Is there a way to change/set my process's training algorithm, that I loaded into my Java application? Before I run the process from the code.
I would recommend to use usual way via branching/select subprocess operators in combination with context macros that can be easily set via API.
What kind of application are you building? Something fancy we can see data science in action in the web?
Greetings,
Sebastian
