Hello guys!
I have a problem with using Filter Examples. I am using a data that is already in rapidminer ("Repository/Samples/data/Iris"). After putting data in the process I put the Filter Examples and connect them. Then in the parameters I press "Add Filters" but in the left box there are no attributes shown.
Here is my XML
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.000">
<operator activated="true" class="retrieve" compatibility="8.1.000" expanded="true" height="68" name="Retrieve Iris" width="90" x="45" y="34">
<parameter key="repository_entry" value="//Samples/data/Iris"/>
</process>
<operator activated="true" class="filter_examples" compatibility="8.1.000" expanded="true" height="103" name="Filter Examples" width="90" x="246" y="34">
<parameter key="parameter_expression" value=""/>
<parameter key="condition_class" value="custom_filters"/>
<parameter key="invert_filter" value="false"/>
<list key="filters_list"/>
<parameter key="filters_logic_and" value="true"/>
<parameter key="filters_check_metadata" value="true"/>
</process>
Can somebody help with this issue?
Thank you in advance for your time.
Best regards,
Ledian
