Would like to find out how do i go about doing a if condiiton in rapidminer than have a few attributes evaluate to a value.
Eg if (carbrand == '"BMW" OR "AUDI", "CATEGORYACAR", "B")
Hi @Hayashi87,
You can use the Generate Attribute operator :
Here the process :
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="8.1.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_excel" compatibility="8.1.000" expanded="true" height="68" name="Read Excel" width="90" x="112" y="34"> <parameter key="excel_file" value="C:\Users\Lionel\Documents\Formations_DataScience\Rapidminer\Tests_Rapidminer\If_Or\If_Or.xlsx"/> <parameter key="imported_cell_range" value="A1:B10"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="Carbrand.true.polynominal.attribute"/> <parameter key="1" value="Category.true.attribute_value.attribute"/> </list> </operator> <operator activated="true" class="generate_attributes" compatibility="8.1.000" expanded="true" height="82" name="Generate Attributes" width="90" x="313" y="34"> <list key="function_descriptions"> <parameter key="Category" value="if(Carbrand=="BMW"||Carbrand=="Audi","A","B")"/> </list> </operator> <connect from_op="Read Excel" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
Lionel
