HelloI have two dataThe first with columns a1, a2 and a3The latter with columns a1, a2 and a3I want columns a1, a2 and a3 to integrate their data togetherDoes anyone know how?Thanks
Hi @ahootanha,
You can use the Append operator.
Here the process :
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="8.1.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="operator_toolbox:create_exampleset_from_doc" compatibility="0.9.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="45" y="85"> <parameter key="Input Csv" value="a1,a2,a3 1,2,3 1,2,3 1,2,3"/> </operator> <operator activated="true" class="operator_toolbox:create_exampleset_from_doc" compatibility="0.9.000" expanded="true" height="68" name="Create ExampleSet (2)" width="90" x="45" y="187"> <parameter key="Input Csv" value="a1,a2,a3 4,5,6 4,5,6 4,5,6"/> </operator> <operator activated="true" class="append" compatibility="8.1.000" expanded="true" height="103" name="Append" width="90" x="313" y="85"/> <connect from_op="Create ExampleSet" from_port="output" to_op="Append" to_port="example set 1"/> <connect from_op="Create ExampleSet (2)" from_port="output" to_op="Append" to_port="example set 2"/> <connect from_op="Append" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
Lionel
Hellothank you very muchButI do not know where to use these code in my rapidshare program?Please guideSend me a screenshot of the implementation of operatorsThanks
Hellothank you very muchButI do not know where to use these code in my rapidminer program?
To load the XML code, I provided, you have to follow this step :
1. Active the XML panel :
2. Copy the XML code, a,d paste it in the XML panel :
3. Click on the "check button"
4. Normally, the process appears in the process window.
I hope it helps,
