How To Set up RapidMiner library in Android Studio
User: "theatozchannel5"
New Altair Community Member
Updated by Jocelyn
I am currently working on an object recognition app. I'm using Android Studio and I have created a Neural Network model on Rapid Miner Studio and saved it as PMML. I want to apply this model on a set of extracted features in Android Studio so that I can obtain a prediction (e.g: is the object a fruit/vegetable/nut?). However, I'm not able to integrate the Rapid Miner library in Android Studio. I've downloaded "rapidminer-extension-template" from https://github.com/rapidminer/rapidminer-extension-template. Is it the correct file that should be downloaded?
I have looked for a working solution for the past 4 days but I can't seem to find one.
Do I have to use the Rapid Miner library to apply the PMML model or is it possible to use something else?
1 - 2 of 21
    OP
    Accepted Answer
    It is possible to import the PMML file in Android Studio. I had to add a library ("pmml-model-1.3.9.jar" along with the schema library: "pmml-schema-1.3.9") that supports it. Now I only have to look for the library's documentation to be able to apply the model on a set of features to obtain a prediction.
    Thanks for the help :D
    OP
    Accepted Answer
    I downloaded the wrong library and found out about this only after receving an email from the library developer stating that the pmml-evaluator library had to be used instead of pmml-model.
