@elham_calm can you just edit your first post and put the XML code into the </>? It's a mess to look at.
If you want to train your target with more features, then just remove the first Select Attributes operator.
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="8.1.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="8.1.000" expanded="true" height="68" name="Retrieve first test" width="90" x="112" y="136"> <parameter key="repository_entry" value="//Local Repository/first test"/> </operator> <operator activated="true" class="rename" compatibility="8.1.000" expanded="true" height="82" name="Rename" width="90" x="313" y="187"> <parameter key="old_name" value="Date/Time"/> <parameter key="new_name" value="Date"/> <list key="rename_additional_attributes"> <parameter key="Zone Sensible Heating" value="Zone Heating"/> </list> </operator> <operator activated="true" class="set_role" compatibility="5.3.013" expanded="true" height="82" name="Set Role" width="90" x="313" y="289"> <parameter key="attribute_name" value="Date"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="subprocess" compatibility="8.1.000" expanded="true" height="82" name="Set Predictions_Params (2)" width="90" x="313" y="391"> <process expanded="true"> <operator activated="false" class="set_macro" compatibility="8.1.000" expanded="true" height="68" name="Set Window_Size (2)" width="90" x="45" y="187"> <parameter key="macro" value="WindowSize"/> <parameter key="value" value="40"/> </operator> <operator activated="false" class="set_macro" compatibility="8.1.000" expanded="true" height="68" name="Set Horizon (2)" width="90" x="179" y="238"> <parameter key="macro" value="horizon"/> <parameter key="value" value="1"/> </operator> <operator activated="false" class="set_macro" compatibility="8.1.000" expanded="true" height="68" name="Set Future_Month (2)" width="90" x="313" y="238"> <parameter key="macro" value="futureMonth"/> <parameter key="value" value="100"/> </operator> <operator activated="true" class="set_macros" compatibility="8.1.000" expanded="true" height="82" name="Set Macros" width="90" x="246" y="34"> <list key="macros"> <parameter key="forecast_horizon" value="2"/> <parameter key="window_size" value="40"/> <parameter key="future_month" value="100"/> </list> <description align="center" color="transparent" colored="false" width="126">Set your Window and Horizon parameters here.</description> </operator> <connect from_port="in 1" to_op="Set Macros" to_port="through 1"/> <connect from_op="Set Macros" from_port="through 1" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="select_attributes" compatibility="8.1.000" expanded="true" height="82" name="Select Attributes" width="90" x="313" y="493"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="Date|Zone Heating"/> </operator> <operator activated="true" class="filter_examples" compatibility="6.4.000" expanded="true" height="103" name="Filter Examples" width="90" x="313" y="595"> <parameter key="condition_class" value="no_missing_attributes"/> <list key="filters_list"/> </operator> <operator activated="true" class="series:windowing" compatibility="7.4.000" expanded="true" height="82" name="Windowing" width="90" x="514" y="136"> <parameter key="window_size" value="%{window_size}"/> <parameter key="create_label" value="true"/> <parameter key="label_attribute" value="Zone Heating"/> </operator> <operator activated="true" class="series:windowing" compatibility="7.4.000" expanded="true" height="82" name="Windowing (2)" width="90" x="514" y="238"> <parameter key="window_size" value="%{window_size}"/> <parameter key="label_attribute" value="Close"/> </operator> <operator activated="true" class="extract_macro" compatibility="8.1.000" expanded="true" height="68" name="Extract Macro" width="90" x="514" y="391"> <parameter key="macro" value="n_examples"/> <list key="additional_macros"/> </operator> <operator activated="true" class="generate_macro" compatibility="8.1.000" expanded="true" height="82" name="Generate Macro" width="90" x="514" y="493"> <list key="function_descriptions"> <parameter key="filter_range" value="eval(%{n_examples})-1"/> </list> </operator> <operator activated="true" class="filter_example_range" compatibility="8.1.000" expanded="true" height="82" name="Filter Example Range" width="90" x="514" y="595"> <parameter key="first_example" value="1"/> <parameter key="last_example" value="%{filter_range}"/> <parameter key="invert_filter" value="true"/> </operator> <operator activated="true" class="remember" compatibility="8.1.000" expanded="true" height="68" name="Remember" width="90" x="648" y="595"> <parameter key="name" value="LastRow"/> </operator> <operator activated="true" class="series:sliding_window_validation" compatibility="7.4.000" expanded="true" height="124" name="Validation (2)" width="90" x="715" y="187"> <parameter key="training_window_width" value="40"/> <parameter key="test_window_width" value="10"/> <parameter key="horizon" value="%{forecast_horizon}"/> <process expanded="true"> <operator activated="true" class="support_vector_machine" compatibility="8.1.000" expanded="true" height="124" name="SVM (2)" width="90" x="179" y="34"> <parameter key="kernel_type" value="radial"/> </operator> <connect from_port="training" to_op="SVM (2)" to_port="training set"/> <connect from_op="SVM (2)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="8.1.000" expanded="true" height="82" name="Apply Model (3)" width="90" x="45" y="34"> <list key="application_parameters"/> </operator> <operator activated="true" class="series:forecasting_performance" compatibility="7.4.000" expanded="true" height="82" name="Performance (2)" width="90" x="246" y="34"> <parameter key="horizon" value="%{forecast_horizon}"/> <parameter key="main_criterion" value="prediction_trend_accuracy"/> </operator> <connect from_port="model" to_op="Apply Model (3)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (3)" to_port="unlabelled data"/> <connect from_op="Apply Model (3)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="optimize_parameters_grid" compatibility="8.1.000" expanded="true" height="103" name="Optimize Parameters (Grid)" width="90" x="849" y="340"> <list key="parameters"> <parameter key="Performance.prediction_trend_accuracy" value="true,false"/> <parameter key="SVM.kernel_gamma" value="[0.0;1;5;linear]"/> <parameter key="SVM.C" value="[1;20;2;linear]"/> </list> <process expanded="true"> <operator activated="true" class="series:sliding_window_validation" compatibility="7.4.000" expanded="true" height="124" name="Validation" width="90" x="112" y="34"> <parameter key="training_window_width" value="40"/> <parameter key="test_window_width" value="10"/> <parameter key="horizon" value="%{forecast_horizon}"/> <process expanded="true"> <operator activated="true" class="support_vector_machine" compatibility="8.1.000" expanded="true" height="124" name="SVM" width="90" x="179" y="34"> <parameter key="kernel_type" value="radial"/> <parameter key="C" value="20.0"/> </operator> <connect from_port="training" to_op="SVM" to_port="training set"/> <connect from_op="SVM" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="8.1.000" expanded="true" height="82" name="Apply Model (2)" width="90" x="45" y="34"> <list key="application_parameters"/> </operator> <operator activated="true" class="series:forecasting_performance" compatibility="7.4.000" expanded="true" height="82" name="Performance" width="90" x="246" y="34"> <parameter key="horizon" value="%{forecast_horizon}"/> <parameter key="main_criterion" value="prediction_trend_accuracy"/> <parameter key="prediction_trend_accuracy" value="false"/> </operator> <connect from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="log" compatibility="8.1.000" expanded="true" height="82" name="Log" width="90" x="313" y="85"> <parameter key="filename" value="tmp"/> <list key="log"> <parameter key="Gamma" value="operator.SVM.parameter.kernel_gamma"/> <parameter key="C" value="operator.SVM.parameter.C"/> <parameter key="Forecast Perf" value="operator.Validation.value.performance"/> </list> </operator> <connect from_port="input 1" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> <operator activated="true" class="loop" compatibility="8.1.000" expanded="true" height="124" name="Loop" width="90" x="916" y="187"> <parameter key="macro_name" value="loop_forecasts"/> <parameter key="iterations" value="%{future_month}"/> <process expanded="true"> <operator activated="true" class="recall" compatibility="8.1.000" expanded="true" height="68" name="Recall" width="90" x="45" y="85"> <parameter key="name" value="LastRow"/> <parameter key="remove_from_store" value="false"/> </operator> <operator activated="true" class="apply_model" compatibility="7.1.001" expanded="true" height="82" name="Apply Model" width="90" x="246" y="34"> <list key="application_parameters"/> </operator> <operator activated="true" class="multiply" compatibility="8.1.000" expanded="true" height="103" name="Multiply" width="90" x="581" y="238"/> <operator activated="true" class="materialize_data" compatibility="8.1.000" expanded="true" height="82" name="Materialize Data (3)" width="90" x="313" y="373"/> <operator activated="true" class="generate_attributes" compatibility="6.4.000" expanded="true" height="82" name="Increase Date (2)" width="90" x="447" y="373"> <list key="function_descriptions"> <parameter key="Date" value="date_add(Date, 1, DATE_UNIT_HOUR)"/> </list> </operator> <operator activated="true" class="set_role" compatibility="5.3.013" expanded="true" height="82" name="Set Role (3)" width="90" x="581" y="373"> <parameter key="attribute_name" value="prediction(label)"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="select_attributes" compatibility="8.1.000" expanded="true" height="82" name="Select Attributes (2)" width="90" x="313" y="497"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Zone Heating-39"/> <parameter key="invert_selection" value="true"/> </operator> <operator activated="true" class="rename" compatibility="8.1.000" expanded="true" height="82" name="Rename (2)" width="90" x="447" y="497"> <parameter key="old_name" value="Zone Heating-38"/> <parameter key="new_name" value="Zone Heating-39"/> <list key="rename_additional_attributes"> <parameter key="Zone Heating-37" value="Zone Heating-38"/> <parameter key="Zone Heating-36" value="Zone Heating-37"/> <parameter key="Zone Heating-35" value="Zone Heating-36"/> <parameter key="Zone Heating-34" value="Zone Heating-35"/> <parameter key="Zone Heating-33" value="Zone Heating-34"/> <parameter key="Zone Heating-32" value="Zone Heating-33"/> <parameter key="Zone Heating-31" value="Zone Heating-32"/> <parameter key="Zone Heating-30" value="Zone Heating-31"/> <parameter key="Zone Heating-29" value="Zone Heating-30"/> <parameter key="Zone Heating-28" value="Zone Heating-29"/> <parameter key="Zone Heating-27" value="Zone Heating-28"/> <parameter key="Zone Heating-26" value="Zone Heating-27"/> <parameter key="Zone Heating-25" value="Zone Heating-26"/> <parameter key="Zone Heating-24" value="Zone Heating-25"/> <parameter key="Zone Heating-23" value="Zone Heating-24"/> <parameter key="Zone Heating-22" value="Zone Heating-23"/> <parameter key="Zone Heating-21" value="Zone Heating-22"/> <parameter key="Zone Heating-20" value="Zone Heating-21"/> <parameter key="Zone Heating-19" value="Zone Heating-20"/> <parameter key="Zone Heating-18" value="Zone Heating-19"/> <parameter key="Zone Heating-17" value="Zone Heating-18"/> <parameter key="Zone Heating-16" value="Zone Heating-17"/> <parameter key="Zone Heating-15" value="Zone Heating-16"/> <parameter key="Zone Heating-14" value="Zone Heating-15"/> <parameter key="Zone Heating-13" value="Zone Heating-14"/> <parameter key="Zone Heating-12" value="Zone Heating-13"/> <parameter key="Zone Heating-11" value="Zone Heating-12"/> <parameter key="Zone Heating-10" value="Zone Heating-11"/> <parameter key="Zone Heating-9" value="Zone Heating-10"/> <parameter key="Zone Heating-8" value="Zone Heating-9"/> <parameter key="Zone Heating-7" value="Zone Heating-8"/> <parameter key="Zone Heating-6" value="Zone Heating-7"/> <parameter key="Zone Heating-5" value="Zone Heating-6"/> <parameter key="Zone Heating-4" value="Zone Heating-5"/> <parameter key="Zone Heating-3" value="Zone Heating-4"/> <parameter key="Zone Heating-2" value="Zone Heating-3"/> <parameter key="Zone Heating-1" value="Zone Heating-2"/> <parameter key="Zone Heating-0" value="Zone Heating-1"/> <parameter key="prediction(label)" value="Zone Heating-0"/> </list> </operator> <operator activated="true" class="remember" compatibility="8.1.000" expanded="true" height="68" name="Remember (2)" width="90" x="581" y="493"> <parameter key="name" value="LastRow"/> </operator> <connect from_port="input 1" to_op="Apply Model" to_port="model"/> <connect from_op="Recall" from_port="result" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_port="output 1"/> <connect from_op="Multiply" from_port="output 2" to_op="Materialize Data (3)" to_port="example set input"/> <connect from_op="Materialize Data (3)" from_port="example set output" to_op="Increase Date (2)" to_port="example set input"/> <connect from_op="Increase Date (2)" from_port="example set output" to_op="Set Role (3)" to_port="example set input"/> <connect from_op="Set Role (3)" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Rename (2)" to_port="example set input"/> <connect from_op="Rename (2)" from_port="example set output" to_op="Remember (2)" to_port="store"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="source_input 3" spacing="0"/> <portSpacing port="source_input 4" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="8.1.000" expanded="true" height="82" name="Append" width="90" x="1050" y="340"/> <connect from_op="Retrieve first test" from_port="output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Set Predictions_Params (2)" to_port="in 1"/> <connect from_op="Set Predictions_Params (2)" from_port="out 1" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Windowing" to_port="example set input"/> <connect from_op="Windowing" from_port="example set output" to_op="Validation (2)" to_port="training"/> <connect from_op="Windowing" from_port="original" to_op="Windowing (2)" to_port="example set input"/> <connect from_op="Windowing (2)" from_port="example set output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_op="Remember" to_port="store"/> <connect from_op="Validation (2)" from_port="model" to_op="Loop" to_port="input 1"/> <connect from_op="Validation (2)" from_port="training" to_op="Optimize Parameters (Grid)" to_port="input 1"/> <connect from_op="Validation (2)" from_port="averagable 1" to_op="Loop" to_port="input 3"/> <connect from_op="Optimize Parameters (Grid)" from_port="performance" to_port="result 1"/> <connect from_op="Optimize Parameters (Grid)" from_port="parameter" to_op="Loop" to_port="input 2"/> <connect from_op="Loop" from_port="output 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator> </process>
This is my xml codes but with just one attribute and niw i want to change it to several attributes for predicting one target
Thanks
