prediction(label) missing when RM reads the model from .mod file
Hi there RM Gurus,
I have a problem to write and read the model files in all my operators. I will give you one example in here. The process is pretty straightforward and easy. I am reading some data from Local Repository and preprocessing it via PCA. Later on I am labelling the data via Set Role and building up a model via k-NN method inside Loop and Deliver Best. In the process like this it works fine. However if I form another project do all the preprocessing steps exactly same and then if I use Read Model instead of the operator itself , it dont produce prediction(label) attribute.
I tried to write model file inside of the Loop and Deliver best, outside of it and use the mod file inside Loop and Deliver best or outside of it.
I am adding XML files instead of copy pasting the code since the code is pretty long.
Thnx in advance for the help.
Best Answer
Sorry for the inconvenience. The problem is solved.
1
1
