If I run my process(which uses cross valaidation) from Java code it's working correctly, but if I create a runnable jar file and execute my program I got this error: 'The dummy operator Cross Validation (replacing concurrency:cross_validation) cannot be executed'
What am I doing wrong? I have a lib folder in my project with the needed Rapidminer jar files. As I read, this plugin isn't open source? What can I do?
RapidMiner.setExecutionMode(RapidMiner.ExecutionMode.COMMAND_LINE);
RapidMiner.init();
Process process = new Process(new File("procFile.rmp"));
process.run();
