Confused about the Query Expression blocks on the Extract Information Operator
User: "sgtcrom7"
New Altair Community Member
Updated by Jocelyn
I'm trying to extract word counts from a block of text. I have the Create Document Operator (where I have pasted my text) linked to the Extract Information Operator. I have the words I want tot extract (terrorist and civilian) entered into the attribute name blocks, what should I be putting in the query expression blocks? Thanks.
1 - 5 of 51
    User: "lionelderkrikor"
    Hi @sgtcrom7,
    Can this process meet your needs?
    <?xml version="1.0" encoding="UTF-8"?><process version="8.1.001">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="8.1.001" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="text:create_document" compatibility="8.1.000" expanded="true" height="68" name="Create Document" width="90" x="112" y="85">
    <parameter key="text" value="My taylor is rich. He's a terrorist, but before he was a civilian."/>
    <operator activated="true" class="text:process_documents" compatibility="8.1.000" expanded="true" height="103" name="Process Documents" width="90" x="313" y="85">
    <parameter key="vector_creation" value="Term Occurrences"/>
    <operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize" width="90" x="313" y="34"/>
    <connect from_port="document" to_op="Tokenize" to_port="document"/>
    <connect from_op="Tokenize" from_port="document" to_port="document 1"/>
    </process>
    <operator activated="true" class="select_attributes" compatibility="8.1.001" expanded="true" height="82" name="Select Attributes" width="90" x="514" y="85">
    <parameter key="attributes" value="civilian|terrorist"/>
    <parameter key="regular_expression" value="civilian"/>
    <connect from_op="Create Document" from_port="output" to_op="Process Documents" to_port="documents 1"/>
    <connect from_op="Process Documents" from_port="example set" to_op="Select Attributes" to_port="example set input"/>
    <connect from_op="Process Documents" from_port="word list" to_port="result 2"/>
    <connect from_op="Select Attributes" from_port="example set output" to_port="result 1"/>
    </process>
    </process>
    Lionel
    User: "sgtcrom7"
    OP
    Lionel,
    Thanks for the reply. I'm not sure if this solves my problem or not. I just downloaded the free version of RapidMiner today, and I am only using the drag and drop functions. So I'm actually not sure where I would enter code like that. Sorry if I wasted your time. I really do appreciate you trying to help.
    I did eventually end up figuring out how to get word counts out of my documents however, so maybe as I keep playing with the software I can learn enough to ask better questions. What I need to do is actually very simple, I'm just trying to figure out how to make it less labor intensive. Again, thanks.
    @sgtcrom7,
    A / To use the code I provide, you have to follow these steps (this is the method to share a process between RapidMiner users) :
    1.Activation of the XML panel :
    2. Copy and paste the XML code I provided in the XML panel
    3. Click on the "check button"
    4. Normally, the process appears in the process window....
    B/ To learn the basics of RapidMiner, I encourage you to start by following :
     - the tutorials (menu Help)
     - the training videos (menu Help
    I hope it helps,
    Lionel
    User: "sgtcrom7"
    OP
    The code didn't run, but thanks for explaining that to me. I'm making progress!
    Hi @sgtcrom7,
    Glad you make progress....but....
    "The code didn't run...."
    Here some hypothesis :
     - did you fully copy the code I provided and/or
     - did you clear the existing code before copying my code in the XML panel ? here the instructions :
    "never give up...." :
    Don't hesitate to reply if it does'nt work.
    Lionel
