Don't understand this error using Map. I want to replace the values of a column from (K, 2, T, M, 1, 6, 3) to (11,2,13,12,1,6,3) to get nominal values.
1) Process
2) MAP
3) Mappings
Any hint?
Thanks!
Thomas
Hi @thomas_wiedmann,
you need to check mark "include special attributes" because yours is a label.
Best,
Martin
