I get some old RapidMiner process files (.xml) from RM v5.1. Try to import into v8.1 failed. Is there any way to migrate them automaticly?
STOP! My fault... I try to import wrong XML Files. Sorry!
Thanks!
Thomas
hi @thomas_wiedmann - that's the Reporting Extension. Did you add this from the Marketplace?
Scott
You should be able to import the processes just fine (the files that end in the .rmp extension) but from a version that old, you may find that many of the operators have been deprecated, so you will need to review them carefully and you might need to rebuild parts of them to work properly.
My first try to import these old process (v5.3). I get a bunch of warning and errors.
The central missing operator was "Generate Report". Is there an alternate for "Generate Report" ?
Thanks. I install i now. I works.. ;-)
