rm 8 server com.rapidanalytics.plugindir doesn't refer to default agent
RayJhong
RayJhong New Altair Community Member
Hi There,
As i known that rm 8.0 server could implement distrubuted environment by assigning job agents accross instances. And there is also an agent to operate default queue named "agent-bundled" if you don't assign tasks to other job agents.
However, recently, i tried to install extensions for RM server following this instruction, after restart RM server, i found new extensions appear on web UI which is great. (Operator Toolbox & Text Processing)
But when i execute process on server using default queue, got an error said can't find "SMOTE UPSAMPLE" operator which is from "Operator Toolbox".
I have to manually put those extension into C:\RapidMinerServer\job-agent\extensions to be able to load those extensions when running default queue, seems like default queue won't refer to this parameter "com.rapidanalytics.plugindir" in system settings as below:
 What can i do if i want default job agent to take "com.rapidanalytics.plugdir" this parameter, otherwise i have to do it twice when adding new extensions?
Any suggestion would be appreciated.
Sincerely,
Ray Jhong
Best Answer
  • Edin_Klapic
    Edin_Klapic New Altair Community Member
    Answer ✓
    Hi @RayJhong,
    You can set the parameter
    jobagent.container.extensionsDir = <path-to-your-RapidMiner-Server-extensions-folder>
    in the .../job-agent/config/config.properties file.
    This should solve the issue. We are aware of this and put it on our list.
    Best regards,
    Edin
  • Edin_Klapic
    Answer ✓
    Hi @RayJhong,
    Best regards,
    Edin
Welcome!
Welcome!
