Hi. I cant find twitts from the specific date and the result be shown blanked. this is my xml project:
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.000">
<operator activated="true" class="social_media:search_twitter" compatibility="8.1.000" expanded="true" height="68" name="Search Twitter" width="90" x="45" y="85">
<parameter key="connection" value="NewConnection"/>
<parameter key="query" value="customer"/>
<parameter key="result_type" value="recent or popular"/>
<parameter key="limit" value="100"/>
<parameter key="filter_by_geo_location" value="false"/>
<parameter key="radius_unit" value="miles"/>
</process>
<operator activated="true" class="filter_examples" compatibility="8.1.000" expanded="true" height="103" name="Filter Examples" width="90" x="179" y="85">
<parameter key="parameter_expression" value=""/>
<parameter key="condition_class" value="custom_filters"/>
<parameter key="invert_filter" value="false"/>
<list key="filters_list">
<parameter key="filters_entry_key" value="Created-At.ge.04/28/2017 4:50:15 PM"/>
<parameter key="filters_entry_key" value="Created-At.le.05/17/2017 4:50:31 PM"/>
</list>
<parameter key="filters_logic_and" value="true"/>
<parameter key="filters_check_metadata" value="true"/>
</process>
<operator activated="true" class="select_attributes" compatibility="8.1.000" expanded="true" height="82" name="Select Attributes" width="90" x="313" y="85">
<parameter key="attribute" value=""/>
<parameter key="attributes" value="Created-At|Id|Text|Retweet-Count|Language"/>
</process>
can anyone help me?
