Iterating through a flat list *.dcm/*.tag file pairs and applying some processing on each pair
User: "ralph_brecheise"
New Altair Community Member
Updated by Jocelyn
I have a flat list of files like this:
IM001.dcm
IM001.tag
IM002.dcm
IM002.tag
I'd like to iterate over this list and apply some processing on each *.dcm/*.tag pair, i.e., inside the "Loop Files" operator I'd like to have access to (IM001.dcm, IM001.tag), (IM002.dcm, IM002.tag), etc.
In Python this is easy but I'd like to learn how to do such file manipulation in RM :)
Is this possible?
Ralph
1 - 3 of 31
    User: "YYH"
    Accepted Answer
    Hi@ralph_brecheise
    That is also easy with 'loop files' operator in RapidMiner. You can use regex to pick the list of names for .dcm files. And inside the loop you do something 'magic' to create the corresponding '.tag' file name with the Macro creations.
    With the newly created file name for .tag  you can do whatever you want to load, extract info from tag.
    The number of iteration here is n/2, instead of n for python ;)
    <?xml version="1.0" encoding="UTF-8"?><process version="8.1.000">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="8.1.000" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="concurrency:loop_files" compatibility="8.1.000" expanded="true" height="82" name="Loop Files" width="90" x="916" y="34">
    <parameter key="directory" value="C:\Users\YuanyuanHuang\Documents\RMCommunity\testLoopFiles"/>
    <parameter key="filter_type" value="regex"/>
    <parameter key="filter_by_regex" value=".*dcm"/>
    <parameter key="enable_macros" value="true"/>
    <operator activated="true" class="image:read_image" compatibility="7.0.000" expanded="true" height="68" name="Read Image" width="90" x="246" y="34"/>
    <operator activated="true" class="generate_macro" compatibility="8.1.000" expanded="true" height="82" name="Generate Macro" width="90" x="380" y="34">
    <parameter key="tag_file_name" value="concat(prefix(%{file_name},index(%{file_name},&quot;.&quot;)),&quot;.tag&quot;)"/>
    </list>
    <connect from_port="file object" to_op="Read Image" to_port="file"/>
    <connect from_op="Read Image" from_port="output" to_op="Generate Macro" to_port="through 1"/>
    <connect from_op="Generate Macro" from_port="through 1" to_port="output 1"/>
    <portSpacing port="source_file object" spacing="0"/>
    <portSpacing port="sink_output 1" spacing="0"/>
    <portSpacing port="sink_output 2" spacing="0"/>
    </process>
    <connect from_op="Loop Files" from_port="output 1" to_port="result 1"/>
    </process>
    </process>
    OP
    Accepted Answer
    It works!
    User: "YYH"
    Accepted Answer
    @ralph_brecheise  the error message told you there is missing extensions. You will need at least "operator toolbox", "converters" extensions from marketplace.
    Any questions, please let us know.
