customer Sentiment Analysis with RapidMiner
kh6055555
New Altair Community Member
RapidMiner results
(at least 900 analyzed Twitter records)
Make sure that it is
the
final
(combined) output of RapidMiner that you used for
your BI report
(this should be the combined
results of
Analyze Aspect
Based Sentiment
To create figures/tables in Excel, add new Tab
ote: work on this assignment in stages. You will need at least 5 separate days to run the
analysis because of the
processing
limitations imposed by
Twitter and Aylien
Limit 300
en
Hope following demos will help you get started here:
Discover Twitter Content Using RapidMiner
Cheers,
1
