hello, i have a numerical dataset, how to keep the maximum value in each example (row) in its current location, and zeroize all other attributes values. i mean to show only the maximum value in example in its origin attributes.
Hi @alhawary8611
Does this process answer to your need ?
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_excel" compatibility="8.1.001" expanded="true" height="68" name="Read Excel" width="90" x="112" y="34"> <parameter key="excel_file" value="C:\Users\Lionel\Documents\Formations_DataScience\Rapidminer\Tests_Rapidminer\Filter_max_values\Filter_max_values.xlsx"/> <parameter key="imported_cell_range" value="A1:D5"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="Att1.true.integer.attribute"/> <parameter key="1" value="Att2.true.integer.attribute"/> <parameter key="2" value="Att3.true.integer.attribute"/> <parameter key="3" value="Att4.true.integer.attribute"/> </list> </operator> <operator activated="true" class="generate_aggregation" compatibility="8.1.001" expanded="true" height="82" name="Generate Aggregation" width="90" x="246" y="34"> <parameter key="attribute_name" value="Max_Att1"/> <parameter key="attribute" value="Att1"/> <parameter key="aggregation_function" value="maximum"/> </operator> <operator activated="true" class="concurrency:loop_attributes" compatibility="8.1.001" expanded="true" height="82" name="Loop Attributes" width="90" x="447" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Max_Att1"/> <parameter key="invert_selection" value="true"/> <process expanded="true"> <operator activated="true" class="generate_attributes" compatibility="8.1.001" expanded="true" height="82" name="Generate Attributes" width="90" x="380" y="34"> <list key="function_descriptions"> <parameter key="%{loop_attribute}" value="if(eval(%{loop_attribute}) == Max_Att1,eval(%{loop_attribute}),0)"/> </list> </operator> <operator activated="true" class="select_attributes" compatibility="8.1.001" expanded="true" height="82" name="Select Attributes" width="90" x="581" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="%{loop_attribute}"/> <parameter key="regular_expression" value="Att1"/> </operator> <connect from_port="input 1" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="operator_toolbox:merge" compatibility="0.9.000" expanded="true" height="82" name="Merge" width="90" x="648" y="34"/> <connect from_op="Read Excel" from_port="output" to_op="Generate Aggregation" to_port="example set input"/> <connect from_op="Generate Aggregation" from_port="example set output" to_op="Loop Attributes" to_port="input 1"/> <connect from_op="Loop Attributes" from_port="output 1" to_op="Merge" to_port="example set 1"/> <connect from_op="Merge" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
Lionel
hello @alhawary8611 welcome to the community! Some quick recommendations for you:• Post your XML process here in this thread (see https://youtu.be/KkgB5QXWXJ8 and "Read Before Posting" on right when you reply)• Attach your dataset if possible (use a fictionalized version if there are privacy concerns)• Make sure you have all necessary extensions installed (see https://youtu.be/pjBqG3xtXx4)Scott
Thank you Mr. Lionel. this is what i need.
