Hi! I have a problem with handling Excel file via association rule creating. Please let me know what do I do wrong? The error message I got is "The exampleset contains non-nominal attribute "prod.date" which is not allowed to fp-growth" .". I try to handle data from Excel file but I have transformed it to .txt in order to attach it.
<?xml version="1.0" encoding="UTF-8"?><process version="8.0.001">
<operator activated="true" class="retrieve" compatibility="8.0.001" expanded="true" height="68" name="Retrieve рабочий файл для проверки (2)" width="90" x="45" y="34">
<parameter key="repository_entry" value="//рабочий файл/первая попытка/рабочий файл для проверки"/>
</process>
<operator activated="true" class="numerical_to_binominal" compatibility="8.0.001" expanded="true" height="82" name="Numerical to Binominal" width="90" x="246" y="34">
<parameter key="attribute_filter_type" value="all"/>
<parameter key="attribute" value=""/>
<parameter key="value_type" value="numeric"/>
<parameter key="except_value_type" value="real"/>
<parameter key="block_type" value="value_series"/>
<parameter key="except_block_type" value="value_series_end"/>
<parameter key="min" value="0.0"/>
<parameter key="max" value="0.0"/>
</process>
<operator activated="true" class="fp_growth" compatibility="8.0.001" expanded="true" height="82" name="FP-Growth" width="90" x="380" y="34">
<parameter key="find_min_number_of_itemsets" value="true"/>
<parameter key="min_number_of_itemsets" value="100"/>
<parameter key="max_number_of_retries" value="15"/>
<parameter key="min_support" value="0.95"/>
<parameter key="max_items" value="-1"/>
<parameter key="keep_example_set" value="false"/>
</process>
<operator activated="true" class="create_association_rules" compatibility="8.0.001" expanded="true" height="82" name="Create Association Rules" width="90" x="514" y="34">
<parameter key="criterion" value="confidence"/>
<parameter key="min_confidence" value="0.8"/>
<parameter key="min_criterion_value" value="0.8"/>
<parameter key="gain_theta" value="2.0"/>
<parameter key="laplace_k" value="1.0"/>
</process>
