I have a trained text-classification model, that works fine with Cross-Validation. Now I am trying to apply the model on new data to predict the different categories. The results are below.
What is going wrong. In the zip are the model and the training and test data files.
PS I look at the post https://community.rapidminer.com/t5/RapidMiner-Studio-Forum/SOLVED-Applying-a-pre-trained-model-on-new-data/td-p/16643
But it applying it gives above results. Probably I forgot something?
@AKO, @land makes very great points but from I see that your process is not what I would do at the very tail end.
Try this (just repath everything)
<?xml version="1.0" encoding="UTF-8"?><process version="8.0.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="8.0.001" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="advanced_file_connectors:read_xml" compatibility="8.0.001" expanded="true" height="68" name="Read XML" width="90" x="45" y="34"> <parameter key="file" value="C:\Users\Thomas Ott\Downloads\CIM_kNN_NewData\Training_items_RapMin.xml"/> <parameter key="xpath_for_examples" value="//root/site/page/children/page/children/page"/> <enumeration key="xpaths_for_attributes"> <parameter key="xpath_for_attribute" value="title[1]/text()"/> <parameter key="xpath_for_attribute" value="body[1]/text()"/> <parameter key="xpath_for_attribute" value="categorie[1]/text()"/> </enumeration> <list key="namespaces"/> <parameter key="use_default_namespace" value="false"/> <parameter key="parse_numbers" value="false"/> <list key="annotations"/> <parameter key="locale" value="Dutch"/> <list key="data_set_meta_data_information"> <parameter key="0" value="title[1]/text().true.polynominal.attribute"/> <parameter key="1" value="body[1]/text().true.polynominal.attribute"/> <parameter key="2" value="categorie[1]/text().true.polynominal.attribute"/> </list> </operator> <operator activated="true" class="rename" compatibility="8.0.001" expanded="true" height="82" name="Rename" width="90" x="112" y="136"> <parameter key="old_name" value="body[1]/text()"/> <parameter key="new_name" value="Text"/> <list key="rename_additional_attributes"> <parameter key="categorie[1]/text()" value="Categorie"/> <parameter key="title[1]/text()" value="Titel"/> </list> </operator> <operator activated="true" class="set_role" compatibility="8.0.001" expanded="true" height="82" name="Set Role" width="90" x="246" y="34"> <parameter key="attribute_name" value="Categorie"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"> <parameter key="Text" value="regular"/> <parameter key="Titel" value="regular"/> </list> </operator> <operator activated="true" class="web:unescape_html_attribute" compatibility="7.3.000" expanded="true" height="82" name="Unescape HTML" width="90" x="380" y="34"> <parameter key="attribute" value="Text"/> </operator> <operator activated="true" class="nominal_to_text" compatibility="8.0.001" expanded="true" height="82" name="Nominal to Text" width="90" x="514" y="34"> <parameter key="attribute" value="Titel"/> </operator> <operator activated="true" class="text:process_document_from_data" compatibility="7.5.000" expanded="true" height="82" name="Process Documents from Data" width="90" x="648" y="34"> <parameter key="prune_method" value="percentual"/> <list key="specify_weights"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="7.5.000" expanded="true" height="68" name="Tokenize" width="90" x="45" y="34"/> <operator activated="true" class="text:transform_cases" compatibility="7.5.000" expanded="true" height="68" name="Transform Cases" width="90" x="179" y="34"/> <operator activated="true" class="text:filter_stopwords_dictionary" compatibility="7.5.000" expanded="true" height="82" name="Filter Stopwords (Dictionary)" width="90" x="380" y="85"> <parameter key="file" value="C:\Users\Thomas Ott\Downloads\CIM_kNN_NewData\stopwords_nl.txt"/> </operator> <operator activated="true" class="text:generate_n_grams_terms" compatibility="7.5.000" expanded="true" height="68" name="Generate n-Grams (Terms)" width="90" x="581" y="34"> <parameter key="max_length" value="1"/> </operator> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (Dictionary)" to_port="document"/> <connect from_op="Filter Stopwords (Dictionary)" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/> <connect from_op="Generate n-Grams (Terms)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="concurrency:cross_validation" compatibility="8.0.001" expanded="true" height="145" name="Cross Validation" width="90" x="849" y="34"> <process expanded="true"> <operator activated="true" class="k_nn" compatibility="8.0.001" expanded="true" height="82" name="k-NN" width="90" x="112" y="34"> <parameter key="k" value="3"/> </operator> <connect from_port="training set" to_op="k-NN" to_port="training set"/> <connect from_op="k-NN" from_port="model" to_port="model"/> <portSpacing port="source_training set" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> <description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="905" y="151">Type your comment</description> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="8.0.001" expanded="true" height="82" name="Apply Model" width="90" x="112" y="34"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="8.0.001" expanded="true" height="82" name="Performance" width="90" x="313" y="34"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="performance 1"/> <connect from_op="Performance" from_port="example set" to_port="test set results"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_test set results" spacing="0"/> <portSpacing port="sink_performance 1" spacing="0"/> <portSpacing port="sink_performance 2" spacing="0"/> </process> </operator> <operator activated="true" class="advanced_file_connectors:read_xml" compatibility="8.0.001" expanded="true" height="68" name="Read XML (2)" width="90" x="45" y="391"> <parameter key="file" value="C:\Users\Thomas Ott\Downloads\CIM_kNN_NewData\Validatie_items_RapMin.xml"/> <parameter key="xpath_for_examples" value="//root/site/page/children/page/children/page"/> <enumeration key="xpaths_for_attributes"> <parameter key="xpath_for_attribute" value="title[1]/text()"/> <parameter key="xpath_for_attribute" value="body[1]/text()"/> <parameter key="xpath_for_attribute" value="categorie[1]/text()"/> </enumeration> <list key="namespaces"/> <parameter key="use_default_namespace" value="false"/> <parameter key="parse_numbers" value="false"/> <list key="annotations"/> <parameter key="locale" value="Dutch"/> <list key="data_set_meta_data_information"> <parameter key="0" value="title[1]/text().true.polynominal.attribute"/> <parameter key="1" value="body[1]/text().true.polynominal.attribute"/> <parameter key="2" value="categorie[1]/text().true.polynominal.attribute"/> </list> </operator> <operator activated="true" class="rename" compatibility="8.0.001" expanded="true" height="82" name="Rename (2)" width="90" x="179" y="391"> <parameter key="old_name" value="body[1]/text()"/> <parameter key="new_name" value="Text"/> <list key="rename_additional_attributes"> <parameter key="categorie[1]/text()" value="Categorie"/> <parameter key="title[1]/text()" value="Titel"/> </list> </operator> <operator activated="true" class="select_attributes" compatibility="8.0.001" expanded="true" height="82" name="Select Attributes" width="90" x="313" y="391"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Categorie"/> <parameter key="invert_selection" value="true"/> </operator> <operator activated="false" class="set_role" compatibility="8.0.001" expanded="true" height="82" name="Set Role (2)" width="90" x="380" y="493"> <parameter key="attribute_name" value="Categorie"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"> <parameter key="Text" value="regular"/> <parameter key="Titel" value="regular"/> </list> </operator> <operator activated="true" class="web:unescape_html_attribute" compatibility="7.3.000" expanded="true" height="82" name="Unescape HTML (2)" width="90" x="514" y="391"> <parameter key="attribute" value="Text"/> </operator> <operator activated="true" class="nominal_to_text" compatibility="8.0.001" expanded="true" height="82" name="Nominal to Text (2)" width="90" x="648" y="391"> <parameter key="attribute" value="Titel"/> </operator> <operator activated="true" class="text:process_document_from_data" compatibility="7.5.000" expanded="true" height="82" name="Process Documents from Data (2)" width="90" x="782" y="289"> <parameter key="prune_method" value="percentual"/> <list key="specify_weights"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="7.5.000" expanded="true" height="68" name="Tokenize (2)" width="90" x="45" y="34"/> <operator activated="true" class="text:transform_cases" compatibility="7.5.000" expanded="true" height="68" name="Transform Cases (2)" width="90" x="179" y="34"/> <operator activated="true" class="text:filter_stopwords_dictionary" compatibility="7.5.000" expanded="true" height="82" name="Filter Stopwords (2)" width="90" x="380" y="34"> <parameter key="file" value="C:\Users\Thomas Ott\Downloads\CIM_kNN_NewData\stopwords_nl.txt"/> </operator> <operator activated="true" class="text:generate_n_grams_terms" compatibility="7.5.000" expanded="true" height="68" name="Generate n-Grams (2)" width="90" x="581" y="34"> <parameter key="max_length" value="1"/> </operator> <connect from_port="document" to_op="Tokenize (2)" to_port="document"/> <connect from_op="Tokenize (2)" from_port="document" to_op="Transform Cases (2)" to_port="document"/> <connect from_op="Transform Cases (2)" from_port="document" to_op="Filter Stopwords (2)" to_port="document"/> <connect from_op="Filter Stopwords (2)" from_port="document" to_op="Generate n-Grams (2)" to_port="document"/> <connect from_op="Generate n-Grams (2)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="apply_model" compatibility="8.0.001" expanded="true" height="82" name="Apply Model (2)" width="90" x="1050" y="238"> <list key="application_parameters"/> </operator> <connect from_op="Read XML" from_port="output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Unescape HTML" to_port="example set input"/> <connect from_op="Unescape HTML" from_port="example set output" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/> <connect from_op="Process Documents from Data" from_port="example set" to_op="Cross Validation" to_port="example set"/> <connect from_op="Process Documents from Data" from_port="word list" to_op="Process Documents from Data (2)" to_port="word list"/> <connect from_op="Cross Validation" from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_op="Cross Validation" from_port="performance 1" to_port="result 2"/> <connect from_op="Read XML (2)" from_port="output" to_op="Rename (2)" to_port="example set input"/> <connect from_op="Rename (2)" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Unescape HTML (2)" to_port="example set input"/> <connect from_op="Unescape HTML (2)" from_port="example set output" to_op="Nominal to Text (2)" to_port="example set input"/> <connect from_op="Nominal to Text (2)" from_port="example set output" to_op="Process Documents from Data (2)" to_port="example set"/> <connect from_op="Process Documents from Data (2)" from_port="example set" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
@AKO the problem you had was the position of the Performance operator. The Performance operator needs to see a label from the training set to compare it to what the model is building on the training set. In your case, your test set provided a label, but it was not what the K-nn trained on, so when it was comparing the two, you got bad results.
Well, not necessarily. I would be very suspicious if the prediction just predicts one class, them something is usually wrong in the data preparation. In this case your new data set simply contains ONLY "" labeled examples. (Which I rather would call "Other" for ease of reading...). However, it seems that your models is quite bad as it only predicts other classes. Have you had "" labeled examples in the training set at all?
In short: Results look like okayish process with unknown predictive performance but with a bad train/test data set.
Greetings,
Sebastian
@thomas Thanks for your correction. @land: thanks for your comment.
I have compared the prediction results of my model and Thomas Ott solution in Excel (see att.). There seem to be little difference between the predicted results.Differences are: 1) some confidence numbers of solution Thomas Ott are 'float'. In my solution the confidence numbers are 'integer'.2) there are 3 rows with different predictions (see column with red-false values).
What obviously went wrong in my model is the Perfomance Operator. Probably the Performance operator is placed on the wrong position?Question: Is there a (fundamental) error (besides the placing of the Performance operator) in my approach?
@Thomas_Ott; Thanks for your answer!
@AKO no worries and glad it worked!
