Export CSV create scientific notation for very small reals
Hi, I'm having this issue with RM when trying to export a dataset to a csv file. I have two columns with real numbers which can be very small and I noticed in the .csv file the scientific notation is used.
How can I turn it off and write the full number with all the decimal places? I checked the "Write CSV" node's documentation but didn't find anything about it.
Thanks in advance.
1 - 2 of
21
Hi @f_laperna,
Here you can find an example of process (to set according your data), using Python, to write the full number with all the decimal places in a .csv file.
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.1.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="generate_data_user_specification" compatibility="8.1.000" expanded="true" height="68" name="Generate Data by User Specification" width="90" x="112" y="85">
<list key="attribute_values">
<parameter key="a" value="0.000000000015"/>
<parameter key="b" value="0.00000000000000000016"/>
</list>
<operator activated="true" class="python_scripting:execute_python" compatibility="7.4.000" expanded="true" height="82" name="Execute Python" width="90" x="313" y="85">
<parameter key="script" value="import pandas as pd from decimal import Decimal import csv # rm_main is a mandatory function, # the number of arguments has to be the number of input ports (can be none) def rm_main(data): file = 'C:/Users/Lionel/Documents/Formations_DataScience/Rapidminer/Tests_Rapidminer/Precision_Python/test_precision_Python.csv' precision = '%.20f' pd.set_option('precision',20) data = pd.DataFrame(data) data.to_csv(path_or_buf =file ,float_format = precision) # connect 2 output ports to see the results return data"/>
<connect from_op="Generate Data by User Specification" from_port="output" to_op="Execute Python" to_port="input 1"/>
<connect from_op="Execute Python" from_port="output 1" to_port="result 1"/>
</process>
</process>
I hope it helps,
Best regards,
Lionel
I don't think it is possible with the Write CSV Operator. I think it is a rare use case.
If you absolutely need to have this format, you will have to use one of the scripting opereators (R, Python, Groovy). As far as I know, it is not so simple in R either, you would have to change the default options for numerical conversion (with options(scipen = 15), meaning that it will write with fixed point notation up to 15 zeros).
Sebastian
