Rapid Miner Server Installation Problem
journey_j
journey_j New Altair Community Member
edited November 5 in Community Q&A
Hello Rapid Miner Community ,  this is first time to install server  and  I alredy download  rapidminer server  . i find a problem  when i run as administrator at rapidminer-server-installer.batch   don't have anything to do for the next step . How can i do now
Best Answer
  • Telcontar120
    Telcontar120 New Altair Community Member
    Answer ✓
    The Server installer batch file can also hang if you don't have your JAVA HOME environment path variable set properly, so you should check that.  But I think even if the installer runs, you won't really be able to run Server with only 4Gb of RAM.
