Increasing Job Container Memory
data123
data123 New Altair Community Member
How do you increase job container memory in Server 8.1?
OutOfMemory Flag indicates my current contianer memory is 12480MB. How do I increase it 24GB?
2018-02-13 15:33:13.913 INFO 14517 --- [taskScheduler-4] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
2018-02-13 15:33:13.913 INFO 14517 --- [taskScheduler-4] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 10592MB / 12480MB
2018-02-13 15:33:18.913 INFO 14517 --- [taskScheduler-4] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
2018-02-13 15:33:18.913 INFO 14517 --- [taskScheduler-4] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 11104MB / 12480MB
2018-02-13 15:33:23.913 INFO 14517 --- [taskScheduler-1] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
2018-02-13 15:33:23.914 INFO 14517 --- [taskScheduler-1] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 11584MB / 12480MB
2018-02-13 15:33:28.914 INFO 14517 --- [taskScheduler-1] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
2018-02-13 15:33:28.914 INFO 14517 --- [taskScheduler-1] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 11680MB / 12480MB
2018-02-13 15:33:33.914 INFO 14517 --- [taskScheduler-1] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
2018-02-13 15:33:33.914 INFO 14517 --- [taskScheduler-1] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 11680MB / 12480MB
2018-02-13 15:33:38.915 INFO 14517 --- [taskScheduler-1] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
2018-02-13 15:33:38.915 INFO 14517 --- [taskScheduler-1] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 11840MB / 12480MB
2018-02-13 15:33:43.915 INFO 14517 --- [taskScheduler-1] c.r.e.j.service.OutOfMemoryWatchdog : Checking memory usage of Job Container
2018-02-13 15:33:43.915 INFO 14517 --- [taskScheduler-1] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 11840MB / 12480MB
Best Answer
  • Edin_Klapic
    Edin_Klapic New Altair Community Member
    Answer ✓
    Hi @data123,
    You can change the value in the configuration file named config.properties in the configuration folder of your Job agent (i.e C:\RapidMinerServer\job-agent\config).
    The parameter is called jobagent.container.memoryLimit
    Please make sure that your license supports the new memory limit (you need to have at least a medium license for RapidMiner Server if you want to assign more than 16 GB).
    Best,
    Edin
  • Edin_Klapic
    Answer ✓
    Hi @data123,
    Best,
    Edin
