Question about - Term Frequencies and TF-IDF: How are these calculated?
thomas_wiedmann
thomas_wiedmann New Altair Community Member
Try to go step by step, but after "Set up Example" my result is different from
https://community.rapidminer.com/t5/RapidMiner-Text-Analytics-Web/Term-Frequencies-and-TF-IDF-How-are-these-calculated/ta-p/46333/jump-to/first-unread-message
My result show not Text column
My process:
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.1.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="text:create_document" compatibility="8.1.000" expanded="true" height="68" name="Create Document" width="90" x="179" y="238">
<parameter key="text" value="This is a report about data mining and text mining"/>
<parameter key="add label" value="false"/>
<parameter key="label_type" value="nominal"/>
<operator activated="true" class="text:create_document" compatibility="8.1.000" expanded="true" height="68" name="Create Document (2)" width="90" x="179" y="340">
<parameter key="text" value="This is a text about video analysis"/>
<operator activated="true" class="text:process_documents" compatibility="8.1.000" expanded="true" height="124" name="Process Documents" width="90" x="380" y="289">
<parameter key="create_word_vector" value="true"/>
<parameter key="vector_creation" value="TF-IDF"/>
<parameter key="add_meta_information" value="true"/>
<parameter key="keep_text" value="false"/>
<parameter key="prune_method" value="none"/>
<parameter key="prune_below_percent" value="3.0"/>
<parameter key="prune_above_percent" value="30.0"/>
<parameter key="prune_below_rank" value="0.05"/>
<parameter key="prune_above_rank" value="0.95"/>
<parameter key="datamanagement" value="double_sparse_array"/>
<parameter key="data_management" value="auto"/>
<operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize" width="90" x="179" y="136">
<parameter key="mode" value="non letters"/>
<parameter key="characters" value=".:"/>
<parameter key="language" value="English"/>
<parameter key="max_token_length" value="3"/>
<operator activated="true" class="text:transform_cases" compatibility="8.1.000" expanded="true" height="68" name="Transform Cases" width="90" x="380" y="136">
<parameter key="transform_to" value="lower case"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="8.1.000" expanded="true" height="68" name="Filter Stopwords (English)" width="90" x="648" y="136"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_port="document 1"/>
</process>
<connect from_op="Create Document" from_port="output" to_op="Process Documents" to_port="documents 1"/>
<connect from_op="Create Document (2)" from_port="output" to_op="Process Documents" to_port="documents 2"/>
<connect from_op="Process Documents" from_port="example set" to_port="result 1"/>
</process>
</process>
What's wrong with my process?
Thanks
Thomas
