Too many files open in system (WordNet)
h_benne
h_benne New Altair Community Member
I'm using the WordNet extension and dictionary for sentiment analysis. When I start the proces I receive an I/O error:
"Too many files open in system". See screenshot. Does anybody knows how to solve this?
I'm working with RapidMiner 8.1, WordNet 3.0 files and MacOS High Sierrra.
Thank you!
Hugo
  • Thomas_Ott
    It's been a while since I used that extension but if I remember correctly, that error is probably related to not having enough memory. There was a workaround to this that @hhomburg devised that used the Remember and Recall operators.
  • land
    land New Altair Community Member
    the problem is not that caused by memory limitations. The problem is that you open the file every time the inner process is executed. There's a limit in the operating system for the maximum amount of opened files and you run into that.
    The solution is as Thomas described: Not opening it more than once. You can open that on the outer process, so that it is just once opened, Remember it then (but before the Process Documents is started) and recall in the Process Documents loop without removing from store. If you find that ugly, you can install the Jackhammer Extension and but a Cache operator around the Open Wordnet operator. Should then be executed only once, too.
    Greetings,
    Sebastian
  • asafwat
    asafwat New Altair Community Member
    i have placed Remember and recall as suggested but it still gives the same error @land
  • e_grant1
    e_grant1 New Altair Community Member
    How to connect Recall and Remember operator with OpenWrdNet? @Thomas_Ott @land
    thanks
    Elaine
