activated="true" class="append" compatibility="8.1.001" expanded="true" height="124" name="Append" width="90" x="313" y="85"/>
    <operator activated="true" class="filter_examples" compatibility="8.1.001" expanded="true" height="103" name="Filter Examples" width="90" x="447" y="85">
    <parameter key="parameter_expression" value="matches(lower(word),&quot;eng.+&quot;)"/>
    <parameter key="condition_class" value="expression"/>
    <list key="filters_list"/>
    <description align="center" color="transparent" colored="false" width="126">Filter for a or A</description>
    <connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 1"/>
    <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 2"/>
    <connect from_op="Generate Data by User Specification (3)" from_port="output" to_op="Append" to_port="example set 3"/>
    <connect from_op="Append" from_port="merged set" to_op="Filter Examples" to_port="example set input"/>
    <connect from_op="Filter Examples" from_port="example set output" to_port="result 1"/>
    </process>
    </process>
  • sgenzer
    sgenzer
    hello @asn4293 so the Filter Examples operator does distinguish between lower and upper case on purpose. Lots of good reasons for it but it's an interesting suggestion to have a checkbox saying "ignore cases". Feel free to put it in our Product Ideas section. :)
    Meanwhile if you want to use Filter Examples irrespective of case, I'd suggest using a RegEx expression or converting your text to one case using the Transform Cases operator (Text Processing extension).
    Scott
  • MartinLiebig
    MartinLiebig
    Hi @asn4293,
    Filter Examples can filter independently of the case. you can just choose expression and write something like:
    lower(attribute) != "myvalue"
    Best,
    Martin
  • asn4293
    Hi @mschmitz,
    Can you please explain in detail. or XML code could work.
    Thank you and have a nice day.
    Regards
    Ahsan Shahid
  • MartinLiebig
    MartinLiebig
    Hi @asn4293,
    sure! Attached is an example.
    Best,
    Martin
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <parameter key="word" value="&quot;a&quot;"/>
    </list>
    <parameter key="word" value="&quot;A&quot;"/>
    </list>
    <parameter key="word" value="&quot;b&quot;"/>
    </list>
    <operator activated="true" breakpoints="after" class="append" compatibility="8.1.001" expanded="true" height="124" name="Append" width="90" x="313" y="85"/>
    <parameter key="parameter_expression" value="lower(word) == &quot;a&quot;"/>
    </process>
    </process>
  • asn4293
    Hi @mschmitz
    I found it useful but not fully. Can we filter like contains for example my data is 'English, english, French but I want to check if it contains eng it should filter out both English and english.
    <?xml version="1.0" encoding="UTF-8"?><process version="8.0.001">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="8.0.001" expanded="true" name="Process">
    <operator activated="true" class="generate_data_user_specification" compatibility="8.0.001" expanded="true" height="68" name="Generate Data by User Specification" width="90" x="179" y="34">
    </list>
    <operator activated="true" class="generate_data_user_specification" compatibility="8.0.001" expanded="true" height="68" name="Generate Data by User Specification (2)" width="90" x="179" y="136">
    </list>
    <operator activated="true" class="generate_data_user_specification" compatibility="8.0.001" expanded="true" height="68" name="Generate Data by User Specification (3)" width="90" x="179" y="238">
    </list>
    <operator activated="true" class="append" compatibility="8.0.001" expanded="true" height="124" name="Append" width="90" x="313" y="85"/>
    <operator activated="true" class="filter_examples" compatibility="8.0.001" expanded="true" height="103" name="Filter Examples" width="90" x="447" y="85">
    <parameter key="parameter_expression" value="lower(word) == &quot;eng&quot;"/>
    </process>
    </process>
    Best regards
    Ahsan Shahid
  • MartinLiebig
    MartinLiebig
    Answer ✓
    Hi @asn4293,
    like this?
    Best,
    Martin
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    </list>
    </list>
    </list>
    </process>
    </process>
  • asn4293
    Dear@mschmitz,
    Thank you so very much for support this would do the work. but it would be wonderful if this data set can also filter in between text for example "English" filter "glis" and we find it as english.
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    </list>
    </list>
    </list>
    <parameter key="parameter_expression" value="matches(lower(word),&quot;glis.+&quot;)"/>
    </process>
    </process>
  • MartinLiebig
    MartinLiebig
    sure. you would just use
    .+glis.+
    as a regular expression.
    Cheers
    Martin
