I am trying to load an Excel file (a telco churn example), but whenever I view the result, the range is always unknown. May I know how to solve this issue ?
Probably the file's metadata is not propogating correctly. I would toggle on the Sync Metadata with Real Data option in the File > Process, then run it.
Hi @laucherhan,
There are also other ways to inspect the result of the Read Excel Operator.
In both ways you will get the output of Read Excel in the Result perspective.
Best,
Edin
