I have a setup with RM Studio + RM Server (based on RM AMI for AWS). But I cannot upload my pre trained model data to the server (server error 500). In the server.log I got the following message:
Caused by: java.io.IOException: Cannot store example set: com.mysql.jdbc.exceptions.jdbc4.MySQLIntegrityConstraintViolationException: Duplicate entry '?' for key 'PRIMARY'
at de.rapidanalytics.entity.IOObjectVersion.storeStream(IOObjectVersion.java:202) [rapidminer-server-ejb.jar:]
at de.rapidanalytics.entity.Version.storeStream(Version.java:172) [rapidminer-server-ejb.jar:]
at de.rapidanalytics.ejb.RepositoryStorageEJBImpl.storeStream(RepositoryStorageEJBImpl.java:125) [rapidminer-server-ejb.jar:]
... 105 more
Caused by: com.mysql.jdbc.exceptions.jdbc4.MySQLIntegrityConstraintViolationException: Duplicate entry '?' for key 'PRIMARY'
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) [rt.jar:1.8.0_161]
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) [rt.jar:1.8.0_161]
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) [rt.jar:1.8.0_161]
at java.lang.reflect.Constructor.newInstance(Constructor.java:423) [rt.jar:1.8.0_161]
at com.mysql.jdbc.Util.handleNewInstance(Util.java:411)
at com.mysql.jdbc.Util.getInstance(Util.java:386)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:1041)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:4187)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:4119)
at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:2570)
at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2731)
at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2820)
at com.mysql.jdbc.PreparedStatement.executeInternal(PreparedStatement.java:2159)
at com.mysql.jdbc.PreparedStatement.executeUpdate(PreparedStatement.java:2462)
at com.mysql.jdbc.PreparedStatement.executeUpdate(PreparedStatement.java:2379)
at com.mysql.jdbc.PreparedStatement.executeUpdate(PreparedStatement.java:2363)
at org.jboss.jca.adapters.jdbc.WrappedPreparedStatement.executeUpdate(WrappedPreparedStatement.java:493)
at com.rapidminer.server.example.db.ExampleSetToDB.storeMetaData(ExampleSetToDB.java:777) [rapidminer-server-ejb.jar:]
at com.rapidminer.server.example.db.ExampleSetToDB.store(ExampleSetToDB.java:523) [rapidminer-server-ejb.jar:]
at de.rapidanalytics.entity.IOObjectVersion.storeStream(IOObjectVersion.java:192) [rapidminer-server-ejb.jar:]
... 107 more
12:05:52,915 INFO [de.rapidanalytics.ejb.RepositoryStorageEJBImpl] (http-/0.0.0.0:8080-11) admin submitted new object to /apps/model-management/data/Prepared Dataset_Excel_Label_v2.
12:05:52,926 INFO [com.rapidminer.server.example.db.ExampleSetToDB] (http-/0.0.0.0:8080-11) Dropping data tables for es_23
12:05:52,932 INFO [com.rapidminer.server.example.db.ExampleSetToDB] (http-/0.0.0.0:8080-11) Failed to drop table: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Unknown table 'rapidminerserver.es_23_nominal_mapping'. (Ignoring)
12:05:52,937 INFO [com.rapidminer.server.example.db.ExampleSetToDB] (http-/0.0.0.0:8080-11) Failed to drop table: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Unknown table 'rapidminerserver.es_23_data_1'. (Ignoring)
12:06:29,751 INFO [de.rapidanalytics.ejb.RepositoryStorageEJBImpl] (http-/0.0.0.0:8080-11) admin deletes entry at /apps/model-management/data/Prepared Dataset_Excel_Label_v2
12:06:29,755 INFO [com.rapidminer.server.example.db.ExampleSetToDB] (http-/0.0.0.0:8080-11) Dropping data tables for es_23
12:06:30,289 INFO [de.rapidanalytics.ejb.RepositoryStorageEJBImpl] (http-/0.0.0.0:8080-11) admin submitted new object to /apps/model-management/data/Prepared Dataset_Excel_Label_v2.
12:06:30,297 INFO [de.rapidanalytics.ejb.RepositoryEJBImpl] (http-/0.0.0.0:8080-11) admin created entry '/apps/model-management/data/Prepared Dataset_Excel_Label_v2 of type 'data'.
12:06:30,299 INFO [com.rapidminer.server.example.db.ExampleSetToDB] (http-/0.0.0.0:8080-11) Dropping data tables for es_24
12:06:30,299 INFO [com.rapidminer.server.example.db.ExampleSetToDB] (http-/0.0.0.0:8080-11) Cannot determine number of subtables. Probably tables already deleted: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Table 'rapidminerserver.es_24_meta' doesn't exist
12:06:30,300 INFO [com.rapidminer.server.example.db.ExampleSetToDB] (http-/0.0.0.0:8080-11) Failed to drop table: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Unknown table 'rapidminerserver.es_24_meta'. (Ignoring)
12:06:30,300 INFO [com.rapidminer.server.example.db.ExampleSetToDB] (http-/0.0.0.0:8080-11) Failed to drop table: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Unknown table 'rapidminerserver.es_24_nominal_mapping'. (Ignoring)
12:06:30,300 INFO [com.rapidminer.server.example.db.ExampleSetToDB] (http-/0.0.0.0:8080-11) Failed to drop table: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Unknown table 'rapidminerserver.es_24_annotations'. (Ignoring)
12:06:40,608 INFO [de.rapidanalytics.ejb.RepositoryStorageEJBImpl] (http-/0.0.0.0:8080-11) admin deletes entry at /apps/model-management/data/Prepared Dataset_Excel_Label_v2
12:06:40,612 INFO [com.rapidminer.server.example.db.ExampleSetToDB] (http-/0.0.0.0:8080-11) Dropping data tables for es_24
12:07:38,536 INFO [de.rapidanalytics.ejb.RepositoryStorageEJBImpl] (http-/0.0.0.0:8080-11) admin submitted new object to /apps/model-management/data/Prepared Dataset_Excel_Label_v2.
12:07:38,544 INFO [de.rapidanalytics.ejb.RepositoryEJBImpl] (http-/0.0.0.0:8080-11) admin created entry '/apps/model-management/data/Prepared Dataset_Excel_Label_v2 of type 'data'.
12:07:38,731 INFO [com.rapidminer.server.example.db.ExampleSetToDB] (http-/0.0.0.0:8080-11) Dropping data tables for es_25
12:07:38,732 INFO [com.rapidminer.server.example.db.ExampleSetToDB] (http-/0.0.0.0:8080-11) Cannot determine number of subtables. Probably tables already deleted: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Table 'rapidminerserver.es_25_meta' doesn't exist
12:07:38,732 INFO [com.rapidminer.server.example.db.ExampleSetToDB] (http-/0.0.0.0:8080-11) Failed to drop table: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Unknown table 'rapidminerserver.es_25_meta'. (Ignoring)
12:07:38,732 INFO [com.rapidminer.server.example.db.ExampleSetToDB] (http-/0.0.0.0:8080-11) Failed to drop table: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Unknown table 'rapidminerserver.es_25_nominal_mapping'. (Ignoring)
12:07:38,733 INFO [com.rapidminer.server.example.db.ExampleSetToDB] (http-/0.0.0.0:8080-11) Failed to drop table: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Unknown table 'rapidminerserver.es_25_annotations'. (Ignoring)
I assume its related to the encoding settings from MySQL (duplicate error for special chars) but as we are using the RM AMI I don't want to the DB settings.
Best regards!
