How can I do a time series graph with several attributes in the y axis for several domain dimension?
User: "santosj"
New Altair Community Member
Updated by Jocelyn
I am using Rapid Miner for my master thesis project and I am right now doing the data exploration of my data. I want to do a specific time series graph but I do not know how to do it in Rapid Miner. I have been searching on the internet for several days on this matter but I cannot find anything..I hope you can help me! I would be very thankful.
The graph that I want to do is a time series graph that has as follows: In the x axis a number of days as an index and in the y axis, several attributes. So far so good. My problem is that I do not know how to plot each attribute that I have in the y axis at a time span in days that I have saved in several attributes. The aim of the series graph that I want to do is to view the evolution of a set of parameters through time were I have the values of all these parameters as well as when they were measured in days. Thank you very much!
1 - 1 of 11
    User: "lionelderkrikor"
    Accepted Answer
    Hi again @santosj,
    Interesting problem !
    If I good understand, one way to perform what you want to do is to use the De-Pivot operator.
    By using this operator, you obtain the Blood Pressure according to the time like this :
    and then you can plot these data like this :
    You can find the process here :
    <?xml version="1.0" encoding="UTF-8"?><process version="8.1.001">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="8.1.001" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="read_excel" compatibility="8.1.001" expanded="true" height="68" name="Read Excel" width="90" x="112" y="34">
    <parameter key="excel_file" value="C:\Users\Lionel\Documents\Formations_DataScience\Rapidminer\Tests_Rapidminer\Time_series_Plot\Time_series_Plot_Blood_pressure.xlsx"/>
    <parameter key="imported_cell_range" value="A1:I3"/>
    <parameter key="first_row_as_names" value="false"/>
    <list key="annotations">
    <parameter key="0" value="Name"/>
    </list>
    <parameter key="0" value="Patient ID.true.integer.attribute"/>
    <parameter key="1" value="Blood Pressure before treatment.true.integer.attribute"/>
    <parameter key="2" value="Blood Pressure 2 months.true.integer.attribute"/>
    <parameter key="3" value="Blood Pressure 3 months.true.integer.attribute"/>
    <parameter key="4" value="Blood Pressure 6 months.true.integer.attribute"/>
    <parameter key="5" value="Treatment date.true.date_time.attribute"/>
    <parameter key="6" value="date 2 months.true.date_time.attribute"/>
    <parameter key="7" value="date 3 months.true.date_time.attribute"/>
    <parameter key="8" value="date 6 months.true.date_time.attribute"/>
    </list>
    <operator activated="true" class="generate_attributes" compatibility="8.1.001" expanded="true" height="82" name="Generate Attributes" width="90" x="246" y="34">
    <parameter key="2" value="2"/>
    <parameter key="3" value="3"/>
    <parameter key="6" value="6"/>
    <parameter key="0" value="0"/>
    </list>
    <operator activated="true" class="select_attributes" compatibility="8.1.001" expanded="true" height="82" name="Select Attributes" width="90" x="380" y="34">
    <parameter key="attributes" value="Blood Pressure 2 months|Blood Pressure 3 months|Blood Pressure 6 months|Blood Pressure before treatment|6|3|2|0"/>
    <operator activated="true" class="de_pivot" compatibility="8.1.001" expanded="true" height="82" name="De-Pivot" width="90" x="514" y="34">
    <list key="attribute_name">
    <parameter key="Blood Pressure" value="Blood Pressure 2 months|Blood Pressure 3 months|Blood Pressure 6 months|Blood Pressure before treatment"/>
    </list>
    <parameter key="index_attribute" value="Time"/>
    <parameter key="create_nominal_index" value="true"/>
    <connect from_op="Read Excel" from_port="output" to_op="Generate Attributes" to_port="example set input"/>
    <connect from_op="Generate Attributes" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
    <connect from_op="Select Attributes" from_port="example set output" to_op="De-Pivot" to_port="example set input"/>
    <connect from_op="De-Pivot" from_port="example set output" to_port="result 1"/>
    </process>
    </process>
    and the Excel example set (from your partial dataset) here :
    https://drive.google.com/open?id=1ZKmTSpj_jHV1rtaxBBCgpgwCIF-zl4zP
    I hope it helps,
    Lionel
